587,163 active members*
3,775 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Where do I get cheap stepper drivers?
Results 1 to 12 of 12
    May 2006
    309
    I recently blew a cnc-box 3977 driver and need to know where I can get a new one. Is it possible to get disconnection-safe drivers?
    Aug 2006
    Hobby CNC
    XYlotex
    Apr 2007
    8082
    Quote Originally Posted by jaru-eri View Post
    http://www.geckodrive.com makes the only "disconnection-safe" stepper drivers that I know of. Take a look at their G540 and G203V models. Although they are not considered cheap, you get what you pay for.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Dec 2004
    1865
    Quote Originally Posted by CarveOne View Post
    CarveOne
    They are inexpensive compared to the cost of replacing a driver board when one driver gets disconnected accidently. Cheap is just that, cheap. Cost effective is more of what needs to be discussed/considered.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Mar 2008
    3655
    In addition to increased performance, plug & play convenience, unkillable features and idle current limiting, the fact that the G540 can use up to 50V power supplies and a REAL 3.5A per motor, then if you factor in the VALUE that comes with the G540, it does not cost much at all:
    Four Axis unkillable and plug & play G540: $299
    Built in breakout board, with connections for home/limit switches and outputs for relays: $80 that you don't need to spend.
    Built in Speed controller: $40 that you don't need to spend.
    Built in 5V Logic power supply: $20 that you don't need to spend.
    Provided DB9 connectors: $12 that you don't need to spend.
    $299 minus $152 = actual cost of just $147 for a VERY sophisticated 4 axis drive.
    CR.
    Dec 2004
    1865
    Cheap vs cost effective.
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    Well said
    Mike
    Apr 2007
    8082
    I agree completely.
    The G540 not cheaply made or designed. You get what you pay for. There is no better deal anywhere for the money.
    Crevice Reamer added all the details that I didn't add in my too quick reply to point jaru-eri toward the Gecko web site where the technical details can be found.
    CarveOne
    CarveOne
    Mar 2008
    3655
    Thanks guys! It's easy to praise the G540 though--It's a fantastic deal. I only barely scratched the surface of it's features--And even Gecko forgot to mention the microstep to full step morphing that allows motors to run much faster:
    G540
    The G540 is a complete 4-axis system which plugs directly into your computer via the parallel port and to your motors through DB9 connectors. It contains four of our G250 drives, our own breakout board and a hard anodized aluminum case.
    G540 Specifications:
    - Four 10-Microstep motor drives
    - 0 to 3.5A rated phase current
    - 18VDC to 50VDC supply voltage
    - Mid-band resonance compensation
    - Auto standby current (70% current)
    - Short-circuit protected
    - Optoisolation on all LPT signal pins
    - Two 1A at 0 to 50VDC rated outputs
    - Four SPST to GND inputs (TTL)
    - FAULT indicator LED,signal to PC
    - POWER indicator LED
    - I-SET resistor on motor connector
    - TRIM adjust for motor smoothness
    - Panel mount (5.7” by2.4” hole dim.)
    - Anodized aluminum package
    - No heatsink needed below 40C ambient
    - Easy to service, removable drives
    - Modular PCB design with no internal wires
    - 10kHz watchdog timer (charge pump)
    - Optoisolated analog output for a VFD drive
    - Conservative ratings, premium components
    - Comes with four backshells and four DB9 solder cup connectors
    NOTHING else comes close to the value of a G540--And as I have shown, the TRUE COST is about what ONE 203V drive costs.
    AND--it is so tiny that you could mount the whole thing INSIDE the case with the computer.
    CR.
    Apr 2007
    8082
    Well, I got a good deal too. Four G203v arrived last month. What I saved at the sale price will pay for a BOB for them.
    CarveOne
    CarveOne
    Dec 2004
    43
    I am looking at this gecko 540 4 axis system.
    Do I make my own cables to connect to the DB9 connectors?
    Also, I can't picture in my head how the current set resistors hook in.
    Thanks, JOhn
    Mar 2008
    3655
    Quote Originally Posted by johnt View Post
    Thanks, JOhn
    Hi John. Yes, you have to make your own cables. Shielded twisted pair wire is best, but not required. This wire is good and also inexpensive:
    http://cgi.ebay.com/Servo-Motor-Wire...3286.m20.l1116
    When you make up the cables using the connectors that come with the G540, you just solder the 1/4 Watt resistor between pins 1 and 5 and the wires into pins 6,7,8,9. Then you slide a piece of heat shrink tubing (which you have previously slid onto the wire) down onto the connector and heat shrink it.
    http://geckodrive.com/upload/G540%20REV3%20MANUAL.pdf
    You can get the resistors here:
    http://digikey.com/
    Do the MOTOR end of the cable this way:
    http://cnczone.com/forums/showthread...651#post545651
    CR.
    my solution
    Just my 2 cents here. I bought the Linistepper controls. These have worked great for me. I used some molex connectors on the ends of my cables where they plug into the power supply/driver control box. In the plugs, I wired a loop so that the power has to go through the loop to get to the driver. If I unplug a motor, the power connection is cut to that axis driver. Works great as a safety.
    The red loops in the photo is the loopback power wire.
    My Solsylva machine (my first cnc)
    http://www.cnczone.com/forums/showthread.php?t=44336
  1. Stepper motors, drivers etc
    By _taz_ in forum Stepper Motors / Drives
    Last Post: 08-05-2007, 12:49 PM
  2. stepper motor drivers
    By nurseling in forum CNC Machine Related Electronics
    Last Post: 01-16-2007, 11:43 PM
  3. stepper drivers
    By Nilesh in forum CNC Machine Related Electronics
    Last Post: 06-23-2004, 02:05 AM
  4. Possible CHEAP drivers, stepper and/or servo
    By NeoMoses in forum CNC Machine Related Electronics
    Last Post: 03-23-2004, 08:45 PM
  5. stepper drivers
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 01-19-2004, 07:58 AM
