I am building a small cnc machine and am planing on using Mark 3 software, do I need a break-out-board?
Dan
Dan
Long answer: A break-out board goes between the parallel port and the motor drivers. You don't necessarily NEED one but it does make the connections much easier to setup and troubleshoot. Plus some of the BOB's have optical isolation between the outputs and your parallel port. This keeps the voltages isolated from the parallel port so hopefully there is less chance of anything killing the port. Most of the BOB's also have LED's for diagnostic purposes. Free plans are available on Pminmo's website. I can vouch for the 3 and 4 axis boards with and without isolation. They all work great.
Short answer: It's up to you.
They are cheap and offer protection. I would advise using one - if nothing else, they make connections easier.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Short answer, if you can solder no. A solder cup db25 and discrete wires will work just as well.
A BOB or my Interfaces are more of a convience, with some extra features.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
I'm considering the Keling CNC package which comes with a BOB. There's not much data in the ad. I was wondering if was optical isolating and I was wondering if I could get all 6 hard stop switches in it too. Or will I need a second BOB and parallel port? What do the experts do to get all 6/9 switches hooked up?
You must use a breakout board when using any of our drives except for the G203V. Use approved boards from PMDX, Bob Campbell Designs or CNC4PC only.
Mariss
Sure. Most modern (< 2 years old) PCs output 3.3V signal levels on the parallel ports while the drives require 5V signal levels to work properly. The exception is the new G203V that works with any standard logic level; 1.8V, 2.5V, 3.3V or 5V.
The breakoutboard buffers that change 3.3V signals to 5V signals must be 74ACT series logic. 74LS, 74HC, etc. will not work because of inadequate output current.
Mariss
That explains it thank you.
John
