603,946 active members*
2,269 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Why isn't my gcode running??
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Oct 2007
    446
    Re: Why isn't my gcode running??
    ok...if all else fails i'll try an older version...
  2. #22
    Mar 2003
    35494
    Try the older version first. Seriously, 3.043.066 is garbage, and is not recommended.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  3. #23
    Oct 2007
    446
    newbie here...is there an easy way to keep all of my configs and settings i have already done? Can't remember off hand if there was an xml file or something for this. Other than maybe having to go through installing the uc100 stuff again....
  4. #24
    Mar 2003
    35494
    You shouldn't have to do anything but install the other version. Installing over the top doesn't normally change any settings.
    You can make a backup of your .xml, and should always have a backup. It's in the Mach3 folder, yourprofilename.xml
    Gerry
  5. #25
    Oct 2007
    446
    Okay...well thats painless then...i assumed i would have to uninstall the current version first....
  6. #26
    Jan 2011
    188
    Re: Mach3 2010 Screen set
    Quote Originally Posted by airbrush View Post
    Not sure why its not running...using mach 3. This line flashes red in the readout and then nothing...just sits there...
    (TOOL #1 0.25 1/4 2 Flute LOC 1.125)
    any ideas?
    comments always display in the message readout - that's normal
    the only way I can replicate that result is to undefine or disable the Z axis configuration - then it just stops on line N03
    I can't believe it's a screenset issue or that there's anything wrong with mach3 2010
    www.signtorch.com
  7. #27
    Oct 2007
    446
    will have to verify this...but seems like if i start mach and immediately load a gcode file then it works.
    This morning loaded up a file, zero'd everything cycle start..nothing. Close mach, load file, zero, worked fine....
  8. #28
    I've just done a test of a full install of the suggested older version over a working existing later version on a Windows 7 machine and can confirm that all settings and license are still in place and the machine works perfectly.
    I did back up the whole Mach3 folder plus screenshots of all config pages, as you should, but in this instance everything worked just fine.
    It's easy to be brave when you have a full clone of your PC sitting on the shelf ;-)
    - Nick
  9. #29
    Oct 2007
    446
    ok, great. If it becomes troublesome i will install. For now, its loading gcode right off the bat always works for me....
  10. #30
    Oct 2007
    446
    installed the older version as suggested...makes no difference...sometimes works sometimes doesn't....but if l start mach and immediately load my gcode works every time....
Page 2 of 2 12
  1. X3 Mill running mach 3-skipping steps during Gcode? not during jog
    By gonetowin in forum Mach Software (ArtSoft software)
    Last Post: 02-02-2015, 08:19 PM
  2. Precix running with Mach3 gcode, problem in edges and corners
    By FABLABBARCELONA in forum Commercial CNC Wood Routers
    Last Post: 12-29-2014, 05:49 PM
  3. Replies: 1
    Last Post: 05-28-2013, 04:25 AM
  4. Bridgeport Conversion (Which kit is best for just running imported gcode?)
    By ronderkis in forum Bridgeport / Hardinge Mills
    Last Post: 04-04-2013, 01:02 AM
  5. Running a gcode output file in the computer
    By Palafox in forum Uncategorised CAM Discussion
    Last Post: 06-10-2008, 11:56 PM
