588,546 active members*
5,323 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Where are my splines?
    Apr 2005
    87
    Folks,
    I hoping someone out there can help me out. I just got a new copy of Solidworks Student Edition 2007-2008 and I'm having great difficulty in understanding where my splines are.
    If I select New/Part then choose front plane and then sketch, I should be all ready to go. Any of the other tools works fine (e.g. lines, rectangles, circles or whatever) but splines simply will not work. When I select splines, I do get the pencil cursor with the wavey spline looking line. When I click and drag, I get nothing. I have tried everything including re-installing the software and still no splines. The splines property box on the left side of the screen remains grayed out as if no spline have been drawn.
    Did I forget to enable something? Is there an option that is turned off by default that needs to be turned on?
    Also (maybe this is a clue) everytime I start Solidworks, I get a message that I have no license for COSMOS. I just haven't gotten it yet. Is this related at all?
    Please help before I go nuts!!!
    Thanks much,
    Joe
    Jan 2008
    5
    Hmm. COSMOS is just a FEA plugin for SW. To draw splines just click on the tool, select some misc points on the sketch then press "Esc".
    I have seen some PC's that don't have a good video card and can't work with SW, you could try opening some SW samples like parts or assemblies and see how it works. If it isn't a video card issue, i guess that you could try on another software (like SEdge or Rhino) or contact SW.
    Apr 2005
    87
    Hey d8432,
    Thanks for the reply. I did a lot of stuff to my PC like updating video drivers, uninstalling SW and cleaning out the registry. After re-installing SW I seem to have found my splines.
    Doing it the way I did, I have no idea what fixed it but I'm back in business.
    Again, thanks for the reply,
    Joe
  1. I can't get rid of splines!!
    By dan3676 in forum Uncategorised CAM Discussion
    Last Post: 09-21-2006, 03:57 PM
  2. Splines
    By spalm in forum SheetCam
    Last Post: 02-19-2006, 01:26 AM
  3. Splines
    By dneisler in forum MetalWork Discussion
    Last Post: 12-01-2005, 04:03 AM
  4. Help with splines
    By CNCRob in forum Autodesk
    Last Post: 09-03-2005, 09:14 PM
  5. Smoothing out splines ??
    By badRandle in forum Mastercam
    Last Post: 05-21-2003, 04:23 PM
