587,178 active members*
3,851 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > why my step motor can't step faster?
Results 1 to 4 of 4
    Jun 2008
    23
    I try to drive step motor manually using AVR and L298.
    for one full step, I use these sequence 1000, 0100, 0010, 0001.
    for every each of I only can put a delay 1ms or higher.
    less then 1ms, the stepmotor just "vibrate" on same position.
    can somebody help me with this
    1mS is 1,000 full-steps per second. That speed is beyond the motor's "pull-out" speed. The pull out speed is the maximum speed the motor can run at without acceleration.
    Mariss
    Mar 2008
    683
    Probably not what you want to hear
    I doubt you want to hear this.
    That's just the way steppers are. They are not fast moving motors. If you want high speed, servo motors are the way to go.
    in my shop... I use my stepper CNC (only one) for my intricate carving machine (my gun grips) and have my servo machines for the fast work.
    If you really need to step up (no pun intended) to a faster machine chances are you can get a servo drive upgrade for your machine.
    Jan 2005
    1695
    If you want more speed, you need to use a higher voltage power supply (ie: 30v or more)
  1. Step by step cnc plasma with parts list and links.
    By massajamesb in forum Waterjet General Topics
    Last Post: 07-09-2007, 04:22 AM
  2. My Solsylva CNC Router Step-By-Step
    By thkoutsidthebox in forum DIY CNC Router Table Machines
    Last Post: 03-31-2007, 01:06 AM
  3. TORQUE: FULL STEP vs half step
    By Glidergider in forum Stepper Motors / Drives
    Last Post: 02-27-2007, 09:02 PM
  4. step by step instruction for building controller
    By avengine in forum Community Club House
    Last Post: 04-21-2006, 01:24 PM
  5. Single Step/Half Step Question
    By Hawkeye in forum DIY CNC Router Table Machines
    Last Post: 11-20-2003, 05:28 PM
