603,314 active members*
1,890 visitors online*
    Nov 2013
    52
    Which Wire Size to Use!
    I am about to start wiring up the components on my CNC refit. I'm going to use 18awg shielded tinned cable to my stepper motors. But as for wiring for the control boards and other components should I use 20 or 22 AWG?
    Re: Which Wire Size to Use!
    22AWG is more than enough for signal wiring. From memory it is rated to over 3A.
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com/store
    Nov 2013
    52
    Quote Originally Posted by phomann View Post
    Cheers
    Peter
    Thanks for your reply Peter,
    I was debating whether to buy some 20AWG, but I have some tinned 22AWG. So I will use that.
    Cheers
    Dave
  1. Via shape/size and wire size.
    By Drools in forum PCB milling
    Last Post: 08-14-2009, 03:47 PM
  2. Wire EDM - Wire Type and Size
    By greenchair in forum Uncategorised MetalWorking Machines
    Last Post: 06-17-2009, 07:44 PM
  3. G540 wire size?
    By bkboggy in forum Gecko Drives
    Last Post: 03-31-2009, 06:04 AM
  4. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
  5. Hookup wire size
    By Monte in forum Xylotex
    Last Post: 02-20-2005, 10:52 PM
