Nichrome wire at http://mscdirect.com all sizes and kinds and 1/3 the proce of other distributors
Hey Gil
That power supply is the one I use. You know it works well with the inconel.
I think I got my wire from aerowright.com
Later Bruce
www.wtxrcdog.com
http://wtxrcdog.blogspot.com/
You can buy Chrome Nickel fishing leader wire at Walmart. It's 69# test and 0.018 inch. It comes in a 25 foot length for less than $2. Works like a champ.
This is the stuff at Walmart.
http://www.thornebros.com/muskie/ter.../lc_mason.html
I find several types od Nichrome wire.
Nickel-Chrom - copper coated
Nickel-Chrom - shining
Ni 80 - shining
Nickel-Chrom-Titan
diameter
0,2mm resistance on 1 meter 16,8
0,3mm resistance on 1 meter 10,1
0,35mm resistance on 1 meter 7,5
0,4mm resistance on 1 meter 4,6
0,5mm resistance on 1 meter 3,4
0,6mm resistance on 1 meter 2,3
or 0.008 0.012 0.014 0.016 0.020 0.024 inch
My question is: wich wire to use for foam cutting and what kaind wire diameter to use. Whati is difference between this wires.
I am using .018 inch, but I see a lot people using between .016 and .020 inch. I have a 115V to 25.2V, 2 Amp step down transformer. My AC voltage going into my transformer measures 124.9 and I'm seeing a little over 28 volts at my cutting wire. My power supply uses a 1 Amp fuse and so far it hasn't blown using .018 inch wire.
Do you cut using wood templates or similate?? I used to cut wings for Rc planes using wood templates, and the wire used to break due to friction. Then I learned a simple trick: you shoul cover the edge of the template with adhesive aluminium tape, wich is used for isolating air conditing installations. Then the wire will run smoothly
Regards from Spain
buy directly from Manufacturer in China, minimum order quantity is one spool.
Here: Http://niwire.com
why not just buy rene 41 wire from skyking? cost is about 60c per foot but you get a much better cut and last longer than s/s or nicrome wire.
you can buy 50feet for $30 and its only $6 shipping to usa
sky king rene 41 wire
I think this site can help you to find what you are looking for:
wires.co.uk : Bare Nickel Chrome / Nichrome Section
they have almost all the kinds of wires, and many more helpful items.
For anyone that needs "small" quantities, one strand of bicycle brake cable works perfectly for me.
It measures +/- 20 ohm/meter. The twist does go away after the first use.
Pelican Wire | Custom manufacturer of appliance, bare resistance, floor heating, insulated and thermocouple wire.
they have 50 foot and 100 ft spools listed on their website. If you need larger quantities then you should call them for a quote 239-597-8555
They have competitive pricing and their customer service is outstanding
