603,975 active members*
3,239 visitors online*
Results 1 to 7 of 7
    Apr 2003
    1873
    Where can I find
    Any one know where I might be able to locate small spur gears made out of fiber? or better yet composite.
    Did a web search and found a company but minimum quantity is 100.
    Dimensions
    OD .852
    Bore: .312
    Height: .400
    # Teeth: 26
    Pressure angle 20 ?
    Ken
    Jan 2004
    190
    what about sdp/si ( 516-328-3300 ) www.sdp-si.com
    thanks Kenneth
    www.lambertsrc.com
    Apr 2003
    1873
    I had looked at them Ken but they do not appear to have the size I need. I may still give them a call on Monday and see if it may be available.
    Ken
    Mar 2003
    4826
    KenS,
    Are you fixing your speed increaser? Better buy a hundred
    First you get good, then you get fast. Then grouchiness sets in.
    Apr 2003
    1873
    That sounds very much like a warning
    Go pretty quick do they ?
    Ken
    Jan 2004
    137
    Have you tried Boston Gear?
    Kenny
    "Plan your work; Work your plan"
    Mar 2003
    19
    Where can I find
    Dimensions
    OD .852
    Bore: .312
    Height: .400
    # Teeth: 26
    Pressure angle 20 ?
    Ken
    Hello , Ken the machine shop that I work for just might be able to help you out . If you havent filled your needs yet let me know and i'll see if I can help . We make all kinds of small or large gears , from just about any material, fibre , delrin, brass, aluminum, steel , cast iron, to name a few.
  1. york and lancaster couny i can not find anyone
    By harolda in forum Mentors & Apprentice Locator
    Last Post: 08-21-2006, 04:37 PM
  2. The most useful software that I cant find!
    By berin in forum Uncategorised CAM Discussion
    Last Post: 12-10-2004, 06:38 PM
  3. Where to find surplus Tslots or 80/20
    By samualt in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 11-05-2004, 08:04 PM
  4. I hate losing Links, trying to find ones for Thomson Bearings
    By CNC Brute in forum DIY CNC Router Table Machines
    Last Post: 01-23-2004, 07:16 PM
  5. Find and Replace
    By HuFlungDung in forum OneCNC
    Last Post: 05-13-2003, 12:05 AM
