I keep loosing the islands on the D's and A's when cutting letters out of MDF. This is 1/2 inch MDF using an 1/8 inch spiral high speed steel cutter at 60 ipm. Letters are 1/8 inch deep.
Thanks for any help.
You may try reversing the cut direction. Two passes rather than one might help with it as well.
Lee
MDF can be flakey and weak.. are you using an up cut bit? maybe that is ripping the little islands out. perhaps try a downcut.
~Steve
I'm using a upcut. Thanks guy's I will try you suggestions.
are the "Islands" in the D and A being ripped out or is the cutter cutting where it shouldn't be?
This site changed my life ----> www.alittlebiteasier.net
Yup.....looks like a upcut versus downcut issue to me.....
When architects and engineers fail ......my phone rings....go figure! LOL What next?
They are being ripped out SmokinErb.
