In terms of laser tube power, when is a Watt a Watt?
I've been using a UK built laser (a CCT) with a 30W air-cooled RF tube - a tiny wee thing. With this I've achieved work that others (with experience of Chinese lasers, using water-cooled DC glass tubes) have said would need an 80W or even a 100W tube.
So is there any real comparison between nameplate Watts and cutting power, when we compare between DC & RF tubes? Should power for machines like Epilogs be seen realistically as twice (or more!) that for the glass tube brigade?
It was also noticeable that this air-cooled tube had almost no cooling applied to it, certainly compared to the sort of pumped-water chiller units essential for bigger Chinese machines.
I'm looking at a Lasersaur build (a DIY design based on Chinese tubes), as a way to get a big laser for 8x4 sheets of plywood. Although I'd probably have gone for the biggest tube anyway, do I still need a reality check before assuming it's a simple upscale from a real tube machine.
