603,326 active members*
3,194 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Why Laser Cutting Machine is the First Choice for Metal Sheet Processing?
    Jul 2021
    6
    Post Why Laser Cutting Machine is the First Choice for Metal Sheet Processing?
    As we all know, laser cutting machines have unique advantages in its range of application, service life, operating difficulty and regular maintenance compared with traditional metal forming equipment by the cutting convenience, easy operation and increasing popularity in global users.
    * Costs
    Laser cutting machines have extensive use in most industries. Decreasing many working procedures necessary for other traditional cutting machines, they are so economical and practical that these laser machines are widely regarded as “highly attractive in price and quality”.
    * Range of Application
    Laser cutting machines can process all kinds of metal sheets and tubes (with high enough configurations). This is what traditional cutting machines lack. Therefore, fiber laser cutter holds its monopoly position.
    * Service Life
    CNC laser cutting machine is perfect in workmanship and generally covered with baking varnish, as a result, rusting will be unlikely to happen and its service life is greatly prolonged. It can be said that the laser machine has satisfactory utilization rate.
    *Operating Method
    With light structure, the metal laser cutter is easy and convenient to be operated. All operators who have relevant mechanical knowledge can handle with it easily.
    * Regular Maintenance
    As a general rule, the sheet and tube metal laser cutting machine is split-type and easy to be maintained in daily life and while troubleshooting.
    Given that, laser cutting machines are widely applied in cutting various metal materials and have emerged as the favorite of large, medium and small-sized metal processing customers.
    Feb 2023
    Re: Why Laser Cutting Machine is the First Choice for Metal Sheet Processing?
    Speed and Accuracy
    Speed and accuracy are two of the fundamental components that determine the quality of metal sheet processing. With advancements in modern technology, laser cutting machines have become the preferred choice for metal sheet processing due to their unparalleled precision, speed and affordability. Laser cutting machines utilize advanced computer controls to accurately cut a wide range of metals with remarkable precision and speed. The machine’s laser beam is capable of slicing through thick steel plates with such precision that no additional finishing is needed on the final product. This makes them highly efficient, cost-effective and reliable when compared to other traditional methods of metal sheet processing. Laser cutting machines also reduce idle time as they can precisely cut complex shapes with ease, delivering incredible results in a fraction of the time required by manual or other conventional methods. These features make it an ideal solution for any organization looking for high-quality metal sheet processing solutions at competitive prices.
    Cost Efficiency
    It's no surprise that businesses are looking for the most cost-effective way to create quality products, and laser cutting machines could be the answer. Laser cutting machines are becoming increasingly popular for metal sheet processing due to their many advantages and affordability.
    Laser cutting machines offer a wide range of benefits, from precision accuracy and speed to high automation with minimal labor costs. The use of lasers can reduce material waste by up to 90%, which makes them very cost efficient compared to other methods of metal sheet processing such as plasma cutting or water jetting. Additionally, laser cutters can produce intricate designs with great detail, making them perfect for intricate parts that require precise measurements and cuts.
    Versatility
    The laser cutting machine is no exception and has become a popular choice for businesses looking to process metal sheets efficiently and effectively. A laser cutting machine uses a focused beam of light to cut through materials such as steel, aluminum, brass, copper and titanium with extreme precision. The results are smooth edges that require no additional finishing or polishing. This makes it the ideal option for businesses needing to quickly produce a large number of items in various shapes and sizes. What’s more, this versatile piece of machinery can be used on thin sheet metals as well as thicker plates up to 13 inches thick. With its ability to quickly process even the most intricate designs with accuracy and speed, the laser cutting machine is an invaluable asset for any business looking to save time and money while achieving superior results every time.
    Safety Considerations
    Laser cutting machines offer an efficient and precise way to cut materials with minimal waste, but there are some risks that need to be taken into account before deciding which type of machine is best for the job. Working with lasers can be hazardous due to the potential of eye and skin damage, as well as the risk of fire caused by misdirected beams. For this reason, it is essential that proper safety protocols and procedures are in place when using any type of laser cutting machine.
    It's important to ensure that all operators have been adequately trained on how to safely operate the laser cutter, including proper use of protective equipment such as goggles or face shields. Additionally, it's important to inspect the work area regularly for any potential hazards or obstructions which could cause accidents or damage the machine itself.
  1. Chinese laser which to choose metal sheet laser cutting machine
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-02-2015, 03:22 AM
  2. Metal laser cutting machine is easier to achieve diversification sheet metal
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-16-2014, 07:46 AM
