603,965 active members*
2,529 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > which format should I pick
Results 1 to 9 of 9
    Oct 2011
    Hi people.
    Maybe my question is too silly , but still I need an answer.
    I am in process of drawing models in ArtCam for mach3, so I made a toolpath and need to save it .Question is:
    which format should I pick from the list (Machine output file is formatted for)
    There are lots of format types there including :mach2 mm cnc (not mach3)
    will it be OK for mach3?or should I choose another format?
    thanks;
    Dec 2011
    59
    What version of Artcam are you using?
    The current post processors for Mach is Mach3gb_inch_ arc or Mach3gb_mm_arc" with both including an ATC versions
    these were updated to Mach3 in 2006 and have been adjusted as needed over the years.
    If you don't have these postp's in the list contact your reseller for them
    Gary
    Beckwith Decor Products
    ArtCam Reseller/Trainer, Custom tooling & Onsrud Dealer
    Oct 2011
    Thanks Garry
    I'll try my best
    will post later.
    Thanks again
    dito
    Oct 2011
    My soft is too old, It's artcam pro 8.1
    but it is full. my friend used to work with cnc router earlier
    so he gave me the software as I now intend to get familiar with all that cnc staff.( I already have mini cnc)
    so could you please explain, is there any other way to get the postprocessor Mach3gb mm arc?
    Dec 2011
    59
    do you have a dongle?
    Gary
    Oct 2011
    The program while installing asked for permission to install "sentinel protection installer" but I
    choose no.
    Dec 2011
    59
    So you have no sentinel security dongle? You are running an illegal copy of the program
    Sorry cannot help you unless you purchase a legit copy of ArtCam, the current version is 2011.
    Gary
    Oct 2011
    no I don't think it's illegal. as I said my friend gave me the CD with artcam
    it looks pretty legal.
    anyway thanks for your previous answers.
    Dec 2011
    59
    For it to be legal you must have the usb security dongle and associated paf file
    otherwise you have an illegal crack copy, which I would suggest you loose!
    Every legal seat of ArtCam has a registered owner via the # on the security dongle.
    Gary
  1. Trying to pick the right operation
    By murphmoose in forum Tormach Personal CNC Mill
    Last Post: 03-27-2011, 07:40 PM
  2. Need help with sub-spindle pick
    By Doolie in forum Okuma
    Last Post: 03-17-2011, 09:16 PM
  3. pick gaurd
    By corrie in forum Musical Instrument Design and Construction
    Last Post: 08-13-2010, 12:00 AM
  4. pick off on citizen f12
    By cseely in forum CNC Swiss Screw Machines
    Last Post: 01-09-2008, 06:13 PM
  5. Why did you pick your avatar?
    By WallCrawler in forum Community Club House
    Last Post: 10-20-2003, 01:53 PM
