586,262 active members*
3,343 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Which version of Windows will NCStudio work on?
Results 1 to 12 of 12
    May 2011
    104
    I'm about to build a computer to run my CNC machine that will be arriving soon but there is so little information out there on NCStudio that I wanted to check if anyone knew the answer?
    I have Windows 8 and Windows 7 I can install. I also assume the more memory and better the graphics card the better the machine will handle any of the software I'll be running?
    Also any other tips would be appreciated (and yes I may switch to Mach3 later but that's not the way I went to start).
    Chris
    Jan 2010
    19
    I am running it on Windows 8 with no issues.
    Cheers
    Ken
    May 2011
    104
    Thanks, that's good to know. Have it built and just need to do the installation.
    Feb 2014
    10
    Re: Which version of Windows will NCStudio work on?
    Quote Originally Posted by Dbl_Tap View Post
    Hey!
    Were you able to run NCStudio with Win7 x64?
    I have WinXP SP3 x86 but I want to switch to Win7 now.
    Max
    May 2011
    104
    Quote Originally Posted by MAVEN05 View Post
    Hey!
    Max
    I honestly don't remember what OS I was using when I had the issues with my machine and NCStudio but I will tell you the one that came with it was an illegal copy that was several years/generations old so I bet an actual licensed copy would work on Windows 7 or even 8.
    Feb 2014
    10
    I was able to run NcStudio on Windows 7 32 bit.
    It didn't work on Win7 64 bit because of some drivers were incompatible for the card didn't work but under 32 bit everything works just fine.
    Nov 2009
    314
    Well, XP no problem,most manufactures test machines with XP actually and XP is recommended for customer.
    Win7 32 bits also work on with actual license copy. 64bit is hard. Anybody here succeed by 64 bits here ?
    Best regards,
    Ms.Mary
    Feb 2014
    10
    Quote Originally Posted by EXLASer View Post
    Best regards,
    Ms.Mary
    You see Ms.Mary
    I already said that Win7 x86 everything works well.
    Was not able to run NcStudio on Win7 x64.
    So if you want to run NcStudio on Windows 7, you should have Windows 7 32bit (x86).
    I heard that NcStudio works also on Windows 8 but I have not tested that myself so i cannot tell anything from my own experience.
    Jul 2003
    168
    On the basis of a current extensive search, I conclude:
    * only 32-bit versions of Windows (Win 7, 8, etc. bear testing; 64-bit versions don't bother to test)
    * 64-bit Windows 7 does not even detect the PCI card
    * Windows 7 (for sure) and probably later "block" conventional install of INF driver files, but allow for "Legacy" install of hardware in Device Manager (right-click computer, add legacy hardware, find and select INF file--unsuccessful for me because my Win 7 is 64-bit)
    Incidentally,
    * no good to try installing, say, WinXP, and testing NCstudio install in a VirtualBox virtual machine in 32-bit RTAI version of Ubuntu (which LinuxCNC users will recognize as required for that app) because VirtualBox requires libraries incompatible with RTAI (interface to a PCI card and timing issues are likely to be problematic anyway from a VM)
    Dan
    Vornphe Guest
    Hi Ken,
    Could you please help to me to guide the setup in window 8?
    Thanks,
    Vorn
    Windows 7 32 bit is best now.
    Andy
    UnionTech CNC
    Jul 2021
    I have Windows 8 and Windows 7 I can install YoInstagram APK MOD . I also assume the more memory and better the graphics card the better the machine will handle any of the software I'll be running?
    Chris
    I'm running it on Windows 8 and 10 and never faced any issue.
  1. Ncstudio Upgraded Version V5.5.60 (ENGLISH)
    By EXLASer in forum Commercial CNC Wood Routers
    Last Post: 04-25-2019, 07:15 AM
  2. Replies: 0
    Last Post: 04-10-2012, 07:51 PM
  3. CNC Seron-1325 and NcStudio AD version 5.4.53 Engraving Software
    By clarenceassey in forum Chinese Machines
    Last Post: 04-10-2012, 07:45 PM
  4. Which version of Windows 7 with Rhino 3?
    By ddgman2001 in forum Rhino 3D
    Last Post: 08-06-2010, 09:43 AM
  5. Mastercam version 17 and windows 7
    By cncwhiz in forum Mastercam
    Last Post: 02-10-2010, 09:52 PM
