603,794 active members*
4,217 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Metalworking- / Woodworking Tooling / Manual Machining > Where can I buy a 1/8" End Mill (cutting 4140 HT) that can cut at least 1 inch Deep?
Results 1 to 10 of 10
    Sep 2010
    I am looking for End Mills for a specific milling application and I will need them to be able to cut with a depth of at least 1 inch to finish the inside of a piece I am working on.
    a 1/8" End mill that can cut 4140HT with a cutting depth of at least 1" is needed.
    Any help would be appreciated. Thanks.
    Mar 2003
    4826
    I see one available at Harveytool.com but I'm glad I'm not the one who has to use it in 4140
    First you get good, then you get fast. Then grouchiness sets in.
    Jun 2010
    84
    Maritool has one:
    http://www.maritool.com/Cutting-Tool...duct_info.html
    I highly recommend Maritool - awesome stuff.
    Feb 2007
    592
    Lightbulb
    You are asking for real problems and a special (and very expensive!) tool that will self destruct with any abuse.
    More likely you need to step back and review other options.
    Jun 2011
    Are you actually going to use all 1.00" of the flutes or do you just need to reach into a part 1.00" deep? A necked tool with a short LOC would be much stronger than a tool with 1.00" of flutes. Just my opinion.:idea:
    Sep 2006
    6463
    Hi, you must be joking.....in 4140....wow.
    I'd spark erode it.....even grinding with a mounted stone would give you headaches.
    Actually, without seeing the shape of the job, (and a photo does wonders), you could use a slotting operation as used on the back of a Bridgeports' ram if'n you can get one, and this will allow you to plunge down to an exact depth with a tool like a chisel etc.
    Ian.
    Aug 2008
    292
    parameters
    Quote Originally Posted by Gun-Machine View Post
    parameters
    1/8" diameter carbide end mill
    1" flute length
    cutting 4140 steel
    my calculations show at 1.1" stick out from collet a 1/8" diameter carbide end mill will have a safe maximum depth of cut of 0.004"
    ......push it too hard and end mill will break or at the very least leave a bad finish
    Nov 2008
    421
    With out knowing exactly what are you going to machine, I would strongly suggest a slot cutter mounted either on supported arbor or use short stubby arbor. Hope this helps , Either way good luck.
    Forget about global warming...Visualize using your turn signal!
    May 2004
    4519
    You did not specify what finish is required or if a small step is allowable. If possible, consider pre-drilling the corners with at least a 0.120 drill. You probably will also find out that you have to go against conventional machining wisdom to avoid breaking your endmill and reducing chatter by slowing everything way, way down. I am talking 200 RPM or less and 0.5 IPM feed. I would still try it wish recommended speed and feed first. But you will probably write off the first endmill to learning. Also maximum axle depth of cut is probably going to be 1/2 diameter or less.
    Aug 2008
    292
    end mill length
    Quote Originally Posted by txcncman View Post
    the chance of milling 4140 steel with a
    1/8" diameter end mill
    at 1" stickout of collet
    at 0.062" DOC i would rate at <1% it will work
    the rule is stickout 2x more flexing goes up 2x2x2 or 8 times
    stickout 3x more flexing goes up 3x3x3 or 27 times
    thats one of those rules of the universe. doesn't matter if you do not like it. long end mills on hard materials behave 1000% different than short end mills on aluminum
  1. Adaptor for 1/8" bit in 1/4" inch router bore
    By RomanLini in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 09:18 PM
  2. 015 / .020 deep engraving in 4140 - What kind of laser does it take ?
    By MassiveTool in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-25-2009, 01:35 PM
  3. Best way to mount 1/16 inch ball mill with 3/16 inch shank in router.
    By cjjonesarmory in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-02-2009, 11:38 AM
  4. Cutting through the crust on 4140
    By jderou in forum MetalWork Discussion
    Last Post: 08-20-2008, 10:33 PM
  5. boring a .875" hole 3" deep in 304SS
    By mc-motorsports in forum MetalWork Discussion
    Last Post: 04-15-2008, 08:57 PM
