603,870 active members*
2,726 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Which CAM software for 4 axis and mach3 support ?
Results 1 to 5 of 5
    Dec 2013
    11
    Hello, I'm using solidcam from some time and use the mach3 post processor included, but I wanted to use the 4 axis of my little machine when I understood that the post processor I used would do the trick, and there's no mach3 post processor for 4 axis and solidcam, then I ask you who know which software I can use to replace soldcam.
    Apr 2004
    5950
    Mecsoft has a version of their VisualMill software that plugs into Solidworks. The second-tier version supports the 4th axis, and has a Mach3 post processor. It lists for $2500, but we offer a discount.
    Andrew Werby
    computersculpture"dot"com
    Andrew Werby
    Website
    Feb 2011
    252
    Feb 2011
    252
    Feb 2011
    252
  1. What software; have Profili2 and 4-axis foam machine, need free driver like Mach3
    By Witsenburg in forum Uncategorised CAM Discussion
    Last Post: 02-22-2017, 08:59 PM
  2. USB support for Mach3
    By ger21 in forum Machines running Mach Software
    Last Post: 08-24-2013, 11:50 AM
  3. Replies: 4
    Last Post: 02-28-2011, 02:25 AM
  4. Looking for open source or free CAM software that support 4 axis machine
    By Nont in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-13-2010, 02:43 AM
  5. Cam software with 3-Axis undercut support
    By jrobson in forum Uncategorised CAM Discussion
    Last Post: 12-15-2009, 05:04 PM
