if and or when you do get shop air supply... go to your local chepo tools place, (i like hargor freight) or whereever you can find a short air snoozel.. er nozel, the one with a hole or holes in the side and stick a small tube in the side of it.. you can play with the placement of the tube till you get the amount of liquid you want.. i use ths setup on one of my lates.. i have a 5 gallon bucket under the lathe bench and it will draw the coolant up the 3 or so feet and then mists the part... works well but be carefull of the mist vapors.. your atomizing a liquid, so it better be something your willing to breathe....it works kinda the way a cheap sand blaster works.. air goes through and sucks up the sand... its cheap and works really well.. but does require some fiddeling with to get the air supply pressure and volume set up.. there is probably a commercially avilable version of this... but im a cheapskate...i also use a fish tank valve on the liquid line to control the flow of coolant...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
