588,344 active members*
5,565 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > What is your velocity and acceleration settings for 6040T
Hybrid View
    Jan 2017
    36
    Hey all, ive got a 6040T upgraded with a Gecko G540 and 48V power supply on a old old laptop using serial cable.
    Ive got my Velocity set to 3000mm/min and Acceleration 500mm/min and have not had a problem will rapiding around the table manually.
    If I set the velocity to say 4000mm/min it will run at that and seems all good at first but every now and then while rapiding around the steppers will stall.
    I even tried running a 2D contouring program with the cutting travel speed as 3000mm / min (previously fastest ive cut at is 2000mm / min) and it stalled at one point loosing steps and ruining the cut
    So my first question is what is the fastest others are getting out of their 6040?
    Im trying to find if it is the machine (steppers) that is limiting me Or Im thinking maybe my laptop is too slow to keep up?
    The highest kernel speed I can choose with the laptop is 35khz any higher and it just freezes up.
    Or do I need ethernet smooth stepper?
    Nov 2012
    108
    Re: What is your velocity and acceleration settings for 6040T
    I also have a G540 at 48V and an Ethernet Smoothstepper, driven by Mach3
    I don't run more than 2000 mm/minute as I have not done much work where my feed/speed calculator suggests I can go much faster.
    If you can rapid at 3000 but stall when cutting, I'd assume that it's a lack of torque in the steppers rather than a problem with your control software, but I am no expert.
  1. Question on velocity and acceleration settings in mach3
    By uberlinuxgeek in forum Shopmaster/Shoptask
    Last Post: 09-25-2015, 03:10 PM
  2. Velocity vs Acceleration?
    By stefon in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2012, 12:13 AM
  3. Max Velocity and acceleration
    By Jamy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-04-2008, 06:35 AM
