587,782 active members*
2,812 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Where to get metric bearings for ballscrew?
Results 1 to 5 of 5
    Jun 2004
    Question Where to get metric bearings for ballscrew?
    A while ago I bought through ebay a NSK ball screw. It didn't come with any bearings to mount it. So I went to bearingsdirect.com and ordered 2 thrust bearings and a mounted bearing. After not receiving the order for over 2 weeks I called them and asked what the hold up was. They said they were on back order and they did not know when they would be in. But they were kind enough to charge my credit card when I made the order. I asked them why they decided not to tell me that they hadn't shipped my order and to credit my card to cancel the order.
    So here I am still without bearings to mount my ball screw. Does anyone know where I can get thrust bearings with an internal diameter of 15mm besides bearingsdirect.com? I tried the usual places like MSCdirect and reidtool, but it seems they have mostly standard sizes.
    Apr 2003
    17
    Bearing source
    Why not use double row ball bearings to mount your lead screw. The 5200 or 5300 series would work for your application.
    I recommend baileynet.com, because they have excellent service. I remember ordering a set of open cage bearings and they were out of them, they upgraded to the sealed bearings for no extra cost.
    Jun 2004
    Thanks for the suggestion. baileynet's catalog indicated that the 5200 and 5300 double wall bearings are good for high thrust load, and they have them in the 15mm size I need. I will give them a try.
    Apr 2003
    17
    Bearing source
    Your welcome
    Jun 2004
    So I called baileynet.com to order the bearings. They were excellent to talk with. They didn't mind taking my super small volume order and were more than helpful over the phone. Keeping in mind that I just ordered from them today and haven't gotten my order yet, I give them an A+. I will post back when I get my bearings from them.
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-05-2024, 08:10 AM
  2. DRO - Metric or Inch
    By DJ Morrow in forum CNC Machine Related Electronics
    Last Post: 11-15-2004, 09:06 PM
  3. Metric vs Inch - arguements pro & con
    By DJ Morrow in forum Mini Lathe
    Last Post: 08-12-2004, 02:46 PM
  4. Are VXB.com bearings good?
    By Evilness in forum DIY CNC Router Table Machines
    Last Post: 07-16-2004, 05:39 AM
  5. router bearings
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 06-14-2003, 05:32 AM
