603,936 active members*
3,589 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Where does one get a computer with a parallel port?
Results 1 to 6 of 6
    Nov 2024
    I started building a 3 axis CNC router maybe 7 yrs ago?
    Anyhow I built the control panel using a gecko 3axis motor driver.
    I remember using an old computer with a parallel port to the gecko.
    But for the life of me I can't find a computer with a lpt1 port.
    Is there a reputable supplier for stuff like this?
    I think I was also running windows 97?
    Thanks for reading
    Ray
    Apr 2018
    158
    Re: Where does one get a computer with a parallel port?
    Parallel ports are obsolete, just like punched paper tape.
    But if you really want one, Ebay offers choices. Here's one: https://www.ebay.com/itm/324681069150?
    Dec 2003
    24260
    Often you will find the connector on the MB, it just needs the board connector, socket and ribbon cable to complete.
    Albert E.
    Nov 2013
    5409
    not all parallel ports work for CNC. There is a specific standard that is required, and many parallel port cards don't support it....fine for a parallel port printer say, but not
    for CNC.
    There is a company, PMDX, that makes breakout boards and motion controllers specifically for Mach3 and Mach4, but also sold a parallel port board selected because
    of its suitability for CNC use.
    https://www.pmdx.com/
    https://www.pmdx.com/1PARPCI
    Craig
    Apr 2004
    5951
    If you need to drive a Gecko G540, I'd suggest using a UC100 motion controller/USB adapter. It's better than using the parallel port in a computer, since it has some trajectory planning abilities embedded in it, and generates a faster pulse stream. It will plug into the 25-pin Centronics connector on the G540 and a USB port on any Windows computer. Get it here: https://cnc4pc.com/uc100-usb-motion-controller.html
    Andrew Werby
    Website
    Dec 2024
    Computers and tablets from before or during the early 2000s may still have parallel ports. You could find these kinds of computers on online markets, at auctions, or from people who sell used goods. These ports are mostly no longer used because USB, Thunderbolt, scratch games and HDMI are better and faster.
