588,010 active members*
3,657 visitors online*
IndustryArena Forum > MetalWorking Machines > Colchester Tornado lathes > What's the Tornado 100 tailstock taper?
    Jul 2015
    Question What's the Tornado 100 tailstock taper?
    I started working with a 1997 Tornado 100, it has the hydraulic tailstock (the type that is set manually and only pushes against the material hydraulically), but it has no live end.
    In order to buy one I need to know the taper it used for attachment, it appears to be MT4 but since no documentation is available with the machine I can't be sure. Also, it has a screw-on lid with a hole in the center that goes over the tapered bore, so that made me wonder if there is a special attachment that's supposed to go there rather that a simple tapered tool.
    Any advice would be appreciated.
    Thanks,
    Jun 2005
    232
    Re: What's the Tornado 100 tailstock taper?
    I have a 1998 clausing storm it has a number 4 taper . Not sure for the Tornado.
    The threads your referring to.There is a nut with a hole in it.
    you screw it on before you put your center in and when you un screw it .
    It pushes the center out .
    Tim
    Jul 2015
    Hi Tim,
    Thanks for the info (and now I know it has another brand name I can look up data by).
    Thanks a lot!
  1. Replies: 25
    Last Post: 04-28-2014, 10:19 PM
  2. WTB: Manual Tailstock with morse taper for 10" troyke rotary table
    By torinwalker in forum Want To Buy...Need help!
    Last Post: 11-28-2012, 08:22 PM
  3. Lathe toolpost morse taper holder vs. tailstock for drilling?
    By bogiestl in forum MetalWork Discussion
    Last Post: 12-30-2011, 12:43 AM
  4. Difference in Female Taper angle using Taper Cutter
    By Buntron in forum Material Machining Solutions
    Last Post: 06-07-2011, 06:53 AM
  5. help identify tailstock taper.
    By menatman in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 01-10-2007, 02:43 PM
