603,964 active members*
1,759 visitors online*
Results 1 to 18 of 18
    Dec 2005
    141
    Why not a Gantry Setup??
    I am working on designing a new mill.... I was thinking about making a gantry setup..... What are the disadvantages to doing a gantry setup vs (what i am going to call) conventional setup.....
    BTW i would be cutting aluminum and some steel....
    Mike
    Jun 2008
    3
    A gantry set up will be significantly less rigid than the conventional column setup, and this will affect the tolerances of the product. Also with a gantry the motors have to move the very heavy spindle around, this means more expensive, powerful motors must be used and also more wear on the linear axis parts such as ballscrews and slides. In most cases for these benchtop cnc machines the product being cut out it much lighter that the spindle setup so it is logical that the stock is being moved not the spindle. Also the counter argument being that in conventional setups the spindle still has to travel up against gravity, however this can be overcome with a counterweight where as on counter weight can be used to offset spindle weight in a gantry setup.
    I hope this is helpful, but im an no expert, im still learning.
    Apr 2004
    5951
    How about a bridge design?
    That can be a lot more rigid than a gantry, since the beam carrying the Y and Z axes doesn't have to move along X. Instead, you move the table underneath it in the X directions. The main disadvantage is that it takes a bit more floor space, but it saves having to make a giant casting, which is the basis for most conventional mill designs.
    By the way, you can use a constant-force spring (think of a tape measure) instead of counterweights in a gantry (or bridge) design to help handle the weight of your spindle.
    Andrew Werby
    www.computersculpture.com
    Jun 2005
    98
    Pound for pound and cubic inch of workspace, a gantry will be SIGNIFICANTLY more ridgid than a conventional machine. The difference comes from the large moment arm attaching the spindle to the column of a conventional mill which is effectively eleminated by a gantry setup. But smaller conventional bench mills can be overbuilt to narrow the performance while not increasing the weight beyond what most hobbyists would consider a burden or excessive expense. For comparison sake lets consider the pros and cons of a gantry vs conventional mill assuming equivalent specs of ridgidity, work envelope and speed. Here's what I would expect to see in a gantry:
    • Lighter weight
    • Smaller machine footprint
    • Extra complexity (more parts to manufacture and align, possibly need second slaved drive to prevent "racking" on one axis)
    • Decreased accesibility of work envelope (everything must fit between gantry columns)
    I myself decided to go with the gantry for a metal working machine and am currently waiting on some money, space and shop access to fall into place before I go forward with the build. Tried to mitigate the cons as much as possible with this design but certainly isn't the only way to do a gantry.
    Apr 2004
    5951
    Quote Originally Posted by Zach_G View Post
    [Sure, but I think you're missing the point I was making. Yes, a thousand-pound gantry will be more rigid than a thousand-pound "C" column, but you don't have to push that C-column (or the equivalent bridge) around, or make it change direction and go the other way. With a gantry, every pound you add counts against you as inertia. You can make a C or a bridge as big and heavy as you want with no penalty, but this isn't the case for a gantry. To work, they have to be as light (but rigid) as possible.]
    • Lighter weight
    [You're correct there. I think that design (as pictured) suffers from the same problem as most gantries; it's overweight and under-rigid. Hanging everything on those big vertical moving members gives you moments of leverage that work against you. You're constructing a big rectangle that wants to be a parallelogram (or a series of them, depending on its mood). A design that eliminates those in favor of raised rails on the sides seems like a better bet to me - see the Mechmate design, which works that way.]
    Andrew Werby
    Dec 2005
    141
    a little more info on where i am comming from and my idea.....
    the mill that i am drafting right now is somewhat like Zach G's with a little different ways of moving the axis... the gantry does not move (this way i can weld or overly bolt the gantry to the base to help with flex) the spindle on the gantry moves left and right for the x axis and the whole gantry moved up and down (using to steppers to offset the weight) and then i have the table move front and back for the y axis... the way i look at it i am moving more differnt parts then the same part over and over again trying to help with ridgidy. (i will try and get a pic up so you guys see what i am talking about....)
    why i like the gantry setup over a column:
    with the column setup the table is supported in a small portion of the of the complete table (size of the saddle) making it so if you get a good amount of weight on the end of the table and extend it to its extent in anyone way there is a possiabliity of the table flexing up and down do to the weight being so far away from the support (the saddle)
    with a gantry (atleast my setup) the rails run the whole lenght of the machine (bigger then the table) so no matter where the table is on the machine it has the same support on the rails....
    also with the gantry setup you can have more cutting area in a smaller package.... (sounds weird right).... my machine is 30" wide (across the y axis) and i have 23.75" of cutting travel on the y... on a column mill (if you have a 8in saddle) your table would have to be 31.75 in wide... well you say 1.75" thats not a big different but a 8in saddle trying to hold a 31.75in table you are going to have a flex issue if not you machine tipping over.... to make it worth while you are going to need a 12-14in saddle to try and hold the weight of the table (if not even bigger) meaning your machine is now you have a 35-37" machine with the possibility of table flex...
    just my thoughs...... what do you guys think
    Mike
    Mar 2009
    296
    Quote Originally Posted by Hellbringer View Post
    Mike
    You can have a few inches more than that 23.75" of cutting travel if you have the table partially come out of the saddle but of course it becomes less rigid when you do that. Sometimes I wonder how well it would work out if you had casters on springs pushing on the floor on each end of the table, so you could have a table a mile long that wouldn't flex so much and wouldn't tip.
    Apr 2004
    5951
    If the gantry doesn't move, it's called a "bridge"
    [QUOTE=Hellbringer;635826]a little more info on where i am comming from and my idea.....
    [You're losing me when you're talking about the whole gantry moving up and down. I can't see why you'd want to do that; you lose rigidity, and you've got a lot more weight to move than if you simply moved the Z-axis back and forth and up and down, like most people do. What are you gaining this way? Maybe the picture will make more sense than what you're saying here...]
    Andrew Werby
    Jun 2005
    98
    Hey Hellbringer, what you have in mind is definitely the most ridgid setup possible. A fixed gantry or bridge mill with a supported table is certainly more stout than a moving gantry. The only reason I went with a moving gantry is to eliminate the extra support structure and to reduce the machine footprint, with a sacrifice for some ridgidity and an increased mass to accelerate, but I think my nema 34 steppers will be up to the task Correct me if I'm wrong but the attached picture is the axis setup you're going for.
    Depending on the dimensional configuration of your machine, I definitely agree that moving the entire Y axis along the Z is much better than having a Z column move along the Y (unless there's very limited Z travel) simply because having an extended Z column from the bridge will create a large moment. Might as well just do a conventional column mill at that point.
    Shun the nonbeliever, (awerby) for the metal cutting gantry cometh! That is assuming I ever get around to building the thing I might try and do a FEA comparison to see just how bendy it really is...
    Dec 2005
    141
    yes that is what i am working on i guess it is called a bridge mill (learn something new everyday)....
    thanks for the insight
    Mike
    Jan 2009
    237
    Stuff passes under a bridge
    A gantry passes over stuff.
    Call 'em what you like, and build 'em strong.
    both designs suffer two obstructions to the work.
    CalG
    May 2007
    781
    Many of the best high performance mills are bridges.
    One advantage is the mass being moved by the X and Y servos is closer to the same then any other configuration. That helps to make nice round circles at speed.
    And if the Z is just a ram then it can move very fast which is nice for high speed hard milling where you tend to get lots of very small cuts were the Z is moving up to a safe level when repositioning for the next pass.
    Mar 2009
    178
    im getting started on building a 5 axis gantry, im just tryin to get a finalized design done, so i can put it in solid works and start having things cut.
    Aug 2005
    231
    I'm pretty much planning on the same thing... Moving plate for Y axis, entire gantry / bridge with Z and X axis moving up and down.
    Reasons being:
    1) need to fit into 3'x4' enclosure. (apartment machine) This gives me 32"x15"x9" travel using Thomson pre-made linear slides that I have.
    2) sick of having a column in the way on either my Taig or the Grizzly at work. I have 9" Y travel on my Taig now, and can't use it all because I run into the column. As it is, I have (2) 1" spacer blocks hanging my spindle way out. <- not good!
    3) if I move the bridge up and down instead of just the Z slide, I get my whole 9" of travel, unobstructed. If I hang my spindle off the moving plate of the slide instead, when it's all the way up and I have a tall part on there I'll hit the non-moving part of the slide that's hanging down. This way everything moves up and clears the whole workspace. Also hanging Z axis slide isn't taking the entire cutting force in X and Y directions, the bridge is.. Just seems to be more supported...
    drawbacks:
    1) I have the 2 big vertical members (towards the back) that I can still hit. Better than 1 central column in the way as I can get most things between them (~40" apart)..
    2) lots of weight / mass moving up and down. I use a 30# gas strut on my Taig to neutrally balance the Z axis, and I intend to do the same on the bridge. That takes care of the weight for the steppers, but doesn't the inertia (or something?) still cause a problem with rapid up/down?
    3) Lots of aluminum. I already have 3 sections of 3060 (3"x6") 8020 aluminum extrusions for the uprights and the bridge. (my boss built a machine with a 6' gantry using a 3060 beam, with a 5HP spindle and Z axis hanging on it. Said it had almost no deflection. Woo! His had a 2.5" thick steel slab as a base though, slightly more stable...)
    4) As drawn now, my spindle center is about 11" away from the edge of the upright supports. That's 2" for the Z axis slides (will have 2) which carry the 3" thick gantry, then 2" more for the X axis slide on the gantry, plus some mount plates. *NO* idea if / how much this will flex / have play. The Thomson slides are great, but that's a lot of stuff hanging out there.
    I like the picture of that ancient green machine! At least that proves the concept is valid. Of course that's probably 3000lbs of cast iron instead of a couple hundred lbs of aluminum..... But still... Glimmer of hope.
    As for other details, I plan on making the lower frame / base from 1030 extrusions (1"x3"), with a layer of 1/4" aluminum over a bed of the 1030 pieces. Then the 3060 uprights will bolt to the 1030 rails towards the back, with a "T" plate bolted down the side of them for extra holding. The machining surface will be .5" aluminum plate on top of a bed of 1030 extrusions, mounted to my Y axis slide plate in the center. The left and right ends will be supported by more linear rails, for a total of 4 rail supports in the Y direction.
    I've been planning this for a long time now, without building much. Every time I find a bigger Thomson Superslide on eBay my design gets bigger / more complex. It started as 9"x9"x9". LOL Finally bought the huge 3060 sticks last week. I knew they were big, but WOW are they big.
    I'll be following the thread for progress. I doubt I'll be making much for a while.
    Dec 2008
    445
    Quote Originally Posted by Riceburner98 View Post
    Reasons being:
    drawbacks:
    Just be aware, depending on which extrusions you get, they are not flat across a surface. The "official" 8020 ones have a 2 degree taper towards the slot, which deflects when you tighten something into the slot. It makes sense for the purpose for which it was intended, and can be compensated for if you plan for it.
    I'm also on a similar idea for my next machine, a 5 axis gantry setup, prolly use a nice surface plate as a base, possibly some filled 3060's for uprights.
    Aug 2005
    231
    Yep, the plan is to mount 1/2" plates to the extrusions then mount to those. Maybe have them skimmed after being bolted down if I get that into it. I see a lot of people (my boss included) just mounting their linear bearings right to the 8020 slots, but wondered how they deal with the taper. My boss used their "blank" T-nut material (6' long) and drilled / tapped holes for the linear bearing. That way the entire T slot was filled with a long nut.
    I was thinking of filling the 3060, but didn't know if it would be really necessary... I thought about turning it into a 5 axis machine with one of those nice tiny NSK spindles, but then realized that would be totally overkill. That, and the 5 axis software would pop a blood vessel or something. I can barely keep 3 axis straight.
  17. #17
    Dec 2008
    445
    Even if you don't use it as 5 axis simultaneous, it sure would be nice to just tip the spindle over and do the sides of the part without rechucking. Sure, a 4th axis (which will be added to the regular mill soon) will allow for a bit of that, but if you're gonna start tipping the head, might as well give it both.
  18. #18
    Aug 2005
    231
    Hey now, don't go giving me any more ideas!
  1. flying gantry: 4 motors/3 axis setup
    By nicanor76 in forum Uncategorised WoodWorking Machines
    Last Post: 04-13-2011, 07:24 PM
  2. Gantry
    By alexis221 in forum DIY CNC Router Table Machines
    Last Post: 11-10-2007, 04:17 PM
  3. gantry
    By posix in forum Linear and Rotary Motion
    Last Post: 01-14-2006, 11:57 AM
  4. gantry
    By MBG in forum MetalWork Discussion
    Last Post: 08-18-2005, 01:53 AM
