587,865 active members*
2,937 visitors online*
Results 1 to 6 of 6
    Sep 2003
    1475
    Question Where and Which
    I have started to cut misc. pieces with a 2 flute 1/4" bit, it works fine.
    I am using a 1.75 HP Porter Cable router with 1/4" and 1/2" collets.
    Now I am ready to get serious in some of my projects and I need some smaller Dia. bits at lease 1/8" or smaller in some instances.
    Who is a reasonably priced supplier and should I use carbide or HS bits as a hobbyist, not making 100's of parts.
    Hager
    Dec 2004
    84
    Apr 2005
    1778
    Quote Originally Posted by Mr.Chips View Post
    Should I use carbide or HS bits as a hobbyist, not making 100's of parts.
    Hager
    Hager,
    I would say definitely carbide, I find that I burn up HSS bits in no time at all.
    Alan
    Aug 2008
    53
    dhellew2
    Without question, use carbide. Just take care of them because they can chip. Sharpness life is about 50 to 1 so the price for carbide over their life is less than hss.
    Jan 2007
    117
    3/32 bits
    Go to Ebay and check out item # 130255753087. This seller has a number of these lots available. I purchased many of these and they work great on most hardwoods.
    Sep 2003
    1475
    Thank you all for your suggestions. I'll start checking them out.
    Hager
