603,945 active members*
4,179 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
Page 51 of 90 41495051525361
Results 1,001 to 1,020 of 1804
Hybrid View
widgitmaster WidgitMaster's Largest Steel... 06-08-2013, 11:57 PM
widgitmaster Today I started milling the... 06-09-2013, 12:07 AM
gmfoster Great to see you back in... 06-09-2013, 12:10 AM
LeeWay Ditto. Looks like this one... 06-09-2013, 12:21 AM
widgitmaster Thanks guys! It's good to be... 06-09-2013, 12:32 AM
CarveOne Welcome back widgitmaster!! ... 06-09-2013, 12:33 AM
widgitmaster Howdy Carv'e! Thanks for the... 06-10-2013, 02:57 PM
CarveOne I spoke before reading the... 06-11-2013, 02:19 AM
CarveOne I can't help with the servo... 06-22-2013, 02:28 AM
Bubba Like an old friend showing... 06-09-2013, 12:36 AM
TOTALLYRC Hi widgit Great to see you... 06-09-2013, 01:26 AM
ViperTX Welcome back Eric...it is... 06-10-2013, 05:20 AM
widgitmaster I've been busy all weekend... 06-10-2013, 03:06 PM
kuroguy typing in e-chain at grainger... 06-10-2013, 07:18 PM
widgitmaster OOPS! It's actually an... 06-10-2013, 10:29 PM
LeeWay This is where I got mine... 06-10-2013, 07:39 PM
widgitmaster This has been a busy day!... 06-10-2013, 10:33 PM
widgitmaster Today I worked on the Gantry... 06-11-2013, 08:14 PM
widgitmaster Then I band sawed a 45 deg on... 06-11-2013, 08:21 PM
widgitmaster Next I milled the Long Y-Axis... 06-11-2013, 08:28 PM
epineh Great to see you back in... 06-12-2013, 10:56 AM
Jason Marsha Welcome back widgitmaster!... 06-12-2013, 12:00 PM
widgitmaster Thanks Guys! Today I'm... 06-12-2013, 05:58 PM
widgitmaster Next, I milled one end of all... 06-12-2013, 06:08 PM
widgitmaster Now that all six tubes are... 06-12-2013, 06:13 PM
widgitmaster Today I band sawed a 45 Deg... 06-14-2013, 09:37 PM
Jason Marsha Great work. I would have... 06-14-2013, 10:49 PM
widgitmaster Hi Jason! The last six tubes... 06-15-2013, 02:51 AM
ger21 You're probably going to want... 06-15-2013, 03:03 AM
bhurts You may want to look into the... 06-15-2013, 07:23 AM
Jason Marsha Wow 1/4" inch sidewall, that... 06-15-2013, 11:25 AM
widgitmaster Hi Gerry Thanks for the... 06-15-2013, 01:45 PM
widgitmaster Today I finished drilling the... 06-15-2013, 08:53 PM
widgitmaster Next I made the base plates... 06-15-2013, 08:59 PM
fuper Hello Widgitmaster, May I... 06-21-2013, 11:07 PM
widgitmaster I bought the Bridgeport type... 06-22-2013, 01:57 AM
widgitmaster Question, Can anyone help me... 06-22-2013, 02:11 AM
Jzarski Well it looks like its about... 06-15-2013, 09:17 PM
widgitmaster The shrimp dinner was... 06-16-2013, 01:54 AM
ZipSnipe Oh hell yes, Welcome back... 06-16-2013, 02:32 AM
widgitmaster ZipSnipe! That's a name I... 06-16-2013, 03:19 AM
widgitmaster The welder called me around... 06-16-2013, 09:51 PM
Dylwad Looks good, you made it too... 06-16-2013, 11:37 PM
widgitmaster Not too worried about... 06-16-2013, 11:43 PM
widgitmaster After the welder dropped of... 06-17-2013, 12:44 AM
bill south Welcome Back Widgit! Glad to... 06-17-2013, 04:07 PM
widgitmaster It's good to see your still... 06-18-2013, 12:06 AM
widgitmaster Got a late start today, only... 06-18-2013, 12:05 AM
widgitmaster I took a break yesterday, and... 06-19-2013, 06:34 PM
CarveOne I can almost guarantee that... 06-30-2013, 01:27 AM
widgitmaster Your probably right Carv'e :)... 06-30-2013, 07:06 PM
Jason Marsha Looking good widgitmaster. ... 06-20-2013, 01:05 PM
widgitmaster Hi Jason, YES, I used a... 06-20-2013, 03:25 PM
harryn I am impressed that you were... 06-20-2013, 07:11 PM
widgitmaster Hi Harry! Actually I bought... 06-20-2013, 09:20 PM
lancut Hi Widgit, As retired tool &... 06-21-2013, 01:21 AM
widgitmaster Thanks! Tomorrow I'm going... 06-21-2013, 03:54 AM
widgitmaster I was a little irritated this... 06-21-2013, 02:53 PM
Dylwad Definitely need reduction on... 06-22-2013, 02:44 AM
widgitmaster So far I have located the... 06-22-2013, 05:45 AM
widgitmaster As for the AC Servos, I don't... 06-22-2013, 05:55 AM
Dylwad A/C servos don't need as... 06-22-2013, 06:24 AM
dsquire Eric It's been a while... 06-22-2013, 06:32 AM
Bubba Widgit, Using the above info... 06-22-2013, 01:10 PM
widgitmaster Hi Don! Its good to see your... 06-22-2013, 04:35 PM
ger21 If you want to go the... 06-22-2013, 05:20 PM
Dylwad Im still intrigued by this... 06-22-2013, 06:43 PM
widgitmaster I have been working on the... 06-22-2013, 08:56 PM
widgitmaster Ok, I'm getting a handle on... 06-22-2013, 08:43 PM
Bubba Eric, If your going to add... 06-22-2013, 09:10 PM
Dylwad Adding encoders to gecko... 06-22-2013, 09:27 PM
Dylwad More info from leadshine... 06-22-2013, 09:49 PM
CarveOne I can already tell that you... 07-07-2013, 12:49 AM
ger21 960 oz motors should be more... 06-22-2013, 11:47 PM
widgitmaster Thanks Gerry! It will be... 06-23-2013, 03:13 AM
TOTALLYRC I agree with Gerry. I am not... 06-23-2013, 11:00 AM
rustamd Awesome new build! 06-24-2013, 04:16 AM
widgitmaster Thanks Russ! 06-24-2013, 04:19 AM
widgitmaster This afternoon I made a... 06-25-2013, 02:00 AM
widgitmaster This morning I made the 4 end... 06-25-2013, 07:17 PM
widgitmaster All the liner rails have... 06-25-2013, 07:32 PM
bhurts I didn't see what size pinion... 06-25-2013, 11:42 PM
widgitmaster This morning I started on the... 06-26-2013, 11:40 PM
widgitmaster Milling the base, or the 3rd... 06-26-2013, 11:54 PM
widgitmaster Its getting late, and I'm... 06-27-2013, 12:05 AM
widgitmaster Just a little progress today!... 06-28-2013, 05:34 AM
CarveOne You can see what has been... 07-10-2013, 11:32 AM
widgitmaster Last week I bid on a large... 06-29-2013, 11:47 PM
bill south Hey Widgit! That's the box... 07-01-2013, 03:34 PM
widgitmaster How's it going Bill ! I do... 07-02-2013, 08:37 PM
widgitmaster This morning I cleaned the... 07-02-2013, 08:46 PM
widgitmaster While I have the mill setup... 07-02-2013, 08:53 PM
widgitmaster Now for the moment of truth,... 07-02-2013, 09:00 PM
jalessi Eric, Good to see you back... 07-02-2013, 09:18 PM
widgitmaster Hi Jeff, Long Time No Chat!... 07-02-2013, 09:36 PM
widgitmaster Well, it looks like it's... 07-02-2013, 09:59 PM
widgitmaster Today I used a 2-ton screw... 07-03-2013, 03:10 PM
widgitmaster Next I setup the mill to... 07-03-2013, 10:34 PM
widgitmaster After milling the tubes to... 07-03-2013, 10:40 PM
pippin88 Very nice work. Are you... 07-04-2013, 01:20 AM
widgitmaster Yes, I have some angle iron... 07-04-2013, 01:47 AM
widgitmaster Happy 4th of July everyone! ... 07-04-2013, 07:07 PM
widgitmaster All that's left is cutting... 07-04-2013, 07:13 PM
rustamd Different lathe? Or just took... 07-04-2013, 08:00 PM
widgitmaster Hey Rustamd, How's it going?... 07-04-2013, 08:06 PM
widgitmaster This morning I started... 07-05-2013, 09:00 PM
widgitmaster Next I setup the lathe to... 07-05-2013, 09:04 PM
widgitmaster with the rails spliced with... 07-05-2013, 09:24 PM
Jzarski I think this is a good place... 07-08-2013, 02:04 AM
TOTALLYRC Nice work Widgit, Mike 07-06-2013, 11:34 AM
widgitmaster Thanks Mike! This... 07-06-2013, 07:21 PM
widgitmaster Now that the beams are done,... 07-06-2013, 07:29 PM
pippin88 One comment (that may come... 07-07-2013, 09:08 AM
widgitmaster I have increased the z-axis... 07-07-2013, 01:56 PM
widgitmaster As for the uplift you guys... 07-07-2013, 03:01 PM
ger21 Which is how all his X and Y... 07-07-2013, 12:36 PM
LeeWay I don't get any uplift in... 07-07-2013, 02:07 PM
widgitmaster Just for the record, here are... 07-07-2013, 02:27 PM
Jason Marsha Well said Eric. I will take... 07-07-2013, 06:11 PM
widgitmaster WOW, thanks Zarski! 07-08-2013, 05:40 AM
widgitmaster I have been unable to log on... 07-10-2013, 03:44 AM
fuper Hey Widgitmaster - I'm... 07-10-2013, 04:55 AM
Dylwad http://www.cnczone.com/forums/... 07-10-2013, 04:10 AM
LeeWay I had to clear my cache and... 07-10-2013, 12:15 PM
widgitmaster WOW, That must have been a... 07-11-2013, 01:20 PM
widgitmaster While CNCZone was down, I... 07-11-2013, 02:11 PM
widgitmaster Nothing new to post, as I'm... 07-13-2013, 02:43 AM
Bubba Widget, IT's Friday and you... 07-13-2013, 02:47 AM
CarveOne widgetmaster said - "I was... 07-24-2013, 08:27 PM
widgitmaster (chair) Sounds good to me... 07-24-2013, 09:06 PM
CarveOne You need to go to Harbor... 08-10-2013, 10:16 PM
widgitmaster Good News! The welder arrived... 07-14-2013, 03:24 AM
Dylwad Mach3 can't close the loop... 07-14-2013, 05:24 AM
Dylwad Found this... 07-14-2013, 05:30 AM
bhurts You can look into the k-flop... 07-14-2013, 07:19 AM
widgitmaster Now that is disappointing, I... 07-14-2013, 10:26 PM
aarggh Sorry in advance, I don't... 07-15-2013, 11:14 PM
Dylwad They are magnetized after... 07-15-2013, 11:49 PM
aarggh Thanks for the link, very... 07-15-2013, 11:59 PM
widgitmaster A little progress today! ... 07-16-2013, 01:38 AM
widgitmaster This morning I started... 07-16-2013, 10:26 PM
widgitmaster The guys at the Air Boat shop... 07-16-2013, 10:33 PM
CarveOne Sweet... Wish I could... 07-17-2013, 12:42 AM
bill south Hey Widgit! Nice Tank! The... 07-17-2013, 01:36 PM
widgitmaster Hi Bill! The tank was... 07-17-2013, 07:12 PM
the4thseal Like your... 07-17-2013, 08:00 PM
CarveOne Hey! That's my new welding... 08-05-2013, 11:38 PM
widgitmaster Wow! Thanks! This morning... 07-17-2013, 10:32 PM
widgitmaster The welder just dropped off... 07-17-2013, 11:55 PM
the4thseal Why do you have three trucks... 07-18-2013, 01:04 AM
widgitmaster Actually I've been waiting... 07-18-2013, 02:01 AM
lancut Hi Widgit. Here I'm sitting... 07-18-2013, 01:34 AM
widgitmaster Yes, the KURT vises are... 07-18-2013, 02:06 AM
the4thseal 1000ipm...wow. Not saying... 07-18-2013, 07:10 PM
widgitmaster with the long tube back from... 07-18-2013, 08:26 PM
widgitmaster Now that the cutter length is... 07-18-2013, 08:40 PM
Dylwad Very nice :) One thing... 07-18-2013, 08:53 PM
widgitmaster We definitely went to... 07-18-2013, 11:34 PM
widgitmaster This morning I finished... 07-19-2013, 08:24 PM
widgitmaster Today I finished milling the... 07-20-2013, 11:42 PM
Jason Marsha Its good you a welder, I... 07-21-2013, 12:16 PM
widgitmaster Hi Jason! NO, I'm not a... 07-21-2013, 01:41 PM
LeeWay Good welder's usually are... 07-21-2013, 01:51 PM
widgitmaster Today, I started working on... 07-21-2013, 09:35 PM
CarveOne I never had one. It's hard... 08-09-2013, 12:09 PM
widgitmaster Next, I started on the long... 07-21-2013, 09:57 PM
widgitmaster With the gears done, I moved... 07-21-2013, 10:01 PM
widgitmaster Today I worked on the lower... 07-23-2013, 01:10 AM
widgitmaster Next, I removed the hard vise... 07-23-2013, 01:16 AM
widgitmaster Today I finished the big... 07-23-2013, 04:13 PM
widgitmaster While waiting for the welder,... 07-23-2013, 08:36 PM
widgitmaster This morning, I started on... 07-24-2013, 07:35 PM
Jason Marsha Are you ok Eric, six days and... 07-31-2013, 12:41 PM
widgitmaster Thanks for checking Bro! I'm... 07-31-2013, 03:03 PM
bill south Eric; Your design or someone... 07-31-2013, 06:46 PM
widgitmaster Hey Bill! Yes, its my... 07-31-2013, 08:44 PM
LeeWay Wow. That's 5 different... 07-31-2013, 09:00 PM
widgitmaster Hi Lee! Yea, i edited &... 07-31-2013, 09:08 PM
widgitmaster Well, I got allot... 08-01-2013, 09:02 PM
widgitmaster Now I have to flip the tank... 08-01-2013, 09:12 PM
widgitmaster After a quick trip to the... 08-01-2013, 11:37 PM
widgitmaster Now for the good news! I... 08-01-2013, 11:40 PM
bill south Good to see you back in the... 08-02-2013, 01:31 PM
widgitmaster Hi Bill! Actually, this... 08-02-2013, 07:07 PM
widgitmaster Finally! I found a good... 08-05-2013, 05:51 PM
aarggh Man I'm loving this thread... 08-06-2013, 01:11 AM
widgitmaster Hi Ian! No actually! But I... 08-06-2013, 01:56 AM
widgitmaster Wow, I got allot accomplished... 08-06-2013, 08:29 PM
jalessi Eric, You might like... 08-06-2013, 09:08 PM
lancut It does looks good and solid.... 08-06-2013, 09:28 PM
widgitmaster Nice caster idea Jeff! Ill... 08-06-2013, 11:29 PM
widgitmaster This morning I jacked up the... 08-07-2013, 07:40 PM
widgitmaster Next, I removed the... 08-07-2013, 07:51 PM
widgitmaster Next, I placed the plate on... 08-07-2013, 08:02 PM
widgitmaster One last setup for today,... 08-07-2013, 08:08 PM
CNCfun&games Widgit, Great thread!!... 08-08-2013, 04:11 PM
widgitmaster WOW! Thanks for the kind... 08-08-2013, 06:31 PM
widgitmaster I decided to go ahead with... 08-08-2013, 10:17 PM
widgitmaster Next, I removed the truck... 08-08-2013, 10:29 PM
CarveOne This is no worse than having... 08-09-2013, 01:46 AM
widgitmaster Long Live the VW Beetle ! I... 08-09-2013, 04:26 AM
Miata2k As I watch this thread, I... 08-09-2013, 05:20 PM
widgitmaster :) This morning I placed... 08-09-2013, 06:54 PM
widgitmaster Now for some fun stuff! I... 08-09-2013, 07:12 PM
widgitmaster The .875" diam post will have... 08-09-2013, 07:21 PM
widgitmaster Today I started making the 2"... 08-10-2013, 09:13 PM
widgitmaster Now its time to work on the... 08-10-2013, 09:24 PM
widgitmaster Next, I removed the angle... 08-10-2013, 09:36 PM
widgitmaster Now that the weldment is... 08-10-2013, 09:52 PM
Dylwad IMO that large of a screw... 08-10-2013, 10:35 PM
widgitmaster Problem Solved! Just bought a... 08-10-2013, 10:42 PM
kuroguy Or two more follow-up... 08-10-2013, 11:12 PM
widgitmaster I'd have to buy a bigger... 08-11-2013, 08:24 PM
CarveOne My bad... I thought you were... 08-11-2013, 09:42 PM
KTP I have an 8 foot long 2 inch... 08-11-2013, 10:16 PM
widgitmaster 2 inch diameter huh! Does it... 08-11-2013, 10:52 PM
widgitmaster Today I started working on... 08-12-2013, 07:12 PM
widgitmaster This morning I put two small... 08-14-2013, 01:20 AM
widgitmaster With the sides machined &... 08-14-2013, 01:27 AM
widgitmaster Now I have to mill a radius... 08-14-2013, 01:40 AM
widgitmaster Now its time to drill all the... 08-14-2013, 01:46 AM
widgitmaster With the ends of the weldment... 08-14-2013, 01:56 AM
widgitmaster With the machining of the... 08-14-2013, 02:04 AM
widgitmaster This morning I finished up... 08-14-2013, 07:16 PM
bill south Wow Eric; Looks like... 08-14-2013, 07:32 PM
widgitmaster You got it Bill :-) 08-14-2013, 10:02 PM
CarveOne I dunno Eric, there is a... 08-28-2013, 11:09 PM
widgitmaster Not sure if anyone realizes... 08-15-2013, 12:05 AM
widgitmaster All morning I've been... 08-15-2013, 10:43 PM
aarggh Eric, a question about those... 08-16-2013, 11:04 AM
widgitmaster Hi Ian, Actually, I have an... 08-16-2013, 01:47 PM
widgitmaster This morning I worked on the... 08-16-2013, 10:07 PM
widgitmaster So what do you think of the... 08-16-2013, 10:17 PM
LeeWay I powder coated some parts of... 08-16-2013, 10:21 PM
widgitmaster Thanks Lee! Today I... 08-17-2013, 10:09 PM
widgitmaster Today I worked on the Z-Axis... 08-18-2013, 07:54 PM
widgitmaster In order to straighten the... 08-18-2013, 08:12 PM
nlancaster neet solution for the z-limit... 08-21-2013, 02:09 AM
widgitmaster Thanks! Today I looked at... 08-21-2013, 03:09 AM
nlancaster Over the years of lurking... 08-21-2013, 11:58 PM
widgitmaster Thanks! The long screws &... 08-22-2013, 02:21 PM
bill south Looking Good Eric; Isn't the... 08-22-2013, 06:28 PM
jckstrthmghty The superman build? 08-22-2013, 08:22 PM
widgitmaster Hi Yall! Today the last... 08-22-2013, 08:58 PM
Miata2k Widgit, I have to go to... 08-23-2013, 03:26 PM
widgitmaster I have a 2.2Kw Spindle &... 08-23-2013, 06:46 PM
widgitmaster The parts are back from the... 08-23-2013, 12:58 AM
widgitmaster This morning I started... 08-23-2013, 06:49 PM
widgitmaster The 1st parts I plan to make... 08-23-2013, 07:05 PM
keebler303 Widgit I think you are... 08-23-2013, 07:10 PM
widgitmaster Every chart I look at & every... 08-23-2013, 07:29 PM
Miata2k Widgit, There is nothing... 08-23-2013, 08:18 PM
keebler303 Use the size you want, the... 08-23-2013, 08:35 PM
CarveOne Widgit, looks like you and I... 09-03-2013, 01:11 AM
widgitmaster Thanks Carv'e, Like I said:... 09-03-2013, 02:14 AM
Dylwad I'll agree that 16 gauge... 08-23-2013, 07:25 PM
kuroguy You also want to make sure... 08-24-2013, 02:19 AM
widgitmaster This is from th Inverter's... 08-24-2013, 03:58 AM
CarveOne Lots of laughs, that's my... 09-03-2013, 11:33 AM
widgitmaster This morning I started on the... 08-26-2013, 06:33 PM
widgitmaster Then I inked up the two... 08-26-2013, 06:51 PM
Miata2k Widgit, I just have a... 08-27-2013, 04:44 PM
widgitmaster Because steel is so much... 08-27-2013, 11:10 PM
kuroguy As an engineer, every part... 08-27-2013, 04:55 PM
keebler303 As another engineer, you... 08-27-2013, 05:32 PM
widgitmaster Wow! I've been busy all day... 08-27-2013, 08:25 PM
widgitmaster Then I setup to mill a pocket... 08-27-2013, 08:32 PM
widgitmaster This morning I drilled &... 08-28-2013, 06:33 PM
widgitmaster Now the screw slots are off... 08-28-2013, 06:42 PM
bill south Widgit; Did you ever decide... 08-29-2013, 02:41 PM
widgitmaster Hi Bill, So far it looks... 08-29-2013, 03:00 PM
alan_3301 I don't know if you can get... 08-29-2013, 11:32 PM
keebler303 Are you in the US? I'm... 08-29-2013, 06:33 PM
widgitmaster Thanks Matt, I'll check into... 08-29-2013, 09:59 PM
widgitmaster Now its time to service my... 08-29-2013, 10:10 PM
widgitmaster Now I can setup the rotary... 08-29-2013, 10:14 PM
CarveOne You will probably need a... 08-30-2013, 01:14 AM
widgitmaster Naah... I rarely ever put a... 08-30-2013, 07:19 PM
widgitmaster The box for the VFD Inverter... 08-30-2013, 07:34 PM
kuroguy Good call on the fans. The... 08-30-2013, 08:22 PM
widgitmaster Thanks for the offer! I... 08-30-2013, 10:43 PM
widgitmaster I got my hands on a nice... 09-06-2013, 08:12 PM
CarveOne My work shop is the... 09-11-2013, 03:36 PM
LeeWay The worst part about this... 08-30-2013, 10:04 PM
widgitmaster :rolleyes: My friend with... 08-30-2013, 10:11 PM
kuroguy Bear in mind that those types... 08-30-2013, 10:49 PM
Dylwad FWIW my VFD is mounted in... 08-30-2013, 10:54 PM
CarveOne Then I"m sure that you... 09-11-2013, 08:39 PM
keebler303 I thought it looked pretty... 09-11-2013, 08:50 PM
kuroguy That's because it is rated... 08-31-2013, 12:54 AM
widgitmaster Geez! One post makes me... 08-31-2013, 01:00 AM
CarveOne I have trouble even making 2"... 09-11-2013, 10:59 PM
aarggh The best muffin fans I've... 08-31-2013, 01:53 AM
Dylwad Great if you can tolerate the... 08-31-2013, 02:11 AM
kuroguy I've got some time on my... 08-31-2013, 02:15 AM
widgitmaster I really do appreciate your... 08-31-2013, 03:23 AM
widgitmaster Today I started on the bronze... 08-31-2013, 09:24 PM
widgitmaster This morning I played in the... 09-02-2013, 08:06 PM
widgitmaster Next I clamped a big parallel... 09-02-2013, 08:13 PM
widgitmaster With the plate milled, I... 09-02-2013, 08:19 PM
widgitmaster Ditto! This morning, I... 09-03-2013, 05:12 PM
widgitmaster Now its time for some lathe... 09-03-2013, 05:21 PM
widgitmaster Now I can assemble the parts... 09-03-2013, 05:28 PM
widgitmaster The parts are back from the... 09-03-2013, 11:22 PM
widgitmaster Today I worked on the x-axis... 09-05-2013, 10:01 PM
widgitmaster Next I put the vise on the... 09-05-2013, 10:10 PM
widgitmaster Today I started making the... 09-06-2013, 07:26 PM
widgitmaster The end I'm turning, is for... 09-06-2013, 07:37 PM
widgitmaster In order to do the other end,... 09-06-2013, 07:55 PM
widgitmaster Today, I finished the x-axis... 09-07-2013, 08:24 PM
widgitmaster Now for a little fun! I have... 09-07-2013, 08:39 PM
widgitmaster Now I can setup the lathe to... 09-07-2013, 08:47 PM
widgitmaster Today I made the sprockets... 09-08-2013, 08:11 PM
widgitmaster Now I can make the forks... 09-08-2013, 08:33 PM
widgitmaster Did allot of running around... 09-09-2013, 07:30 PM
widgitmaster Now that I have the outer... 09-10-2013, 05:51 PM
widgitmaster Now I can put the partial... 09-10-2013, 05:55 PM
bill south Widgit; Yup, it's coming... 09-10-2013, 07:01 PM
kuroguy I'd imagine after spending so... 09-10-2013, 07:04 PM
widgitmaster NEVER FORGET 09-11-2013, 01:27 PM
widgitmaster :) This morning I put the... 09-11-2013, 07:28 PM
widgitmaster Next, I removed the X-Slide... 09-11-2013, 07:36 PM
widgitmaster Before I stop for lunch, I... 09-11-2013, 07:43 PM
widgitmaster After lunch, I stopped by the... 09-11-2013, 07:49 PM
widgitmaster This morning I played with... 09-12-2013, 06:42 PM
keebler303 Powdercoat would be my... 09-12-2013, 07:10 PM
widgitmaster This morning I placed one of... 09-13-2013, 08:23 PM
widgitmaster Next I flipped the parts... 09-13-2013, 08:31 PM
Miata2k Widgit, Correct me if I'm... 09-14-2013, 03:03 AM
widgitmaster YES! They were turned, then... 09-14-2013, 03:49 AM
widgitmaster Next, I have to clamp the... 09-13-2013, 08:40 PM
widgitmaster Today I setup the mill to... 09-14-2013, 06:14 PM
widgitmaster Next put my large angle-plate... 09-14-2013, 06:24 PM
widgitmaster Now it's time to attach the... 09-14-2013, 06:36 PM
widgitmaster I have one more hole to drill... 09-14-2013, 06:44 PM
widgitmaster Now that the weldments are... 09-14-2013, 06:51 PM
widgitmaster Today I made up two round... 09-15-2013, 07:30 PM
greenb_60097 Re: WidgitMaster's Largest... 10-13-2016, 07:46 PM
widgitmaster Today I started making all... 09-17-2013, 12:55 AM
widgitmaster Next, I used my little radius... 09-17-2013, 01:06 AM
widgitmaster Well, when I tried to use the... 09-17-2013, 06:41 PM
CarveOne Those look pretty cool... 10-07-2013, 07:40 PM
widgitmaster She gets all the money too! :) 10-10-2013, 10:58 PM
widgitmaster With the mill re-assembled, I... 09-17-2013, 06:48 PM
widgitmaster Not much time in the shop... 09-18-2013, 05:25 PM
widgitmaster Finally got some time in the... 09-20-2013, 08:57 PM
dsquire Hi Eric I haven't... 09-21-2013, 06:10 AM
widgitmaster :) Hi Don, you do realize... 09-21-2013, 01:24 PM
LeeWay I'm down South. Roll it on... 09-21-2013, 02:19 PM
CarveOne I try not to keep track of... 10-11-2013, 10:50 AM
widgitmaster Hi Lee! Today I removed... 09-22-2013, 03:21 PM
widgitmaster I've been too busy with home... 09-25-2013, 03:01 AM
steve123 Looking great, but I wouldn't... 09-25-2013, 06:56 AM
widgitmaster If I leave the webs the way... 09-25-2013, 01:37 PM
widgitmaster I removed the euro-grease... 09-25-2013, 10:29 PM
bill south Hey Eric; I do enjoy the way... 09-26-2013, 01:50 PM
widgitmaster Hi Bill! Actually I try to... 09-26-2013, 09:35 PM
widgitmaster This morning I put the z-axis... 09-27-2013, 10:22 PM
widgitmaster With the weldment positioned... 09-27-2013, 10:29 PM
widgitmaster Next, I drilled a 1/2" diam... 09-27-2013, 10:36 PM
widgitmaster So far I have setup the mill... 09-27-2013, 10:47 PM
Trotline Watching you put all those... 09-28-2013, 12:54 AM
widgitmaster Here's more Luke! This... 09-28-2013, 05:57 PM
CarveOne Breaks in the action are... 10-18-2013, 09:05 AM
LeeWay "This thing is going to be a... 09-28-2013, 07:54 PM
widgitmaster Hi Lee! I just could not... 09-29-2013, 12:03 AM
widgitmaster Today I setup the tall... 09-29-2013, 07:25 PM
widgitmaster This morning I counter-bored... 10-01-2013, 09:50 PM
widgitmaster Then I made the blank parts... 10-01-2013, 09:57 PM
widgitmaster I have an idea on how to make... 10-02-2013, 07:54 PM
widgitmaster Now I have to mill a pocket... 10-02-2013, 08:02 PM
widgitmaster Now that all the pieces are... 10-02-2013, 08:11 PM
widgitmaster Now I can have some real fun!... 10-02-2013, 08:20 PM
widgitmaster Now I can screw the parts... 10-02-2013, 08:30 PM
slimneill Great work Wigit, your talent... 10-04-2013, 06:12 PM
widgitmaster Thanks, and welcome aboard! ... 10-04-2013, 10:00 PM
widgitmaster This morning I started making... 10-04-2013, 10:07 PM
widgitmaster Next I milled the step on the... 10-04-2013, 10:14 PM
widgitmaster Now I can assemble the unit,... 10-04-2013, 10:22 PM
widgitmaster The day of adversity! 10-05-2013, 07:41 PM
widgitmaster Day of adversity, round two! 10-05-2013, 08:00 PM
keebler303 It's good you stopped for the... 10-06-2013, 02:31 AM
widgitmaster Thanks! I needed a chuckle ... 10-06-2013, 03:00 AM
widgitmaster So far its been a relaxing... 10-06-2013, 11:28 PM
CNCMAN172 She is a real artist these... 10-26-2013, 06:05 PM
widgitmaster This afternoon I decided to... 10-10-2013, 11:15 PM
widgitmaster Now I need to make the upper... 10-11-2013, 03:36 AM
widgitmaster Now I need to setup the... 10-11-2013, 03:53 AM
widgitmaster So far this project has been... 10-11-2013, 04:02 AM
LeeWay Yeah, same here. I do keep a... 10-11-2013, 01:03 PM
CarveOne It pays to have lots of... 10-30-2013, 12:54 AM
widgitmaster How True! I took a break... 10-30-2013, 02:07 AM
Miata2k You better be careful, Carve1... 10-30-2013, 03:49 AM
bill south Widget; Don't consider it an... 10-11-2013, 01:37 PM
widgitmaster Oh I'm NOT going to abandon... 10-11-2013, 02:15 PM
widgitmaster today I made the two chain... 10-11-2013, 08:06 PM
CarveOne Thanks for the file... 10-30-2013, 06:43 AM
widgitmaster Well, I got allot done today!... 10-12-2013, 08:39 PM
widgitmaster Now that the limit slide bar... 10-12-2013, 08:52 PM
widgitmaster With the Z-axis limit bar... 10-12-2013, 08:59 PM
Titaniumboy Widgitmaster, I know you... 10-13-2013, 09:16 AM
widgitmaster Thanks Titaniumboy! 10-13-2013, 06:04 PM
widgitmaster This project has slowed down,... 10-16-2013, 10:17 PM
bill south Dat's one purty box Widgit!... 10-17-2013, 06:46 PM
widgitmaster Thanks Bill! Hopefully this... 10-18-2013, 05:18 AM
widgitmaster Here is a preview of the two... 10-18-2013, 04:38 PM
widgitmaster After a few hours in the shop... 10-22-2013, 12:22 AM
widgitmaster This morning I dismantled the... 10-22-2013, 07:01 PM
widgitmaster Now I need to drill a hole in... 10-22-2013, 07:11 PM
CarveOne Good job Widget, Making... 11-03-2013, 10:26 PM
widgitmaster You twisted my arm! I have... 11-03-2013, 10:59 PM
widgitmaster Now I must say, Laurel &... 10-22-2013, 07:19 PM
widgitmaster With the mess behind me, I... 10-22-2013, 07:24 PM
CarveOne Most of us have made them... 11-03-2013, 11:22 PM
kuroguy that's horrible. cut your... 10-22-2013, 07:30 PM
widgitmaster Can I throw in the Chinese... 10-22-2013, 07:33 PM
kuroguy if you insist. Glad I... 10-22-2013, 08:17 PM
CarveOne My own 12x36 lathe has been... 11-09-2013, 12:10 PM
aarggh Curse you kuroguy and your... 10-23-2013, 10:00 AM
CarveOne If I understand widgitmaster... 10-23-2013, 11:17 AM
kuroguy So long as his soul can spend... 10-23-2013, 01:40 PM
widgitmaster WOW! Now I'll need a week in... 10-23-2013, 02:51 PM
CNCMAN172 Widgitmaster, Watching your... 10-24-2013, 12:32 AM
widgitmaster Thank you, your too kind... 10-24-2013, 03:25 AM
Dirty Engineer I love these build threads. ... 10-24-2013, 04:24 PM
widgitmaster Thanks! This morning I... 10-24-2013, 07:04 PM
widgitmaster In my initial design, the pin... 10-24-2013, 07:15 PM
widgitmaster Next, I'll finish drilling... 10-24-2013, 07:25 PM
widgitmaster For the next setup, I'll have... 10-24-2013, 07:43 PM
widgitmaster This morning I turned two... 10-25-2013, 04:48 PM
widgitmaster Yea she is! This weekend I... 10-28-2013, 02:57 PM
widgitmaster So I started a re-design of... 10-28-2013, 03:12 PM
TOTALLYRC It is not as scrap pile, It... 10-29-2013, 12:08 PM
widgitmaster :) I have crunched the... 10-29-2013, 02:55 PM
widgitmaster Success! I found 4 pieces of... 10-29-2013, 04:14 PM
widgitmaster This morning I ground off all... 10-30-2013, 11:37 PM
widgitmaster This morning I made the soft... 10-31-2013, 10:44 PM
widgitmaster The first setup is to mill... 11-01-2013, 07:57 PM
widgitmaster Now that I have the thicker... 11-01-2013, 08:05 PM
widgitmaster Now that all the datum... 11-01-2013, 08:14 PM
widgitmaster Now I can clamp the weldment... 11-01-2013, 08:22 PM
widgitmaster When I finished up yesterday,... 11-02-2013, 08:17 PM
widgitmaster Now that the angles are cut,... 11-02-2013, 08:23 PM
widgitmaster In order to do the next few... 11-02-2013, 08:33 PM
widgitmaster With the back surface details... 11-02-2013, 08:37 PM
widgitmaster The last detail is to counter... 11-02-2013, 08:47 PM
widgitmaster Today I broke away from all... 11-03-2013, 08:08 PM
widgitmaster Of all the wood species I've... 11-04-2013, 12:20 AM
widgitmaster Phew! This has been a crazy... 11-09-2013, 04:06 AM
Miata2k Well its like I always say.. ... 11-10-2013, 12:34 AM
CarveOne Yeah, the 1-1/2"dust drains... 11-10-2013, 12:52 AM
keebler303 The sintered metal machines... 11-10-2013, 01:22 AM
CarveOne There was a lot of... 11-10-2013, 08:56 AM
widgitmaster I'm glad they didn't fail... 11-10-2013, 03:39 AM
Miata2k You and your painter friend... 11-10-2013, 07:23 AM
CarveOne They worked fine for the... 11-10-2013, 09:01 AM
widgitmaster Anyone get a description of... 11-11-2013, 02:42 AM
widgitmaster Late Monday evening I milled... 11-13-2013, 04:55 AM
widgitmaster After mounting the rails &... 11-13-2013, 05:02 AM
widgitmaster Now I have to mill a pocked... 11-13-2013, 05:19 AM
widgitmaster This morning I made the... 11-13-2013, 10:59 PM
widgitmaster This morning I made the final... 11-16-2013, 11:38 PM
widgitmaster Now I can get back on track... 11-16-2013, 11:48 PM
widgitmaster Now that the box is mounted... 11-17-2013, 12:03 AM
widgitmaster Although I had accomplished... 11-17-2013, 12:15 AM
CNCMAN172 Widgitmaster, Very nice... 11-17-2013, 12:55 AM
widgitmaster Thanks Russ! 11-17-2013, 01:56 AM
widgitmaster Today I started making the... 11-17-2013, 09:17 PM
widgitmaster Next I put a 60" long, 3"... 11-17-2013, 09:28 PM
nlancaster Widget, you always build... 11-18-2013, 02:51 AM
widgitmaster Thanks !! The 25mm & 16mm... 11-18-2013, 03:27 AM
bhurts Everything is looking... 11-18-2013, 05:06 AM
widgitmaster Thanks Ben!! Yes, it... 11-18-2013, 07:05 AM
bill south Eric; This is a thing of... 11-18-2013, 03:17 PM
widgitmaster Thanks Bill!! I doubt it,... 11-18-2013, 03:35 PM
kuroguy I suspect your hobby time in... 11-19-2013, 06:52 PM
widgitmaster After all the aggravation of... 11-18-2013, 10:30 PM
widgitmaster Does that mean I'm supposed... 11-19-2013, 10:01 PM
widgitmaster Yesterday I measured... 11-21-2013, 09:58 PM
widgitmaster First I squared up a block... 11-21-2013, 10:09 PM
widgitmaster After a quick check to see... 11-21-2013, 10:30 PM
nlancaster I always love it when people... 11-22-2013, 04:45 AM
widgitmaster Thanks o'l friend! Widgit 11-22-2013, 05:09 AM
widgitmaster A little more progress this... 11-22-2013, 07:11 PM
widgitmaster Now I have to remove the vise... 11-22-2013, 07:29 PM
keebler303 That's a smart little tap... 11-22-2013, 09:28 PM
widgitmaster Thanks KEEBLER303, I've had... 11-25-2013, 10:25 PM
widgitmaster The welding did not take... 11-25-2013, 10:46 PM
widgitmaster Today I milled the extended... 11-26-2013, 08:24 PM
widgitmaster No I have to figure out the... 11-26-2013, 08:37 PM
widgitmaster Today I made the upper... 11-28-2013, 12:11 AM
widgitmaster This morning I put the... 11-30-2013, 06:31 PM
widgitmaster Now that the bracket is... 11-30-2013, 06:40 PM
widgitmaster Now that I have all the wire... 11-30-2013, 07:53 PM
nlancaster What color on the powder... 11-30-2013, 08:32 PM
widgitmaster The steel frame will be RED,... 11-30-2013, 10:39 PM
Miata2k Widgit, I think I've seen... 12-02-2013, 06:37 PM
keebler303 You have it upside down! The... 12-02-2013, 07:45 PM
nlancaster Colors will be nice and... 12-01-2013, 07:40 PM
widgitmaster Today I managed to get three... 12-01-2013, 07:53 PM
Jason Marsha Thanks for the pic showing a... 12-02-2013, 11:06 AM
widgitmaster Hi Jason! Remember to use... 12-02-2013, 02:57 PM
Trotline Now you've done it. Widget... 12-02-2013, 07:49 PM
widgitmaster More like the Big Widgit!... 12-02-2013, 09:34 PM
widgitmaster With the all the parts... 12-02-2013, 09:40 PM
widgitmaster I have updated the CAD file... 12-03-2013, 04:08 AM
CNCMAN172 Widget you have gone first... 12-04-2013, 03:19 PM
widgitmaster Your very welcome Russ! I... 12-04-2013, 09:28 PM
widgitmaster Now that the box and all the... 12-04-2013, 09:37 PM
CNCMAN172 Wigit, Not many people would... 12-04-2013, 09:42 PM
widgitmaster Thanks again Russ, But I... 12-05-2013, 04:24 AM
CNCMAN172 Wigit, I can totally relate... 12-05-2013, 03:43 PM
CNCMAN172 Wigit, I can totally relate... 12-05-2013, 03:56 PM
bill south Widgit; You attention to... 12-05-2013, 03:07 PM
widgitmaster Thanks again Guys! When I... 12-05-2013, 06:48 PM
widgitmaster This morning I started on the... 12-05-2013, 07:00 PM
widgitmaster Now I have to figure out a... 12-05-2013, 07:15 PM
widgitmaster While I was doing the Couch... 12-06-2013, 06:13 PM
widgitmaster Retirement Plan If you had... 12-06-2013, 07:00 PM
CarveOne There might be something to... 12-06-2013, 09:07 PM
bill south That's the best advice I've... 12-06-2013, 07:36 PM
widgitmaster The welder finished the VFD... 12-06-2013, 09:10 PM
CarveOne First class workmanship... 12-20-2013, 08:45 PM
widgitmaster Thanks Carv'e :) 12-20-2013, 10:31 PM
keebler303 The problem with beer is it... 12-07-2013, 01:28 AM
tjbaudio Then your not drinking real... 12-07-2013, 02:26 AM
CarveOne You're most welcome. You... 12-21-2013, 01:59 AM
widgitmaster I'll be away for the weekend,... 12-07-2013, 04:37 AM
zigmart Beer is very high in vitamin... 12-07-2013, 07:49 AM
CarveOne You have a good weekend too. ... 12-07-2013, 07:52 AM
widgitmaster Had a great weekend, spent... 12-09-2013, 07:23 PM
CNCMAN172 Wigit, Wow that support... 12-09-2013, 08:44 PM
widgitmaster Hi Russ, I was able to get... 12-11-2013, 01:38 AM
CNCMAN172 Wigit it looks great. The... 12-11-2013, 03:44 AM
widgitmaster Thanks Russ! Actually I've... 12-11-2013, 04:22 AM
CNCMAN172 Wigit, Sorry the link did... 12-11-2013, 02:46 PM
Topdecking Wow, just wow. 12-14-2013, 07:50 PM
CNCMAN172 Widget, You might consider... 12-11-2013, 02:41 PM
widgitmaster I believe we are on the same... 12-11-2013, 02:58 PM
CNCMAN172 Wiget, yes this is the same... 12-11-2013, 03:27 PM
kuroguy put a cheap prefilter in... 12-11-2013, 07:03 PM
widgitmaster I like the idea of a... 12-11-2013, 10:10 PM
widgitmaster This morning I placed the... 12-12-2013, 10:23 PM
widgitmaster Oh yea! I won the Squirrel... 12-12-2013, 10:27 PM
CNCMAN172 Awesome Wigit, nice work as... 12-14-2013, 12:52 AM
widgitmaster I have found a really high... 12-14-2013, 04:40 AM
widgitmaster With all the work on the... 12-14-2013, 07:27 PM
widgitmaster Thank you!! This morning I... 12-16-2013, 06:54 PM
widgitmaster After deburring all the... 12-16-2013, 07:07 PM
CNCMAN172 Wigit, very very nice. :)... 12-16-2013, 08:05 PM
nlancaster Widgit, this machine is going... 12-17-2013, 01:59 AM
widgitmaster Thanks guys! I sure hope I... 12-17-2013, 03:32 AM
widgitmaster The welder arrived around... 12-17-2013, 06:33 PM
CNCMAN172 Wigit, wow you still have... 12-17-2013, 07:50 PM
widgitmaster Are you kidding? It went... 12-17-2013, 08:01 PM
widgitmaster This morning I installed the... 12-18-2013, 08:51 PM
keebler303 I'm surprised you didn't use... 12-18-2013, 09:02 PM
widgitmaster The back plate is bolted in... 12-18-2013, 09:19 PM
keebler303 Fair enough. 12-18-2013, 09:59 PM
widgitmaster Now I have to make the back... 12-18-2013, 09:01 PM
widgitmaster Because the plate's size... 12-18-2013, 09:15 PM
widgitmaster This morning I finished up... 12-19-2013, 09:21 PM
widgitmaster Now that the plates are done,... 12-19-2013, 09:31 PM
widgitmaster The power cord strain relief... 12-20-2013, 04:13 PM
Trotline Something I've been thinking... 12-21-2013, 03:54 AM
widgitmaster Thank you for the kind words... 12-21-2013, 04:53 AM
widgitmaster Last night I was thinking... 12-21-2013, 05:50 PM
widgitmaster This morning I made an... 12-22-2013, 06:25 PM
widgitmaster After separating the... 12-22-2013, 06:55 PM
jalessi Eric, Try probing all the... 12-22-2013, 07:11 PM
widgitmaster Hi Jeff, When I measured... 12-22-2013, 07:46 PM
widgitmaster This morning I stopped and... 12-24-2013, 01:11 AM
widgitmaster Before I can do any more to... 12-24-2013, 01:18 AM
widgitmaster Back on the mill, I removed... 12-24-2013, 01:28 AM
widgitmaster Now I can load the VCarvePro... 12-24-2013, 01:33 AM
widgitmaster With the parts removed from... 12-24-2013, 01:52 AM
nlancaster Widgitmaster rules for life.... 12-24-2013, 10:27 PM
widgitmaster I hope you all had a nice... 12-26-2013, 04:37 AM
widgitmaster This morning I put the rotary... 12-26-2013, 08:43 PM
widgitmaster Now I have to attach the... 12-26-2013, 09:01 PM
CNCMAN172 Very nice, custom Delrin... 12-26-2013, 09:06 PM
widgitmaster Thanks Russ! Widgit 12-26-2013, 11:21 PM
widgitmaster Today I qualified a few of... 12-27-2013, 09:54 PM
widgitmaster The knob on the opposite side... 12-27-2013, 10:03 PM
widgitmaster This morning I ground up a... 12-28-2013, 10:18 PM
widgitmaster Now I have to make the... 12-28-2013, 10:28 PM
widgitmaster With the Delrin parts... 12-28-2013, 10:38 PM
Spk64 Looking great. Takes a lot... 12-28-2013, 10:47 PM
widgitmaster Thanks Steve! Patience and a... 12-28-2013, 11:00 PM
widgitmaster This afternoon I started on... 12-30-2013, 10:53 PM
widgitmaster To do the other side, I have... 12-30-2013, 11:07 PM
widgitmaster Happy New Year to all you... 01-01-2014, 07:21 PM
Bubba Widgit, And a Happy New Year... 01-01-2014, 08:41 PM
widgitmaster Well, it a new year! I've got... 01-03-2014, 06:38 AM
bill south Widget; As we can finally... 01-03-2014, 04:17 PM
widgitmaster The eBay bid on the squirrel... 01-03-2014, 04:35 PM
kuroguy if you post the wheel... 01-03-2014, 06:11 PM
widgitmaster Thanks Kuroguy! Here are the... 01-03-2014, 11:14 PM
widgitmaster This morning I finished up... 01-03-2014, 11:30 PM
kuroguy the closest I can find is a... 01-06-2014, 06:29 PM
CNCMAN172 Wiget, I have run my Chinese... 01-06-2014, 07:13 PM
widgitmaster This morning I started on the... 01-06-2014, 10:33 PM
widgitmaster Thanks Guys! 600 CFM ! Wow,... 01-06-2014, 10:16 PM
Falcon69 okay, I've been finding it... 01-06-2014, 11:49 PM
widgitmaster Thanks! Unfortunately, I... 01-07-2014, 10:57 PM
widgitmaster This morning I struggled... 01-07-2014, 11:00 PM
CNCMAN172 Wigit, wow you even do... 01-07-2014, 11:53 PM
widgitmaster The steel for mounting the... 01-09-2014, 02:57 PM
kuroguy You'll never get 600 cfm... 01-09-2014, 03:03 PM
widgitmaster If that is going to be a... 01-09-2014, 03:24 PM
Miata2k From this chart I found... 01-10-2014, 12:58 AM
kuroguy ...and the real problem is if... 01-10-2014, 01:10 AM
widgitmaster With KuroGuy's warning in... 01-09-2014, 07:47 PM
widgitmaster Back in the house, I started... 01-09-2014, 03:21 PM
CNCMAN172 Wigit, where did you get the... 01-09-2014, 03:40 PM
widgitmaster Thanks Russ! Here's the... 01-09-2014, 04:16 PM
CarveOne Yes, do edge light it. ... 01-19-2014, 03:06 AM
widgitmaster YES! Back-lighting makes... 01-19-2014, 02:39 PM
Topdecking Very clean as usual there WM. 01-10-2014, 04:39 AM
keebler303 The "slip-on wire markers"... 01-09-2014, 06:25 PM
widgitmaster Next I sprayed some layout... 01-09-2014, 07:55 PM
widgitmaster Great News!! After my trip... 01-09-2014, 10:42 PM
kuroguy I've been traveling for work... 01-10-2014, 01:05 AM
Miata2k The fan that you are using... 01-10-2014, 01:15 AM
widgitmaster I would like to turn off the... 01-10-2014, 01:48 AM
nlancaster Yes you have reduced it by... 01-10-2014, 04:28 AM
kuroguy You've actually got 25% of... 01-10-2014, 02:08 PM
CNCMAN172 Thanks Widgit, I will get... 01-10-2014, 02:18 PM
widgitmaster This morning I made a trip to... 01-10-2014, 06:00 PM
Topdecking I have a bunch of motors like... 01-10-2014, 06:51 PM
widgitmaster After a quick trip to ACE for... 01-11-2014, 06:59 PM
widgitmaster After lunch, I went on a... 01-11-2014, 09:49 PM
widgitmaster Things Not to do when wiring... 01-12-2014, 04:43 PM
widgitmaster Today I played in the shop... 01-12-2014, 06:18 PM
TOTALLYRC Hi widgit, I am in awe of... 01-13-2014, 10:35 AM
widgitmaster Thanks Mike! Warmer weather... 01-13-2014, 02:04 PM
widgitmaster The welder showed up this... 01-13-2014, 07:34 PM
Dirty Engineer If I may offer some advice I... 01-13-2014, 07:56 PM
nlancaster getting so close widget! 01-13-2014, 07:54 PM
widgitmaster There is no way I'm going to... 01-13-2014, 10:29 PM
Wackamazoo This is going to look... 01-13-2014, 10:42 PM
bill south Widgit; Your powder bill is... 01-14-2014, 02:28 PM
widgitmaster Thanks again Guys! Well,... 01-14-2014, 09:06 PM
jckstrthmghty Almost feel like I'm watching... 01-14-2014, 09:25 PM
Miata2k Just needs someone to do some... 01-14-2014, 09:59 PM
kuroguy except on american chopper... 01-14-2014, 10:02 PM
widgitmaster Actually, the z slide is... 01-14-2014, 10:29 PM
widgitmaster The filter box has returned... 01-15-2014, 08:36 PM
bill south Widgit; Have the powder... 01-16-2014, 03:07 PM
widgitmaster Hi Bill, The parts should be... 01-16-2014, 03:26 PM
widgitmaster So far I've been busy... 01-18-2014, 10:37 PM
widgitmaster This afternoon I put that... 01-18-2014, 10:47 PM
Bubba Hey, Now you just need to... 01-18-2014, 11:09 PM
nlancaster Do it! 219278 01-19-2014, 12:00 AM
ger21 Or take a torch to it and... 01-19-2014, 03:10 PM
widgitmaster Wow! What did I get myself... 01-21-2014, 01:19 AM
Bubba Widgitmaster OH GREAT SIR:... 01-21-2014, 01:28 AM
widgitmaster How True, Bubba! But I've... 01-21-2014, 03:58 AM
kuroguy You should build a hobby shop... 01-21-2014, 02:17 PM
widgitmaster WOW! Thanks for the kind... 01-22-2014, 12:38 AM
widgitmaster Everything is on schedule,... 01-22-2014, 11:11 PM
CarveOne We're rootin' ya Widgit. I'm... 01-23-2014, 03:07 AM
Wackamazoo Oddly, yes! 01-22-2014, 11:24 PM
CNCMAN172 Wigit, Should be exciting to... 01-22-2014, 11:39 PM
bhurts Widgit do yo make the little... 01-23-2014, 05:09 AM
widgitmaster Hello Ben! Yes, I have made... 01-23-2014, 02:09 PM
widgitmaster While I'm waiting for the Red... 01-23-2014, 05:45 PM
kuroguy you're gonna need to write... 01-23-2014, 06:33 PM
kuroguy ...and to clarify, it outputs... 01-23-2014, 06:41 PM
widgitmaster Well that's not what I... 01-23-2014, 07:06 PM
kuroguy this might work for you.... 01-23-2014, 07:13 PM
kuroguy what flow rate are you trying... 01-23-2014, 07:09 PM
widgitmaster The spindle is water cooled,... 01-23-2014, 07:15 PM
kuroguy you might be able to make one... 01-23-2014, 07:32 PM
kuroguy Personally, I'd use a... 01-23-2014, 07:20 PM
tjbaudio I think you need to stick... 01-23-2014, 07:57 PM
widgitmaster Thanks! I'm not sold on the... 01-23-2014, 08:32 PM
kuroguy here's one that turns on at... 01-23-2014, 08:41 PM
widgitmaster I agree, I should have also... 01-23-2014, 08:50 PM
kuroguy oops.... Agrowtek SNS-FLW... 01-23-2014, 08:50 PM
widgitmaster Well, I recieved a reply from... 01-23-2014, 10:30 PM
kuroguy How big is the piping you are... 01-23-2014, 08:37 PM
kuroguy ok, you're not gonna get much... 01-23-2014, 08:58 PM
widgitmaster I know, fortunately the water... 01-23-2014, 09:10 PM
kuroguy there's only 2 wires. I... 01-23-2014, 09:16 PM
keebler303 This is almost surely the... 01-23-2014, 09:39 PM
Falcon69 Why not use something like... 01-23-2014, 09:53 PM
kuroguy you'll get the same pulsed... 01-23-2014, 09:58 PM
Falcon69 Actually, come to think of... 01-23-2014, 10:05 PM
Falcon69 True, but combined with this... 01-23-2014, 10:01 PM
widgitmaster Correct me if I'm wrong, but... 01-23-2014, 10:50 PM
widgitmaster Thanks Guys! For helping me... 01-23-2014, 11:22 PM
Spk64 Widget Have you tested the... 01-24-2014, 12:18 AM
ger21 Eric's 5 gal/min pump should... 01-24-2014, 12:27 AM
Spk64 Oops missed that. Also... 01-24-2014, 02:02 AM
Miata2k We are using a Thermal... 01-24-2014, 12:52 AM
widgitmaster This afternoon I made up a... 01-24-2014, 10:24 PM
CNCMAN172 Eric, Your water tank, pump,... 01-24-2014, 11:10 PM
widgitmaster Thanks Russ! I'm really... 01-25-2014, 12:09 AM
Topdecking You really are keeping that... 01-25-2014, 12:37 AM
kuroguy That pump doesn't sit... 01-25-2014, 02:35 AM
widgitmaster Yes, it's extended down into... 01-25-2014, 03:10 AM
CNCMAN172 Wigit, I use distilled water... 01-25-2014, 03:37 PM
widgitmaster Thanks Russ! I mounted the... 01-25-2014, 06:02 PM
Wackamazoo Very cool! I would think... 01-25-2014, 08:57 PM
keebler303 I agree. The radiator will do... 01-25-2014, 10:35 PM
Dylwad For sure, he could probably... 01-25-2014, 10:54 PM
widgitmaster I'm glad the cooling system... 01-26-2014, 12:11 AM
CNCMAN172 Wigit, I will be totally... 01-26-2014, 09:19 PM
CarveOne Your machine is coming... 02-07-2014, 06:40 PM
Topdecking Actually while many think... 01-26-2014, 09:49 PM
widgitmaster Just want to say that I... 01-27-2014, 03:40 AM
nlancaster You should get a discount on... 01-27-2014, 05:51 AM
bill south Widget; I hope you don't... 01-27-2014, 03:22 PM
Dylwad I remember getting it from... 01-27-2014, 06:42 PM
CarveOne Widgit can't hear you guys. ... 02-08-2014, 06:26 PM
kuroguy antifreeze comes in two... 01-27-2014, 03:43 PM
widgitmaster No problem Bill! The... 01-27-2014, 03:48 PM
widgitmaster The parts will be here in an... 01-27-2014, 06:46 PM
kuroguy oh man. this is gonna be... 01-27-2014, 06:49 PM
jalessi Eric, Pure propylene... 01-28-2014, 12:21 AM
widgitmaster Oh man is my back sore! All... 01-28-2014, 12:46 AM
widgitmaster The 1st thing I need to do is... 01-28-2014, 01:07 AM
Miata2k WOW that turned out great! ... 01-28-2014, 01:20 AM
nlancaster http://www.pdxmc.com/uploads/F... 01-28-2014, 05:08 AM
Dylwad Scotch brite pad (roloc) on a... 01-28-2014, 06:00 AM
CNCMAN172 Wow, they did a great job on... 01-28-2014, 10:50 PM
widgitmaster Not yet Russ, I have some... 01-29-2014, 12:18 AM
widgitmaster This morning I put the doors... 01-29-2014, 12:36 AM
nlancaster Do you need another grandson... 01-29-2014, 01:27 AM
keebler303 Seems your discount powder... 01-29-2014, 03:39 AM
widgitmaster Actually the threads were... 01-29-2014, 05:59 AM
Topdecking Those are BEAUTIFUL ballnut... 02-03-2014, 06:21 PM
bill south Widgit; Looking Amazing so... 01-29-2014, 02:56 PM
widgitmaster Well, putting a 5-pound drill... 01-29-2014, 03:25 PM
widgitmaster This morning I propped up the... 01-29-2014, 09:33 PM
widgitmaster Now I have to make and... 01-29-2014, 09:44 PM
widgitmaster While studying the Y-Axis... 01-29-2014, 09:54 PM
widgitmaster This morning I put painter's... 01-31-2014, 03:33 AM
widgitmaster After cleaning out the... 01-31-2014, 03:44 AM
kuroguy Yup, this is just like... 01-31-2014, 03:51 AM
widgitmaster Today I solved a problem with... 02-02-2014, 01:55 AM
widgitmaster After removing the right-side... 02-02-2014, 02:06 AM
widgitmaster This morning I dropped off... 02-03-2014, 05:15 PM
widgitmaster today I made the two Teflon... 02-05-2014, 12:55 AM
widgitmaster The stuff for the 220-VAC... 02-05-2014, 01:00 AM
widgitmaster Lots of progress today! The... 02-05-2014, 11:05 PM
CNCMAN172 Looking Sweet Wigit, this... 02-05-2014, 11:17 PM
nlancaster Looking like you are making... 02-05-2014, 11:23 PM
widgitmaster The parts have returned from... 02-07-2014, 03:30 AM
widgitmaster The race is on Carv'e :) ... 02-08-2014, 01:34 AM
Jason Marsha Almost there Widgit, the... 02-08-2014, 12:01 PM
CNCMAN172 Wigit, those colors really... 02-08-2014, 05:31 PM
widgitmaster You tell'em Carv'e !! So... 02-09-2014, 12:11 AM
widgitmaster So far I've made excellent... 02-11-2014, 02:22 AM
keebler303 Keep the panel doors closed... 02-11-2014, 05:01 AM
widgitmaster No smoke, but it did get... 02-11-2014, 06:04 AM
widgitmaster A little more progress today!... 02-11-2014, 11:22 PM
widgitmaster This morning I added the... 02-12-2014, 08:48 PM
CNCMAN172 Wigit, amazing that those... 02-13-2014, 08:47 PM
widgitmaster Hi Russ, The switches have... 02-13-2014, 11:55 PM
ger21 YouTube. 02-14-2014, 12:03 AM
widgitmaster http://youtu.be/Gxm4r_IK3Zw 02-14-2014, 02:12 AM
nlancaster http://stemworksblog.files.wor... 02-14-2014, 02:38 AM
CNCMAN172 Wigit, AWESOME.... wow it... 02-14-2014, 02:51 AM
Falcon69 good job, congrats 02-14-2014, 03:29 AM
widgitmaster After I got the Constant... 02-14-2014, 04:52 AM
nlancaster Widget are you talking about... 02-14-2014, 06:06 AM
widgitmaster One of the settings in Mach3... 02-14-2014, 01:39 PM
tahustvedt Mine does this too, and... 02-16-2014, 10:25 PM
bill south Nice Job Eric! Another... 02-14-2014, 03:30 PM
widgitmaster Thanks Bill! Only worked... 02-15-2014, 04:29 AM
ger21 On commercial machines, after... 02-15-2014, 05:01 PM
pippin88 I think most VFDs will... 02-15-2014, 11:22 PM
widgitmaster Each E-Stop has two NC switch... 02-16-2014, 12:16 AM
pippin88 Sorry, poor phrasing on my... 02-16-2014, 02:05 AM
widgitmaster Today I removed the Z-Slide,... 02-16-2014, 12:31 AM
widgitmaster Hi Gerry, This morning I... 02-17-2014, 04:52 PM
Bubba On mine, there is a setting... 02-16-2014, 12:26 AM
widgitmaster Can someone help me locate a... 02-16-2014, 03:14 PM
Spk64 Is this what you are looking... 02-16-2014, 03:36 PM
ger21 OEM Buttons - Mach3Wiki... 02-16-2014, 03:36 PM
widgitmaster YES!! Thank you, that's... 02-16-2014, 04:47 PM
widgitmaster This afternoon I ran the... 02-16-2014, 08:16 PM
tahustvedt 1140 IPM is pretty amazing.... 02-16-2014, 10:28 PM
widgitmaster As for the Constant Velocity,... 02-17-2014, 03:10 AM
dodger889 You might want to use a... 02-20-2014, 04:36 AM
tahustvedt It's odd. It doesn't always... 02-17-2014, 01:59 PM
widgitmaster Last night I finished wiring... 02-17-2014, 04:36 PM
widgitmaster Now that everything is... 02-17-2014, 04:43 PM
CarveOne Widgit, I'll be making a... 02-22-2014, 04:14 AM
widgitmaster Sorry CarveOne I didn't see... 02-23-2014, 08:04 AM
widgitmaster This afternoon, I decided to... 02-18-2014, 12:19 AM
kuroguy that's turning into one good... 02-18-2014, 06:12 PM
widgitmaster Thanks Kuroguy! Looks... 02-18-2014, 08:18 PM
kuroguy have you got an oscilloscope?... 02-18-2014, 08:21 PM
kuroguy wait. is the shutdown coming... 02-18-2014, 08:29 PM
widgitmaster Unfortunately I have a... 02-18-2014, 09:12 PM
kuroguy might be able to filter out... 02-18-2014, 09:16 PM
mactec54 widgitmaster Almost done... 02-19-2014, 03:54 AM
CNCMAN172 Wiget, You are getting EMI... 02-19-2014, 03:56 AM
CNCMAN172 Look on eBay for ferrite ring... 02-19-2014, 04:01 AM
widgitmaster It appears that I've made the... 02-19-2014, 05:18 AM
CNCMAN172 Wigit, I would recommend... 02-19-2014, 01:00 PM
mactec54 CNCMAN172 If widgitmaster ... 02-19-2014, 03:18 PM
dodger889 Just a dumb question how do... 02-20-2014, 12:22 AM
widgitmaster There is a #12-AWG ground... 02-20-2014, 01:37 AM
kuroguy Is dodger889 a ham? 02-20-2014, 05:05 AM
dodger889 No just played with... 02-20-2014, 10:40 AM
widgitmaster Question? The VFD inverter... 02-20-2014, 02:48 PM
Alan XR8 Just connect it up and if it... 02-20-2014, 02:58 PM
kuroguy alan is right. reversing a... 02-20-2014, 03:01 PM
widgitmaster Excellent! It starts in... 02-20-2014, 03:14 PM
CNCMAN172 Wigit, As others said... 02-20-2014, 03:27 PM
mactec54 Some good points, but for... 02-20-2014, 04:10 PM
widgitmaster Can someone explain why the... 02-23-2014, 01:24 PM
mactec54 widgitmaster Were ever you... 02-20-2014, 04:34 PM
CNCMAN172 Mactec54, you are 100%... 02-20-2014, 05:19 PM
CNCMAN172 Interesting Video on EMI and... 02-20-2014, 05:22 PM
widgitmaster Oh how I wish I had a nice... 02-21-2014, 12:20 AM
CNCMAN172 Wigit, Just looked at a... 02-20-2014, 06:52 PM
widgitmaster Yes, I have a SmoothStepper!... 02-21-2014, 01:22 AM
bill south Cncman; Great Video. ... 02-20-2014, 09:04 PM
widgitmaster Wow, spend the day in the... 02-20-2014, 11:58 PM
widgitmaster As planned, the UPS truck... 02-21-2014, 12:18 AM
kuroguy You can pick up a 60Mhz scope... 02-21-2014, 04:30 AM
CNCMAN172 Widget, You do such nice... 02-21-2014, 01:57 PM
widgitmaster Thanks Russ! 02-21-2014, 02:41 PM
widgitmaster This morning I finished the... 02-22-2014, 02:35 AM
widgitmaster This afternoon, I rearranged... 02-22-2014, 02:40 AM
TOTALLYRC Filed that away for the next... 02-23-2014, 10:28 AM
dodger889 widgit have thought about... 02-23-2014, 11:14 AM
ger21 A debounce setting of 130 is... 02-23-2014, 01:47 PM
CNCMAN172 Wigit, My guess is the e-stop... 02-23-2014, 09:20 PM
mactec54 CNCMAN172 What you are... 02-23-2014, 09:50 PM
widgitmaster A little progress today, as I... 02-24-2014, 12:19 AM
dodger889 Hey guys just wondering if... 02-24-2014, 01:03 AM
CNCMAN172 Dodger889, You are correct... 02-24-2014, 02:22 AM
widgitmaster So your saying I should add... 02-24-2014, 02:49 AM
CNCMAN172 Wigit, with 19 feet of cable... 02-24-2014, 03:03 AM
widgitmaster Actually, there is an ice... 02-24-2014, 03:14 AM
CNCMAN172 Do you have a wiring diagram... 02-24-2014, 03:19 AM
widgitmaster Right now all the diagrams... 02-24-2014, 03:24 AM
dodger889 Widgit Now you have a way to... 02-24-2014, 09:06 AM
widgitmaster Other than the fact that I'm... 02-24-2014, 08:13 PM
tahustvedt Fourth from the left is the... 02-24-2014, 09:17 PM
ger21 Do you have the Home switches... 02-24-2014, 09:29 PM
CNCMAN172 Wigit can you pencil a quick... 02-24-2014, 09:55 PM
CNCMAN172 Wigit, lets take this step by... 02-24-2014, 10:00 PM
bhurts I do not use mach but I... 02-24-2014, 10:46 PM
widgitmaster After I disconnected the... 02-24-2014, 11:45 PM
widgitmaster Now that I have added the... 02-24-2014, 11:51 PM
widgitmaster I just want to say Thank You... 02-24-2014, 11:47 PM
CNCMAN172 Widget great news...... 02-25-2014, 02:13 PM
bill south Great Job Widgit and... 02-25-2014, 02:20 PM
widgitmaster Thanks again guys! Today... 02-25-2014, 11:26 PM
mactec54 That's a good thing, this... 02-26-2014, 12:06 AM
widgitmaster Well, here we go again :( I... 02-26-2014, 06:06 PM
CNCMAN172 Widgit, I think you first... 02-26-2014, 07:01 PM
Trotline The biggest reasons for a... 02-26-2014, 07:07 PM
CNCMAN172 Wigit, it just hit me these... 02-26-2014, 07:53 PM
widgitmaster The SS is set to receive 5V... 02-26-2014, 08:50 PM
CNCMAN172 USB2 or USB3 type ports? you... 02-26-2014, 11:00 PM
widgitmaster I fixed the error msg's, but... 02-26-2014, 11:05 PM
CNCMAN172 Wigit, LOL I know these... 02-26-2014, 11:16 PM
widgitmaster Thanks Russ, that manual was... 02-27-2014, 07:34 PM
widgitmaster The more I use the... 02-27-2014, 07:40 PM
widgitmaster Finnaly, I have the motors... 02-28-2014, 12:07 AM
widgitmaster Can anyone help me set the... 02-28-2014, 12:09 AM
CNCMAN172 Widget, I am down in Ashville... 02-28-2014, 01:57 AM
widgitmaster The SmoothStepper keeps... 02-28-2014, 04:19 PM
mactec54 I would not say the... 02-28-2014, 10:34 PM
CNCMAN172 Should have clarified remove... 02-28-2014, 11:40 PM
mactec54 His USB cable already has 2... 03-01-2014, 12:21 AM
ger21 USB Smoothsteppers are known... 02-28-2014, 05:28 PM
widgitmaster Hi Gerry, Well I just... 02-28-2014, 07:14 PM
Alan XR8 Hi Widgit, you have the 126... 02-28-2014, 05:40 PM
widgitmaster Yes Thanks! I had to change... 02-28-2014, 07:10 PM
CNCMAN172 Widget, as others mentioned... 02-28-2014, 11:38 PM
nlancaster 25ft USB cable is beyond the... 03-01-2014, 12:51 AM
widgitmaster Again, I really do appreciate... 03-01-2014, 01:12 AM
nlancaster Sounds like a good plan... 03-01-2014, 01:18 AM
widgitmaster Thanks nlancaster !! Here... 03-01-2014, 09:46 PM
widgitmaster Today I removed the... 03-02-2014, 09:40 PM
widgitmaster While I'm waiting for the... 03-03-2014, 10:19 PM
Alan XR8 Work if Art Widgit. A1 all... 03-03-2014, 11:51 PM
widgitmaster I had the machine & spindle... 03-04-2014, 08:12 PM
mactec54 Did this happen after a... 03-05-2014, 05:33 AM
widgitmaster Hi Mac, Actually, I... 03-05-2014, 05:38 PM
tahustvedt I read about that a few days... 03-04-2014, 08:45 PM
widgitmaster Oh well, this one looks like... 03-04-2014, 11:26 PM
Miata2k I'm pretty sure this drive... 03-05-2014, 12:14 AM
Vice Comp Hey Widgit, I've been... 03-05-2014, 01:04 AM
ger21 According to that other... 03-04-2014, 11:30 PM
CNCMAN172 Widget you should disconnect... 03-05-2014, 02:05 AM
widgitmaster This evening I removed the... 03-05-2014, 05:14 AM
mactec54 widgitmaster Hi Widgit,... 03-05-2014, 06:21 PM
kuroguy ...and the VFD should also... 03-05-2014, 07:16 PM
widgitmaster Thanks Guys! I have been... 03-06-2014, 10:15 PM
brcase If I didn't live 2300 miles... 03-07-2014, 06:26 AM
widgitmaster Thanks for the kind words! 03-07-2014, 07:05 AM
Miata2k No always the best option,... 03-07-2014, 08:10 PM
widgitmaster like I said, "Wishfull... 03-07-2014, 10:55 PM
Miata2k I know what you mean. I... 03-08-2014, 01:26 AM
widgitmaster The ribbon cables and 2nd... 03-07-2014, 11:03 PM
widgitmaster I have been thinking of... 03-08-2014, 05:36 AM
CNCMAN172 Wigit, you should have said... 03-08-2014, 02:07 PM
widgitmaster Thanks Russ! 03-08-2014, 02:17 PM
widgitmaster PMDX-126 Breakout Board... 03-08-2014, 06:08 PM
widgitmaster Good News / Bad News :( 03-10-2014, 06:54 PM
CNCMAN172 Widget, This is a bummer. ... 03-10-2014, 08:51 PM
widgitmaster Thanks Russ, I have to order... 03-10-2014, 09:15 PM
CNCMAN172 Widget, I know for fact if... 03-10-2014, 09:32 PM
keebler303 "No user serviceable parts... 03-10-2014, 09:47 PM
mactec54 widgitmaster This may help... 03-10-2014, 11:12 PM
widgitmaster Thanks Mac! Do the... 03-11-2014, 12:17 AM
CNCMAN172 Widget, I think MAC might be... 03-11-2014, 12:34 AM
widgitmaster That's not the case, as It... 03-11-2014, 12:37 AM
widgitmaster After logging in to Mouser, I... 03-11-2014, 12:35 AM
widgitmaster I need to hit the couch, my... 03-11-2014, 12:41 AM
mactec54 widgitmaster You should... 03-11-2014, 01:14 AM
dodger889 Did you check each leg going... 03-11-2014, 03:33 AM
Vice Comp Widgit, You really need to... 03-11-2014, 05:21 AM
CNCMAN172 Widget, You are probably... 03-11-2014, 01:11 PM
widgitmaster Good morning ! I have read... 03-11-2014, 02:05 PM
widgitmaster Well, curiosity bit me in the... 03-11-2014, 03:30 PM
kuroguy i wonder if that means the... 03-11-2014, 03:38 PM
widgitmaster I know your in the... 03-11-2014, 04:31 PM
kuroguy that depends on how they are... 03-11-2014, 05:04 PM
widgitmaster I guess there's only one way... 03-11-2014, 06:10 PM
mactec54 No The DL means one or more... 03-11-2014, 04:37 PM
widgitmaster Thanks Mac! So far I have... 03-11-2014, 04:48 PM
CNCMAN172 Widget, did the spindle... 03-11-2014, 03:52 PM
CNCMAN172 Wow that sucker really did... 03-11-2014, 03:55 PM
widgitmaster No Russ, as I stated back in... 03-11-2014, 04:11 PM
bill south Widgit; I was looking at... 03-11-2014, 04:12 PM
widgitmaster Your probably right Bill, and... 03-11-2014, 04:25 PM
kuroguy good solution to your... 03-11-2014, 06:31 PM
tjbaudio I thought you were also going... 03-11-2014, 08:30 PM
widgitmaster Yes, but I haven't figured... 03-11-2014, 10:03 PM
jalessi Eric, ... 03-11-2014, 11:12 PM
kuroguy I recommended that flow... 03-12-2014, 02:29 AM
tjbaudio I wish we were closer, I'm in... 03-12-2014, 01:54 AM
CNCMAN172 Widget, you just convinced me... 03-11-2014, 09:00 PM
bhurts You can always use the... 03-12-2014, 12:26 AM
widgitmaster That's a nice find Jeff!... 03-12-2014, 01:48 AM
dodger889 Just thinking about it. If... 03-12-2014, 02:51 AM
ger21 Just a note about referencing... 03-12-2014, 02:51 AM
widgitmaster Good News! 03-13-2014, 04:13 AM
mactec54 widgitmaster Here is what... 03-13-2014, 02:57 PM
widgitmaster Thanks Mac! When I opened... 03-13-2014, 03:08 PM
mactec54 widgitmaster They are the... 03-13-2014, 03:38 PM
widgitmaster Thanks Mac! Today I... 03-13-2014, 11:52 PM
mactec54 Correct Diode's are for DC... 03-14-2014, 01:20 AM
widgitmaster The stripe on the Diode goes... 03-14-2014, 01:39 AM
kuroguy on a dc relay a diode is used... 03-14-2014, 12:17 AM
matth But a lot of the time a high... 03-14-2014, 12:54 AM
CNCMAN172 Widget the two VFDs do look... 03-14-2014, 12:55 AM
kuroguy To clamp back EMF by... 03-14-2014, 03:57 AM
mactec54 widgitmaster 03-14-2014, 04:03 AM
widgitmaster Ok, thanks! Now, does the... 03-14-2014, 05:57 AM
tjbaudio I would not use a Varister. ... 03-14-2014, 08:41 AM
kuroguy the varistor or diode... 03-14-2014, 12:50 PM
matth I'm sorry but that is not... 03-14-2014, 12:57 PM
kuroguy ...but on an old car, that... 03-14-2014, 01:01 PM
kuroguy I stand corrected 03-14-2014, 01:00 PM
mactec54 Here is some good information... 03-14-2014, 02:04 PM
widgitmaster Thanks again Mac! That was... 03-14-2014, 11:33 PM
widgitmaster Today I removed the top box... 03-14-2014, 11:43 PM
pippin88 I've run my 1.5kw spindle... 03-15-2014, 09:04 AM
widgitmaster Has anyone used 2" x 6" Toung... 03-16-2014, 02:16 PM
CNCMAN172 Widget, the issue with using... 03-16-2014, 02:36 PM
widgitmaster Thanks Russ, I'll go with the... 03-16-2014, 03:47 PM
tahustvedt It says the video is private.... 03-16-2014, 04:36 PM
widgitmaster https://www.youtube.com/watch?... 03-16-2014, 04:44 PM
CNCMAN172 Widget, wow that is smoking... 03-16-2014, 09:18 PM
tahustvedt So fast and smooth. More than... 03-16-2014, 10:10 PM
widgitmaster Thanks guys! I'm bored... 03-17-2014, 04:04 PM
tahustvedt You have had more than your... 03-17-2014, 05:26 PM
CNCMAN172 Widget, My son has this... 03-17-2014, 08:54 PM
widgitmaster Only one problem Russ! I... 03-17-2014, 09:16 PM
CNCMAN172 Widget, does the pendant... 03-18-2014, 01:12 PM
bill south Widget; I would still... 03-18-2014, 05:40 PM
widgitmaster Thanks Guys, but I have... 03-18-2014, 10:24 PM
widgitmaster Finally some GOOD news! The... 03-19-2014, 01:08 AM
nlancaster Widget, good to hear on the... 03-19-2014, 01:50 AM
bill south Hey Guys; Soon we'll see... 03-19-2014, 01:38 PM
kuroguy Widgit, Do you think your... 03-19-2014, 02:50 PM
widgitmaster Hi Guy! Actually I have NO... 03-19-2014, 04:08 PM
widgitmaster Another eBay screw up !! 03-19-2014, 08:01 PM
Falcon69 the item was for the... 03-19-2014, 08:08 PM
widgitmaster No, I had the wrong link in... 03-19-2014, 08:14 PM
kuroguy widgit, I've contacted a guy... 03-19-2014, 08:12 PM
widgitmaster Thanks Guy, I needed a laugh!... 03-19-2014, 09:10 PM
kuroguy Glad I could help. 03-19-2014, 10:08 PM
Falcon69 wow, that guy is even worse.... 03-19-2014, 08:15 PM
widgitmaster I'm tired of dealing with... 03-19-2014, 09:01 PM
tahustvedt I bought a stepper from... 03-19-2014, 09:09 PM
Falcon69 i bought my power supply and... 03-19-2014, 09:32 PM
CarveOne Re: WidgitMaster's Largest... 03-28-2014, 12:59 AM
Wackamazoo Automation Technologies 03-19-2014, 09:36 PM
CNCMAN172 Widget, That guy's store... 03-19-2014, 09:44 PM
tjbaudio I bought stuff from... 03-20-2014, 05:16 AM
tahustvedt Infoshine15 is the seller I... 03-20-2014, 05:36 PM
widgitmaster Re: WidgitMaster's Largest... 03-22-2014, 11:00 PM
ger21 Re: WidgitMaster's Largest... 03-22-2014, 11:16 PM
widgitmaster Re: WidgitMaster's Largest... 03-22-2014, 11:35 PM
ger21 Re: WidgitMaster's Largest... 03-23-2014, 12:33 AM
widgitmaster Re: WidgitMaster's Largest... 03-23-2014, 02:13 AM
ger21 Re: WidgitMaster's Largest... 03-23-2014, 02:23 AM
widgitmaster WOW !! 03-23-2014, 04:54 PM
widgitmaster Re: WidgitMaster's Largest... 03-23-2014, 05:54 PM
widgitmaster Re: WidgitMaster's Largest... 03-25-2014, 02:45 PM
keebler303 Re: WidgitMaster's Largest... 03-25-2014, 04:36 PM
CarveOne Re: WidgitMaster's Largest... 03-26-2014, 12:04 AM
bill south Re: WidgitMaster's Largest... 03-25-2014, 06:58 PM
CarveOne Re: WidgitMaster's Largest... 03-25-2014, 11:42 PM
widgitmaster Re: WidgitMaster's Largest... 03-25-2014, 07:32 PM
tahustvedt Re: WidgitMaster's Largest... 03-25-2014, 08:35 PM
keebler303 Re: WidgitMaster's Largest... 03-25-2014, 10:27 PM
tahustvedt Re: WidgitMaster's Largest... 03-25-2014, 10:45 PM
widgitmaster The seller issued you a full... 03-27-2014, 02:35 PM
Bubba Re: WidgitMaster's Largest... 03-27-2014, 02:51 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2014, 03:06 PM
CNCMAN172 Re: WidgitMaster's Largest... 03-27-2014, 03:51 PM
Falcon69 Re: WidgitMaster's Largest... 03-27-2014, 04:38 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2014, 07:17 PM
tauntdesigns Re: WidgitMaster's Largest... 03-27-2014, 04:44 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2014, 07:20 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2014, 08:08 PM
Donny M. Carter Re: WidgitMaster's Largest... 03-27-2014, 08:55 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2014, 09:58 PM
CarveOne Re: WidgitMaster's Largest... 04-05-2014, 11:56 PM
CarveOne Re: WidgitMaster's Largest... 05-09-2014, 12:04 AM
widgitmaster Re: WidgitMaster's Largest... 05-12-2014, 03:37 PM
minichopper6hp Re: WidgitMaster's Largest... 03-27-2014, 10:20 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2014, 10:45 PM
minichopper6hp Re: WidgitMaster's Largest... 03-27-2014, 10:47 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2014, 11:37 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2014, 11:21 PM
kuroguy Re: WidgitMaster's Largest... 03-28-2014, 01:26 PM
CarveOne Re: WidgitMaster's Largest... 04-12-2014, 02:05 AM
widgitmaster Re: WidgitMaster's Largest... 03-28-2014, 11:51 PM
keebler303 Re: WidgitMaster's Largest... 03-29-2014, 03:36 PM
widgitmaster Re: WidgitMaster's Largest... 03-29-2014, 04:52 PM
CarveOne Re: WidgitMaster's Largest... 04-17-2014, 11:03 AM
ger21 Re: WidgitMaster's Largest... 03-29-2014, 05:12 PM
widgitmaster Re: WidgitMaster's Largest... 03-29-2014, 11:08 PM
widgitmaster Finally, the new spindle has... 03-29-2014, 11:42 PM
CarveOne Re: Finally, the new spindle... 04-19-2014, 10:02 PM
widgitmaster Re: Finally, the new spindle... 04-19-2014, 11:52 PM
Bubba Re: WidgitMaster's Largest... 03-30-2014, 01:31 AM
widgitmaster Re: WidgitMaster's Largest... 03-30-2014, 01:56 AM
Bubba Re: WidgitMaster's Largest... 03-30-2014, 02:00 AM
widgitmaster Re: WidgitMaster's Largest... 03-30-2014, 09:07 PM
jalessi Re: WidgitMaster's Largest... 03-30-2014, 09:22 PM
Bubba Re: WidgitMaster's Largest... 03-30-2014, 09:24 PM
Dylwad Re: WidgitMaster's Largest... 03-30-2014, 09:38 PM
Jzarski Re: WidgitMaster's Largest... 03-31-2014, 05:38 AM
widgitmaster Re: WidgitMaster's Largest... 03-31-2014, 01:58 PM
widgitmaster Re: WidgitMaster's Largest... 03-31-2014, 02:28 PM
TOTALLYRC Re: WidgitMaster's Largest... 03-31-2014, 02:38 PM
widgitmaster Re: WidgitMaster's Largest... 03-31-2014, 03:50 PM
widgitmaster Re: WidgitMaster's Largest... 04-01-2014, 06:18 PM
CNCMAN172 Re: WidgitMaster's Largest... 04-01-2014, 08:21 PM
widgitmaster Re: WidgitMaster's Largest... 04-01-2014, 06:23 PM
kuroguy Re: WidgitMaster's Largest... 04-01-2014, 06:30 PM
widgitmaster Re: WidgitMaster's Largest... 04-01-2014, 06:44 PM
keebler303 Re: WidgitMaster's Largest... 04-01-2014, 08:24 PM
widgitmaster Re: WidgitMaster's Largest... 04-02-2014, 03:27 AM
CNCMAN172 Re: WidgitMaster's Largest... 04-02-2014, 02:10 PM
widgitmaster Re: WidgitMaster's Largest... 04-02-2014, 09:13 PM
widgitmaster Progress Report 04-02-2014, 09:29 PM
JerryBurks Re: Progress Report 04-03-2014, 05:33 AM
Dylwad Re: WidgitMaster's Largest... 04-03-2014, 06:03 AM
widgitmaster Re: WidgitMaster's Largest... 04-03-2014, 02:24 PM
Jason Marsha Re: WidgitMaster's Largest... 04-03-2014, 02:47 PM
Donny M. Carter Re: WidgitMaster's Largest... 04-06-2014, 02:02 AM
tinygiants Re: WidgitMaster's Largest... 04-06-2014, 02:13 AM
CarveOne Re: WidgitMaster's Largest... 05-12-2014, 08:18 PM
widgitmaster Re: WidgitMaster's Largest... 04-06-2014, 04:33 PM
widgitmaster Re: WidgitMaster's Largest... 04-06-2014, 04:51 PM
jalessi Re: WidgitMaster's Largest... 04-07-2014, 03:08 AM
widgitmaster Re: WidgitMaster's Largest... 04-11-2014, 06:14 PM
widgitmaster Re: WidgitMaster's Largest... 04-17-2014, 03:58 AM
Donny M. Carter Re: WidgitMaster's Largest... 04-17-2014, 02:17 PM
tauntdesigns Re: WidgitMaster's Largest... 04-17-2014, 04:17 AM
widgitmaster Curiosity got me thinking! 04-19-2014, 09:34 PM
keebler303 Re: WidgitMaster's Largest... 04-20-2014, 03:47 AM
dodger889 Re: WidgitMaster's Largest... 04-20-2014, 09:58 AM
Dylwad Re: WidgitMaster's Largest... 04-20-2014, 10:26 AM
widgitmaster Re: WidgitMaster's Largest... 04-20-2014, 05:23 PM
widgitmaster Re: WidgitMaster's Largest... 04-26-2014, 10:14 PM
groc426 Re: WidgitMaster's Largest... 04-27-2014, 04:42 AM
widgitmaster Re: WidgitMaster's Largest... 04-27-2014, 05:04 PM
widgitmaster Re: WidgitMaster's Largest... 04-30-2014, 03:43 AM
CNCMAN172 Re: WidgitMaster's Largest... 04-30-2014, 03:49 PM
widgitmaster Re: WidgitMaster's Largest... 04-30-2014, 05:29 PM
CarveOne Re: WidgitMaster's Largest... 05-18-2014, 09:54 PM
nlancaster Re: WidgitMaster's Largest... 04-30-2014, 06:54 PM
widgitmaster Re: WidgitMaster's Largest... 04-30-2014, 07:04 PM
CarveOne Re: WidgitMaster's Largest... 05-19-2014, 01:17 AM
bill south Re: WidgitMaster's Largest... 04-30-2014, 07:38 PM
widgitmaster Re: WidgitMaster's Largest... 04-30-2014, 10:16 PM
CNCMAN172 Re: WidgitMaster's Largest... 04-30-2014, 09:51 PM
widgitmaster Re: WidgitMaster's Largest... 04-30-2014, 10:03 PM
nlancaster Re: WidgitMaster's Largest... 04-30-2014, 10:39 PM
kuroguy Re: WidgitMaster's Largest... 05-01-2014, 03:13 AM
CarveOne Re: WidgitMaster's Largest... 05-28-2014, 01:38 AM
widgitmaster Re: WidgitMaster's Largest... 05-08-2014, 11:39 PM
widgitmaster Re: WidgitMaster's Largest... 05-13-2014, 12:46 AM
CarveOne Re: WidgitMaster's Largest... 05-29-2014, 07:41 PM
nlancaster Re: WidgitMaster's Largest... 05-13-2014, 12:55 AM
widgitmaster Re: WidgitMaster's Largest... 05-13-2014, 01:09 AM
CNCMAN172 Re: WidgitMaster's Largest... 05-13-2014, 01:37 AM
widgitmaster Re: WidgitMaster's Largest... 05-13-2014, 04:59 AM
Donny M. Carter Re: WidgitMaster's Largest... 05-13-2014, 01:46 PM
bill south Re: WidgitMaster's Largest... 05-13-2014, 02:23 PM
widgitmaster Re: WidgitMaster's Largest... 05-13-2014, 04:36 PM
ihavenofish Re: WidgitMaster's Largest... 05-13-2014, 05:36 PM
CNCMAN172 Re: WidgitMaster's Largest... 05-14-2014, 02:24 AM
keebler303 Re: WidgitMaster's Largest... 05-13-2014, 05:12 PM
tauntdesigns Re: WidgitMaster's Largest... 05-13-2014, 06:34 PM
CarveOne Re: WidgitMaster's Largest... 06-07-2014, 10:50 AM
bill south Re: WidgitMaster's Largest... 05-13-2014, 07:03 PM
widgitmaster Re: WidgitMaster's Largest... 05-13-2014, 08:17 PM
slowlearner Re: WidgitMaster's Largest... 05-14-2014, 12:03 AM
widgitmaster Re: WidgitMaster's Largest... 05-14-2014, 02:47 AM
widgitmaster Re: WidgitMaster's Largest... 05-14-2014, 04:34 AM
widgitmaster Re: WidgitMaster's Largest... 05-15-2014, 02:57 AM
CNCMAN172 Re: WidgitMaster's Largest... 05-15-2014, 11:44 AM
bill south Re: WidgitMaster's Largest... 05-15-2014, 02:31 PM
widgitmaster Re: WidgitMaster's Largest... 05-16-2014, 02:28 PM
widgitmaster Re: WidgitMaster's Largest... 05-15-2014, 04:20 PM
tauntdesigns Re: WidgitMaster's Largest... 05-16-2014, 12:32 AM
Khalid Re: WidgitMaster's Largest... 05-16-2014, 07:34 AM
widgitmaster Re: WidgitMaster's Largest... 05-16-2014, 02:09 PM
widgitmaster Re: WidgitMaster's Largest... 05-16-2014, 03:23 PM
widgitmaster Re: WidgitMaster's Largest... 05-18-2014, 08:55 PM
bill south Re: WidgitMaster's Largest... 05-19-2014, 02:02 PM
widgitmaster Re: WidgitMaster's Largest... 05-20-2014, 03:01 AM
paul3112 Re: WidgitMaster's Largest... 05-20-2014, 03:36 AM
widgitmaster Re: WidgitMaster's Largest... 05-20-2014, 04:35 AM
widgitmaster Re: WidgitMaster's Largest... 05-27-2014, 09:46 PM
jckstrthmghty Re: WidgitMaster's Largest... 05-27-2014, 10:06 PM
Khalid Re: WidgitMaster's Largest... 05-28-2014, 05:44 AM
widgitmaster Re: WidgitMaster's Largest... 05-28-2014, 11:30 PM
nlancaster Re: WidgitMaster's Largest... 05-29-2014, 01:17 AM
widgitmaster Re: WidgitMaster's Largest... 05-29-2014, 06:29 PM
bill south Re: WidgitMaster's Largest... 05-30-2014, 01:38 PM
widgitmaster Re: WidgitMaster's Largest... 05-30-2014, 06:53 PM
widgitmaster Re: WidgitMaster's Largest... 06-01-2014, 02:40 AM
Trotline Re: WidgitMaster's Largest... 06-01-2014, 05:30 AM
widgitmaster Re: WidgitMaster's Largest... 06-01-2014, 12:33 PM
widgitmaster Re: WidgitMaster's Largest... 06-02-2014, 06:45 PM
tauntdesigns Re: WidgitMaster's Largest... 06-02-2014, 08:16 PM
widgitmaster Re: WidgitMaster's Largest... 06-03-2014, 05:10 PM
widgitmaster Re: WidgitMaster's Largest... 06-07-2014, 04:44 AM
bhurts Re: WidgitMaster's Largest... 06-09-2014, 09:04 PM
widgitmaster Re: WidgitMaster's Largest... 06-14-2014, 08:51 PM
mactec54 Re: WidgitMaster's Largest... 06-14-2014, 10:03 PM
tauntdesigns Re: WidgitMaster's Largest... 06-14-2014, 10:09 PM
tauntdesigns Re: WidgitMaster's Largest... 06-14-2014, 10:14 PM
widgitmaster Re: WidgitMaster's Largest... 06-14-2014, 11:27 PM
CarveOne Re: WidgitMaster's Largest... 07-14-2014, 12:04 PM
mactec54 Re: WidgitMaster's Largest... 06-14-2014, 11:52 PM
tauntdesigns Re: WidgitMaster's Largest... 06-14-2014, 11:54 PM
mactec54 Re: WidgitMaster's Largest... 06-15-2014, 12:10 AM
tauntdesigns Re: WidgitMaster's Largest... 06-15-2014, 12:28 AM
mactec54 Re: WidgitMaster's Largest... 06-15-2014, 12:39 AM
widgitmaster Re: WidgitMaster's Largest... 06-15-2014, 12:47 AM
tauntdesigns Re: WidgitMaster's Largest... 06-15-2014, 01:04 AM
mactec54 Re: WidgitMaster's Largest... 06-15-2014, 01:14 AM
widgitmaster Re: WidgitMaster's Largest... 06-15-2014, 01:30 AM
mactec54 Re: WidgitMaster's Largest... 06-15-2014, 01:49 AM
aarggh Re: WidgitMaster's Largest... 07-31-2014, 05:13 AM
zer0fighter Re: WidgitMaster's Largest... 06-15-2014, 05:41 PM
widgitmaster Re: WidgitMaster's Largest... 06-15-2014, 10:17 PM
widgitmaster Re: WidgitMaster's Largest... 06-15-2014, 10:20 PM
zer0fighter Re: WidgitMaster's Largest... 06-16-2014, 01:08 AM
widgitmaster Re: WidgitMaster's Largest... 06-25-2014, 04:13 PM
paul3112 Re: WidgitMaster's Largest... 06-25-2014, 04:27 PM
widgitmaster Re: WidgitMaster's Largest... 06-25-2014, 04:47 PM
paul3112 Re: WidgitMaster's Largest... 06-25-2014, 04:52 PM
paul3112 Re: WidgitMaster's Largest... 06-25-2014, 04:59 PM
Dylwad Re: WidgitMaster's Largest... 06-26-2014, 12:02 AM
Dylwad Re: WidgitMaster's Largest... 06-26-2014, 12:09 AM
paul3112 Re: WidgitMaster's Largest... 06-26-2014, 12:38 AM
paul3112 Re: WidgitMaster's Largest... 06-26-2014, 12:43 AM
ger21 Re: WidgitMaster's Largest... 06-26-2014, 02:57 PM
widgitmaster Re: WidgitMaster's Largest... 06-28-2014, 02:43 PM
BuckNaked31 Re: WidgitMaster's Largest... 06-28-2014, 03:25 PM
paul3112 Re: WidgitMaster's Largest... 06-28-2014, 03:33 PM
mactec54 Re: WidgitMaster's Largest... 06-28-2014, 03:53 PM
ger21 Re: WidgitMaster's Largest... 06-28-2014, 04:13 PM
widgitmaster Re: WidgitMaster's Largest... 07-05-2014, 03:05 AM
paul3112 Re: WidgitMaster's Largest... 07-05-2014, 04:57 AM
widgitmaster Re: WidgitMaster's Largest... 07-05-2014, 12:59 PM
paul3112 Re: WidgitMaster's Largest... 07-05-2014, 01:28 PM
widgitmaster Re: WidgitMaster's Largest... 07-13-2014, 05:56 PM
tauntdesigns Re: WidgitMaster's Largest... 07-13-2014, 08:24 PM
cd_edwards Re: WidgitMaster's Largest... 07-18-2014, 12:54 AM
widgitmaster Re: WidgitMaster's Largest... 07-19-2014, 04:54 AM
widgitmaster Re: WidgitMaster's Largest... 07-21-2014, 03:18 AM
CNCMAN172 Re: WidgitMaster's Largest... 07-21-2014, 01:26 PM
Jason Marsha Re: WidgitMaster's Largest... 07-22-2014, 02:07 AM
epineh Re: WidgitMaster's Largest... 07-23-2014, 11:14 AM
widgitmaster Re: WidgitMaster's Largest... 07-30-2014, 01:04 AM
dodger889 Re: WidgitMaster's Largest... 07-30-2014, 02:10 AM
widgitmaster Re: WidgitMaster's Largest... 07-30-2014, 02:32 AM
dodger889 Re: WidgitMaster's Largest... 07-30-2014, 02:51 AM
widgitmaster Re: WidgitMaster's Largest... 07-30-2014, 05:30 AM
tauntdesigns Re: WidgitMaster's Largest... 07-31-2014, 02:09 AM
widgitmaster Re: WidgitMaster's Largest... 08-01-2014, 04:33 AM
widgitmaster Re: WidgitMaster's Largest... 08-01-2014, 05:05 AM
widgitmaster Re: WidgitMaster's Largest... 08-02-2014, 08:30 PM
InMesh Re: WidgitMaster's Largest... 08-02-2014, 10:00 PM
widgitmaster Re: WidgitMaster's Largest... 08-04-2014, 11:14 PM
paul3112 Re: WidgitMaster's Largest... 08-05-2014, 01:07 AM
widgitmaster Re: WidgitMaster's Largest... 08-05-2014, 02:53 AM
paul3112 Re: WidgitMaster's Largest... 08-05-2014, 05:06 AM
Miata2k Re: WidgitMaster's Largest... 12-15-2014, 11:40 PM
CNCMAN172 Re: WidgitMaster's Largest... 08-05-2014, 12:40 PM
widgitmaster Re: WidgitMaster's Largest... 08-05-2014, 01:11 PM
widgitmaster Re: WidgitMaster's Largest... 08-05-2014, 01:42 PM
widgitmaster Re: WidgitMaster's Largest... 08-07-2014, 01:48 AM
CNCMAN172 Re: WidgitMaster's Largest... 08-21-2014, 01:27 PM
tauntdesigns Re: WidgitMaster's Largest... 08-12-2014, 04:59 PM
cd_edwards Re: WidgitMaster's Largest... 08-13-2014, 02:38 AM
widgitmaster Re: WidgitMaster's Largest... 08-13-2014, 11:01 PM
Dirty Engineer Re: WidgitMaster's Largest... 08-21-2014, 04:26 AM
bill south Re: WidgitMaster's Largest... 08-21-2014, 01:14 PM
widgitmaster Re: WidgitMaster's Largest... 08-21-2014, 03:29 PM
ger21 Re: WidgitMaster's Largest... 08-21-2014, 04:42 PM
widgitmaster Re: WidgitMaster's Largest... 08-22-2014, 01:05 AM
bill south Re: WidgitMaster's Largest... 08-22-2014, 02:06 PM
Alan XR8 Re: WidgitMaster's Largest... 08-22-2014, 02:13 PM
widgitmaster Re: WidgitMaster's Largest... 08-22-2014, 11:02 PM
widgitmaster Re: WidgitMaster's Largest... 08-23-2014, 02:22 AM
tauntdesigns Re: WidgitMaster's Largest... 08-26-2014, 01:34 AM
widgitmaster Re: WidgitMaster's Largest... 09-01-2014, 02:23 AM
widgitmaster Re: WidgitMaster's Largest... 09-02-2014, 01:43 AM
Alan XR8 Re: WidgitMaster's Largest... 09-02-2014, 11:53 AM
widgitmaster Re: WidgitMaster's Largest... 09-02-2014, 11:42 PM
Bubba Re: WidgitMaster's Largest... 09-02-2014, 11:46 PM
tauntdesigns Re: WidgitMaster's Largest... 09-03-2014, 02:43 AM
bill south Re: WidgitMaster's Largest... 09-03-2014, 01:14 PM
widgitmaster Re: WidgitMaster's Largest... 09-11-2014, 10:21 PM
tinygiants Re: WidgitMaster's Largest... 09-12-2014, 01:41 AM
Dirty Engineer Re: WidgitMaster's Largest... 09-12-2014, 05:19 AM
widgitmaster Re: WidgitMaster's Largest... 09-12-2014, 04:04 PM
bill south Re: WidgitMaster's Largest... 09-12-2014, 07:18 PM
aarggh Re: WidgitMaster's Largest... 09-13-2014, 02:58 AM
Jason Marsha Re: WidgitMaster's Largest... 09-13-2014, 12:45 PM
widgitmaster Re: WidgitMaster's Largest... 09-13-2014, 04:57 PM
Alan XR8 Re: WidgitMaster's Largest... 09-13-2014, 05:11 PM
Jason Marsha Re: WidgitMaster's Largest... 09-14-2014, 11:51 AM
TOTALLYRC Re: WidgitMaster's Largest... 09-15-2014, 12:02 PM
CNC-Joe Re: WidgitMaster's Largest... 09-20-2014, 04:58 PM
widgitmaster Re: WidgitMaster's Largest... 09-21-2014, 02:09 PM
widgitmaster Re: WidgitMaster's Largest... 09-21-2014, 02:28 PM
Alan XR8 Re: WidgitMaster's Largest... 09-21-2014, 05:33 PM
widgitmaster Re: WidgitMaster's Largest... 09-21-2014, 07:00 PM
Black Forest Re: WidgitMaster's Largest... 12-02-2017, 05:50 PM
widgitmaster Re: WidgitMaster's Largest... 12-02-2017, 09:10 PM
Black Forest Re: WidgitMaster's Largest... 12-02-2017, 10:22 PM
bill south Re: WidgitMaster's Largest... 09-22-2014, 02:05 PM
BuckNaked31 Re: WidgitMaster's Largest... 09-22-2014, 04:36 PM
nlancaster Re: WidgitMaster's Largest... 09-23-2014, 03:52 AM
widgitmaster Re: WidgitMaster's Largest... 10-01-2014, 11:30 AM
Alan XR8 Re: WidgitMaster's Largest... 10-01-2014, 12:08 PM
widgitmaster Re: WidgitMaster's Largest... 10-04-2014, 11:51 PM
ClaudioG Re: WidgitMaster's Largest... 10-05-2014, 06:01 AM
widgitmaster Re: WidgitMaster's Largest... 10-05-2014, 01:03 PM
widgitmaster Re: WidgitMaster's Largest... 10-20-2014, 09:27 PM
Dirty Engineer Re: WidgitMaster's Largest... 10-21-2014, 02:18 AM
widgitmaster Re: WidgitMaster's Largest... 10-30-2014, 07:09 PM
bill south Re: WidgitMaster's Largest... 10-30-2014, 07:52 PM
widgitmaster Re: WidgitMaster's Largest... 10-30-2014, 11:22 PM
CNCMAN172 Re: WidgitMaster's Largest... 10-30-2014, 09:02 PM
bill south Re: WidgitMaster's Largest... 10-31-2014, 06:09 PM
widgitmaster Re: WidgitMaster's Largest... 11-11-2014, 12:48 PM
Bubba Re: WidgitMaster's Largest... 11-11-2014, 02:11 PM
bill south Re: WidgitMaster's Largest... 11-11-2014, 02:15 PM
widgitmaster Re: WidgitMaster's Largest... 11-27-2014, 01:45 PM
Bubba Re: WidgitMaster's Largest... 11-27-2014, 02:02 PM
widgitmaster Re: WidgitMaster's Largest... 12-16-2014, 01:02 AM
Miata2k Re: WidgitMaster's Largest... 12-17-2014, 01:15 AM
aarggh Re: WidgitMaster's Largest... 12-17-2014, 03:20 AM
Bubba Re: WidgitMaster's Largest... 12-17-2014, 03:35 AM
widgitmaster Re: WidgitMaster's Largest... 12-17-2014, 04:09 AM
widgitmaster Re: WidgitMaster's Largest... 02-12-2015, 08:34 PM
Alan XR8 Re: WidgitMaster's Largest... 02-12-2015, 10:48 PM
tinygiants Re: WidgitMaster's Largest... 02-13-2015, 03:16 AM
widgitmaster Re: WidgitMaster's Largest... 04-11-2015, 11:27 PM
CarveOne Re: WidgitMaster's Largest... 11-27-2015, 02:35 PM
widgitmaster Re: WidgitMaster's Largest... 11-28-2015, 03:09 AM
CarveOne Re: WidgitMaster's Largest... 11-28-2015, 01:55 PM
widgitmaster Re: WidgitMaster's Largest... 11-28-2015, 03:13 AM
CarveOne Re: WidgitMaster's Largest... 11-28-2015, 02:03 PM
widgitmaster Re: WidgitMaster's Largest... 04-12-2015, 09:07 PM
ger21 Re: WidgitMaster's Largest... 04-12-2015, 10:32 PM
widgitmaster Re: WidgitMaster's Largest... 04-12-2015, 10:49 PM
ger21 Re: WidgitMaster's Largest... 07-12-2015, 08:42 PM
bhurts Re: WidgitMaster's Largest... 04-12-2015, 11:20 PM
widgitmaster Re: WidgitMaster's Largest... 07-07-2015, 11:25 PM
Jason Marsha Re: WidgitMaster's Largest... 07-12-2015, 12:39 PM
widgitmaster Re: WidgitMaster's Largest... 07-15-2015, 01:17 AM
widgitmaster Re: WidgitMaster's Largest... 07-15-2015, 01:08 AM
widgitmaster Re: WidgitMaster's Largest... 07-15-2015, 01:32 AM
widgitmaster Re: WidgitMaster's Largest... 07-15-2015, 01:43 AM
cd_edwards Re: WidgitMaster's Largest... 07-15-2015, 03:01 AM
widgitmaster Re: WidgitMaster's Largest... 07-16-2015, 08:37 PM
widgitmaster Re: WidgitMaster's Largest... 07-16-2015, 09:46 PM
jalessi Re: WidgitMaster's Largest... 07-17-2015, 02:02 AM
bill south Re: WidgitMaster's Largest... 07-17-2015, 02:51 PM
widgitmaster Re: WidgitMaster's Largest... 07-17-2015, 09:02 PM
widgitmaster Re: WidgitMaster's Largest... 08-08-2015, 10:16 PM
aarggh Re: WidgitMaster's Largest... 08-11-2015, 10:53 AM
widgitmaster Re: WidgitMaster's Largest... 08-22-2015, 02:15 AM
Jason Marsha Re: WidgitMaster's Largest... 08-22-2015, 11:25 PM
widgitmaster Re: WidgitMaster's Largest... 08-23-2015, 03:01 PM
cd_edwards Re: WidgitMaster's Largest... 08-22-2015, 11:59 PM
widgitmaster Re: WidgitMaster's Largest... 08-23-2015, 03:13 PM
widgitmaster Re: WidgitMaster's Largest... 08-30-2015, 04:27 PM
widgitmaster It's Time for an UPGRADE !! 09-24-2015, 01:33 AM
aarggh Re: It's Time for an UPGRADE... 09-24-2015, 04:40 AM
widgitmaster Re: It's Time for an UPGRADE... 09-24-2015, 04:52 AM
kuroguy Re: WidgitMaster's Largest... 09-24-2015, 02:00 PM
widgitmaster Re: WidgitMaster's Largest... 09-26-2015, 03:27 AM
widgitmaster Re: WidgitMaster's Largest... 09-26-2015, 04:00 AM
nlancaster Re: WidgitMaster's Largest... 09-26-2015, 07:39 AM
widgitmaster Re: WidgitMaster's Largest... 09-27-2015, 12:34 AM
bill south Re: WidgitMaster's Largest... 09-30-2015, 03:43 PM
widgitmaster Re: WidgitMaster's Largest... 10-01-2015, 01:54 PM
widgitmaster Re: WidgitMaster's Largest... 11-26-2015, 02:32 PM
CNCMAN172 Re: WidgitMaster's Largest... 11-26-2015, 04:19 PM
widgitmaster Re: WidgitMaster's Largest... 11-26-2015, 05:19 PM
Bubba Re: WidgitMaster's Largest... 11-26-2015, 02:56 PM
widgitmaster Re: WidgitMaster's Largest... 12-19-2015, 06:55 PM
mactec54 Re: WidgitMaster's Largest... 12-19-2015, 10:19 PM
bill south Re: WidgitMaster's Largest... 12-21-2015, 08:32 PM
bill south Re: WidgitMaster's Largest... 12-22-2015, 08:02 PM
widgitmaster Re: WidgitMaster's Largest... 12-23-2015, 05:13 AM
widgitmaster Re: WidgitMaster's Largest... 01-18-2016, 06:41 PM
onecut Re: WidgitMaster's Largest... 04-13-2016, 03:17 PM
rodrigomartins Re: WidgitMaster's Largest... 04-13-2016, 08:52 PM
widgitmaster Re: WidgitMaster's Largest... 04-19-2016, 04:09 AM
ger21 Re: WidgitMaster's Largest... 04-19-2016, 01:02 PM
CarveOne Re: WidgitMaster's Largest... 04-20-2016, 10:49 AM
bill south Re: WidgitMaster's Largest... 04-20-2016, 03:36 PM
widgitmaster Re: WidgitMaster's Largest... 04-23-2016, 03:20 AM
Bubba Re: WidgitMaster's Largest... 04-23-2016, 01:30 PM
widgitmaster Re: WidgitMaster's Largest... 04-24-2016, 01:09 AM
Bubba Re: WidgitMaster's Largest... 04-24-2016, 02:08 AM
Alan XR8 Re: WidgitMaster's Largest... 04-24-2016, 10:09 PM
widgitmaster Re: WidgitMaster's Largest... 04-25-2016, 02:45 AM
Alan XR8 Re: WidgitMaster's Largest... 04-25-2016, 03:26 AM
widgitmaster Re: WidgitMaster's Largest... 05-16-2016, 02:18 PM
Alan XR8 Re: WidgitMaster's Largest... 05-16-2016, 02:37 PM
CNCMAN172 Re: WidgitMaster's Largest... 05-16-2016, 02:45 PM
widgitmaster Re: WidgitMaster's Largest... 08-02-2016, 05:40 PM
ViperTX Re: WidgitMaster's Largest... 08-02-2016, 05:50 PM
rustamd Re: WidgitMaster's Largest... 08-04-2016, 11:54 AM
widgitmaster Re: WidgitMaster's Largest... 08-05-2016, 03:21 AM
rustamd Re: WidgitMaster's Largest... 08-05-2016, 03:40 AM
rustamd Re: WidgitMaster's Largest... 08-05-2016, 03:48 AM
Bubba Re: WidgitMaster's Largest... 08-02-2016, 05:54 PM
CNCMAN172 Re: WidgitMaster's Largest... 08-02-2016, 08:18 PM
widgitmaster Re: WidgitMaster's Largest... 08-04-2016, 03:41 AM
CNCMAN172 Re: WidgitMaster's Largest... 08-04-2016, 01:35 PM
bill south Re: WidgitMaster's Largest... 08-04-2016, 01:47 PM
paul3112 Re: WidgitMaster's Largest... 08-04-2016, 08:43 PM
widgitmaster Re: WidgitMaster's Largest... 08-05-2016, 03:13 AM
widgitmaster Re: WidgitMaster's Largest... 08-08-2016, 10:46 PM
onecut Re: WidgitMaster's Largest... 08-11-2016, 10:11 AM
widgitmaster Re: WidgitMaster's Largest... 08-12-2016, 01:02 AM
CNCMAN172 Re: WidgitMaster's Largest... 09-20-2016, 01:53 PM
widgitmaster Re: WidgitMaster's Largest... 09-20-2016, 01:42 PM
Bubba Re: WidgitMaster's Largest... 09-20-2016, 01:53 PM
widgitmaster Re: WidgitMaster's Largest... 09-20-2016, 01:58 PM
greenb_60097 Re: WidgitMaster's Largest... 10-13-2016, 08:06 PM
widgitmaster Re: WidgitMaster's Largest... 10-14-2016, 02:48 AM
greenb_60097 Re: WidgitMaster's Largest... 10-14-2016, 05:04 AM
widgitmaster Re: WidgitMaster's Largest... 05-20-2017, 09:50 PM
handlewanker Re: WidgitMaster's Largest... 11-20-2019, 05:27 AM
Bubba Re: WidgitMaster's Largest... 05-20-2017, 09:59 PM
jalessi Re: WidgitMaster's Largest... 05-20-2017, 10:01 PM
widgitmaster Re: WidgitMaster's Largest... 05-20-2017, 10:15 PM
epineh Re: WidgitMaster's Largest... 05-21-2017, 01:31 AM
widgitmaster Re: WidgitMaster's Largest... 05-21-2017, 01:41 PM
fretman_2 Re: WidgitMaster's Largest... 05-22-2017, 09:18 PM
widgitmaster Re: WidgitMaster's Largest... 05-22-2017, 10:33 PM
RotarySMP Re: WidgitMaster's Largest... 05-23-2017, 08:49 AM
widgitmaster Re: WidgitMaster's Largest... 05-23-2017, 12:57 PM
louieatienza Re: WidgitMaster's Largest... 05-25-2017, 07:09 PM
bill south Re: WidgitMaster's Largest... 05-23-2017, 01:40 PM
widgitmaster Re: WidgitMaster's Largest... 05-23-2017, 02:26 PM
CNCMAN172 Re: WidgitMaster's Largest... 05-23-2017, 06:43 PM
widgitmaster Re: WidgitMaster's Largest... 05-24-2017, 01:01 AM
jckstrthmghty Re: WidgitMaster's Largest... 05-24-2017, 03:35 PM
widgitmaster Re: WidgitMaster's Largest... 05-24-2017, 05:31 PM
Khalid Re: WidgitMaster's Largest... 05-24-2017, 05:42 AM
widgitmaster Re: WidgitMaster's Largest... 05-24-2017, 10:43 AM
MajorTendonitis Re: WidgitMaster's Largest... 05-24-2017, 08:43 PM
widgitmaster Re: WidgitMaster's Largest... 05-25-2017, 02:25 PM
widgitmaster Re: WidgitMaster's Largest... 06-14-2017, 03:37 PM
CNCMAN172 Re: WidgitMaster's Largest... 06-14-2017, 04:28 PM
widgitmaster Re: WidgitMaster's Largest... 06-14-2017, 06:12 PM
bill south Re: WidgitMaster's Largest... 06-14-2017, 06:29 PM
widgitmaster Re: WidgitMaster's Largest... 06-14-2017, 08:32 PM
MajorTendonitis Re: WidgitMaster's Largest... 06-15-2017, 12:59 AM
widgitmaster Re: WidgitMaster's Largest... 06-15-2017, 02:41 PM
MajorTendonitis Re: WidgitMaster's Largest... 06-16-2017, 11:57 PM
widgitmaster Re: WidgitMaster's Largest... 07-05-2017, 07:14 PM
stragenmitsuko Re: WidgitMaster's Largest... 07-08-2017, 04:58 PM
widgitmaster Re: WidgitMaster's Largest... 07-10-2017, 12:42 PM
Azalin Re: WidgitMaster's Largest... 07-05-2017, 11:14 PM
widgitmaster Re: WidgitMaster's Largest... 07-06-2017, 02:20 AM
gregoose Re: WidgitMaster's Largest... 07-06-2017, 02:47 AM
widgitmaster Re: WidgitMaster's Largest... 07-06-2017, 12:18 PM
Azalin Re: WidgitMaster's Largest... 07-06-2017, 07:14 AM
widgitmaster Re: WidgitMaster's Largest... 07-07-2017, 04:00 AM
widgitmaster Re: WidgitMaster's Largest... 07-08-2017, 02:05 PM
Bubba Re: WidgitMaster's Largest... 07-08-2017, 02:42 PM
widgitmaster Re: WidgitMaster's Largest... 07-10-2017, 12:33 PM
bill south Re: WidgitMaster's Largest... 07-11-2017, 03:22 PM
widgitmaster Re: WidgitMaster's Largest... 07-14-2017, 11:52 AM
widgitmaster Re: WidgitMaster's Largest... 07-15-2017, 09:31 PM
stragenmitsuko Re: WidgitMaster's Largest... 07-15-2017, 11:40 PM
widgitmaster Re: WidgitMaster's Largest... 10-03-2017, 01:48 PM
stragenmitsuko Re: WidgitMaster's Largest... 10-03-2017, 03:04 PM
widgitmaster Re: WidgitMaster's Largest... 10-03-2017, 10:15 PM
skrubol Re: WidgitMaster's Largest... 12-06-2017, 08:23 PM
Bubba Re: WidgitMaster's Largest... 07-15-2017, 09:52 PM
widgitmaster Re: WidgitMaster's Largest... 07-15-2017, 10:19 PM
widgitmaster Re: WidgitMaster's Largest... 07-18-2017, 09:56 PM
TOTALLYRC Re: WidgitMaster's Largest... 07-20-2017, 12:20 AM
widgitmaster Re: WidgitMaster's Largest... 07-20-2017, 03:33 AM
widgitmaster Re: WidgitMaster's Largest... 07-20-2017, 08:19 PM
widgitmaster Re: WidgitMaster's Largest... 07-22-2017, 09:42 PM
fretman_2 Re: WidgitMaster's Largest... 07-25-2017, 02:42 PM
widgitmaster Re: WidgitMaster's Largest... 07-30-2017, 04:48 AM
CNCMAN172 Re: WidgitMaster's Largest... 07-30-2017, 01:50 PM
widgitmaster Re: WidgitMaster's Largest... 08-01-2017, 12:11 AM
widgitmaster Re: WidgitMaster's Largest... 08-01-2017, 12:49 AM
widgitmaster Re: WidgitMaster's Largest... 08-01-2017, 12:53 AM
Tomcat104 Re: WidgitMaster's Largest... 08-13-2017, 10:53 PM
widgitmaster Re: WidgitMaster's Largest... 08-14-2017, 12:33 AM
Bubba Re: WidgitMaster's Largest... 08-01-2017, 01:09 AM
bill south Re: WidgitMaster's Largest... 08-02-2017, 02:13 PM
widgitmaster Re: WidgitMaster's Largest... 08-02-2017, 04:39 PM
widgitmaster Re: WidgitMaster's Largest... 08-05-2017, 12:35 PM
Bubba Re: WidgitMaster's Largest... 08-05-2017, 12:45 PM
widgitmaster Re: WidgitMaster's Largest... 08-08-2017, 09:04 PM
Bubba Re: WidgitMaster's Largest... 08-08-2017, 09:33 PM
widgitmaster Re: WidgitMaster's Largest... 08-08-2017, 11:04 PM
Bubba Re: WidgitMaster's Largest... 08-08-2017, 11:07 PM
widgitmaster Re: WidgitMaster's Largest... 08-08-2017, 11:28 PM
rocketflier Re: WidgitMaster's Largest... 08-09-2017, 12:51 AM
widgitmaster Re: WidgitMaster's Largest... 08-13-2017, 04:23 AM
Bubba Re: WidgitMaster's Largest... 08-13-2017, 01:01 PM
widgitmaster Re: WidgitMaster's Largest... 08-14-2017, 12:32 AM
Bubba Re: WidgitMaster's Largest... 08-14-2017, 12:40 AM
widgitmaster Re: WidgitMaster's Largest... 08-14-2017, 02:09 PM
Bubba Re: WidgitMaster's Largest... 08-14-2017, 02:14 PM
widgitmaster Re: WidgitMaster's Largest... 08-18-2017, 03:49 PM
Tomcat104 Re: WidgitMaster's Largest... 08-18-2017, 04:17 PM
Bubba Re: WidgitMaster's Largest... 08-18-2017, 03:58 PM
widgitmaster Re: WidgitMaster's Largest... 08-18-2017, 04:30 PM
widgitmaster Re: WidgitMaster's Largest... 08-23-2017, 11:45 PM
bill south Re: WidgitMaster's Largest... 08-24-2017, 01:44 PM
widgitmaster Re: WidgitMaster's Largest... 08-24-2017, 06:08 PM
onecut Re: WidgitMaster's Largest... 08-24-2017, 11:58 PM
stragenmitsuko Re: WidgitMaster's Largest... 08-25-2017, 07:06 PM
widgitmaster Re: WidgitMaster's Largest... 08-28-2017, 01:01 PM
widgitmaster Re: WidgitMaster's Largest... 08-25-2017, 03:15 PM
Bubba Re: WidgitMaster's Largest... 08-25-2017, 03:32 PM
widgitmaster Re: WidgitMaster's Largest... 08-25-2017, 05:20 PM
Bubba Re: WidgitMaster's Largest... 08-25-2017, 05:27 PM
widgitmaster Re: WidgitMaster's Largest... 09-05-2017, 08:31 PM
Bubba Re: WidgitMaster's Largest... 09-05-2017, 09:55 PM
widgitmaster Re: WidgitMaster's Largest... 09-13-2017, 04:31 AM
widgitmaster Re: WidgitMaster's Largest... 09-18-2017, 01:42 AM
Bubba Re: WidgitMaster's Largest... 09-18-2017, 01:54 AM
widgitmaster WidgitMaster's Largest Steel... 09-18-2017, 12:33 PM
fretman_2 Re: WidgitMaster's Largest... 09-21-2017, 03:29 PM
widgitmaster Re: WidgitMaster's Largest... 09-25-2017, 02:31 AM
ihavenofish Re: WidgitMaster's Largest... 09-27-2017, 07:39 PM
Bubba Re: WidgitMaster's Largest... 09-25-2017, 01:42 PM
widgitmaster Re: WidgitMaster's Largest... 09-27-2017, 01:50 AM
Bubba Re: WidgitMaster's Largest... 09-27-2017, 01:54 AM
widgitmaster Re: WidgitMaster's Largest... 09-27-2017, 02:06 AM
widgitmaster Re: WidgitMaster's Largest... 09-27-2017, 02:21 AM
widgitmaster Re: WidgitMaster's Largest... 09-28-2017, 03:32 AM
bill south Re: WidgitMaster's Largest... 09-28-2017, 01:48 PM
widgitmaster Re: WidgitMaster's Largest... 09-28-2017, 02:38 PM
widgitmaster Re: WidgitMaster's Largest... 09-30-2017, 01:28 PM
widgitmaster Re: WidgitMaster's Largest... 10-02-2017, 07:20 PM
Bubba Re: WidgitMaster's Largest... 10-02-2017, 07:55 PM
widgitmaster Re: WidgitMaster's Largest... 10-04-2017, 03:15 AM
Bubba Re: WidgitMaster's Largest... 10-04-2017, 12:36 PM
bill south Re: WidgitMaster's Largest... 10-04-2017, 02:40 PM
widgitmaster Re: WidgitMaster's Largest... 10-04-2017, 03:14 PM
widgitmaster Re: WidgitMaster's Largest... 10-17-2017, 12:17 PM
widgitmaster Re: WidgitMaster's Largest... 10-25-2017, 03:00 AM
Bubba Re: WidgitMaster's Largest... 10-25-2017, 12:22 PM
stragenmitsuko Re: WidgitMaster's Largest... 10-25-2017, 02:37 PM
widgitmaster Re: WidgitMaster's Largest... 10-25-2017, 03:21 PM
widgitmaster Re: WidgitMaster's Largest... 10-25-2017, 03:03 PM
widgitmaster Re: WidgitMaster's Largest... 10-27-2017, 12:22 PM
Bubba Re: WidgitMaster's Largest... 10-27-2017, 01:38 PM
widgitmaster Re: WidgitMaster's Largest... 11-05-2017, 01:06 PM
Bubba Re: WidgitMaster's Largest... 11-05-2017, 01:22 PM
widgitmaster Re: WidgitMaster's Largest... 11-05-2017, 03:24 PM
widgitmaster Re: WidgitMaster's Largest... 11-07-2017, 12:35 PM
ZipSnipe Re: WidgitMaster's Largest... 11-05-2017, 03:36 PM
widgitmaster Re: WidgitMaster's Largest... 11-06-2017, 08:32 PM
widgitmaster Re: WidgitMaster's Largest... 11-07-2017, 02:42 PM
widgitmaster Re: WidgitMaster's Largest... 11-10-2017, 12:36 AM
widgitmaster Re: WidgitMaster's Largest... 11-10-2017, 12:38 AM
Bubba Re: WidgitMaster's Largest... 11-10-2017, 12:50 AM
widgitmaster Re: WidgitMaster's Largest... 11-10-2017, 01:45 PM
widgitmaster Re: WidgitMaster's Largest... 11-11-2017, 12:15 PM
Bubba Re: WidgitMaster's Largest... 11-11-2017, 01:44 PM
widgitmaster Re: WidgitMaster's Largest... 11-16-2017, 01:06 AM
Bubba Re: WidgitMaster's Largest... 11-16-2017, 01:19 AM
widgitmaster Re: WidgitMaster's Largest... 11-16-2017, 01:23 AM
widgitmaster Re: WidgitMaster's Largest... 11-19-2017, 04:05 AM
widgitmaster Re: WidgitMaster's Largest... 11-22-2017, 01:27 PM
Bubba Re: WidgitMaster's Largest... 11-22-2017, 02:28 PM
widgitmaster Re: WidgitMaster's Largest... 11-23-2017, 11:52 PM
Bubba Re: WidgitMaster's Largest... 11-24-2017, 01:52 PM
widgitmaster Re: WidgitMaster's Largest... 11-27-2017, 08:45 PM
TOTALLYRC Re: WidgitMaster's Largest... 11-29-2017, 02:58 AM
widgitmaster Re: WidgitMaster's Largest... 11-29-2017, 03:33 AM
louieatienza Re: WidgitMaster's Largest... 11-29-2017, 02:47 PM
widgitmaster Re: WidgitMaster's Largest... 11-29-2017, 05:15 PM
widgitmaster Re: WidgitMaster's Largest... 12-01-2017, 03:18 AM
Bubba Re: WidgitMaster's Largest... 12-01-2017, 02:05 PM
widgitmaster Re: WidgitMaster's Largest... 12-01-2017, 06:52 PM
widgitmaster Re: WidgitMaster's Largest... 12-02-2017, 02:02 PM
Bubba Re: WidgitMaster's Largest... 12-02-2017, 02:25 PM
Khalid Re: WidgitMaster's Largest... 12-04-2017, 02:03 PM
widgitmaster Re: WidgitMaster's Largest... 12-06-2017, 06:07 PM
stragenmitsuko Re: WidgitMaster's Largest... 12-06-2017, 06:24 PM
widgitmaster Re: WidgitMaster's Largest... 12-06-2017, 07:04 PM
skrubol Re: WidgitMaster's Largest... 12-06-2017, 08:13 PM
widgitmaster Re: WidgitMaster's Largest... 12-08-2017, 01:26 PM
Bubba Re: WidgitMaster's Largest... 12-08-2017, 01:42 PM
widgitmaster Re: WidgitMaster's Largest... 12-08-2017, 01:55 PM
widgitmaster Here is my NEW 2018 Harley... 12-08-2017, 03:28 PM
Bubba Re: WidgitMaster's Largest... 12-08-2017, 04:10 PM
bill south Re: WidgitMaster's Largest... 12-12-2017, 04:36 PM
widgitmaster Re: WidgitMaster's Largest... 12-12-2017, 04:52 PM
widgitmaster Re: WidgitMaster's Largest... 12-15-2017, 03:03 PM
Bubba Re: WidgitMaster's Largest... 12-15-2017, 03:17 PM
widgitmaster Re: WidgitMaster's Largest... 12-18-2017, 03:30 PM
Bubba Re: WidgitMaster's Largest... 12-18-2017, 04:58 PM
widgitmaster Re: WidgitMaster's Largest... 01-01-2018, 06:15 AM
Bubba Re: WidgitMaster's Largest... 01-01-2018, 01:55 PM
widgitmaster Re: WidgitMaster's Largest... 01-03-2018, 01:47 PM
Bubba Re: WidgitMaster's Largest... 01-03-2018, 02:18 PM
widgitmaster Re: WidgitMaster's Largest... 01-03-2018, 08:57 PM
Bubba Re: WidgitMaster's Largest... 01-03-2018, 09:27 PM
TOTALLYRC Re: WidgitMaster's Largest... 01-04-2018, 11:37 AM
widgitmaster Re: WidgitMaster's Largest... 01-04-2018, 01:13 PM
stragenmitsuko Re: WidgitMaster's Largest... 01-04-2018, 02:46 PM
widgitmaster Re: WidgitMaster's Largest... 01-04-2018, 05:35 PM
widgitmaster Re: WidgitMaster's Largest... 01-04-2018, 06:48 PM
TOTALLYRC Re: WidgitMaster's Largest... 01-05-2018, 12:44 PM
widgitmaster Re: WidgitMaster's Largest... 01-04-2018, 07:18 PM
TOTALLYRC Re: WidgitMaster's Largest... 01-04-2018, 08:06 PM
widgitmaster Re: WidgitMaster's Largest... 01-04-2018, 10:02 PM
widgitmaster Re: WidgitMaster's Largest... 01-05-2018, 01:31 PM
widgitmaster Re: WidgitMaster's Largest... 01-07-2018, 05:04 AM
Bubba Re: WidgitMaster's Largest... 01-07-2018, 01:28 PM
widgitmaster Re: WidgitMaster's Largest... 01-07-2018, 09:11 PM
TOTALLYRC Re: WidgitMaster's Largest... 01-07-2018, 11:48 PM
widgitmaster Re: WidgitMaster's Largest... 01-08-2018, 01:11 AM
TOTALLYRC Re: WidgitMaster's Largest... 01-08-2018, 11:13 AM
widgitmaster Re: WidgitMaster's Largest... 01-09-2018, 04:38 AM
louieatienza Re: WidgitMaster's Largest... 01-10-2018, 04:06 AM
TOTALLYRC Re: WidgitMaster's Largest... 01-09-2018, 12:15 PM
bill south Re: WidgitMaster's Largest... 01-09-2018, 02:34 PM
widgitmaster Re: WidgitMaster's Largest... 01-09-2018, 07:04 PM
shujaa Re: WidgitMaster's Largest... 02-23-2018, 01:45 PM
skrubol Re: WidgitMaster's Largest... 02-23-2018, 03:39 PM
widgitmaster Re: WidgitMaster's Largest... 01-10-2018, 01:43 PM
Bubba Re: WidgitMaster's Largest... 01-10-2018, 02:48 PM
widgitmaster Re: WidgitMaster's Largest... 01-10-2018, 08:09 PM
widgitmaster Re: WidgitMaster's Largest... 01-13-2018, 02:08 PM
widgitmaster Re: WidgitMaster's Largest... 01-13-2018, 09:31 PM
Bubba Re: WidgitMaster's Largest... 01-13-2018, 11:02 PM
widgitmaster Re: WidgitMaster's Largest... 01-14-2018, 12:41 AM
widgitmaster Re: WidgitMaster's Largest... 01-17-2018, 12:14 PM
widgitmaster Re: WidgitMaster's Largest... 01-24-2018, 04:09 AM
TOTALLYRC Re: WidgitMaster's Largest... 01-24-2018, 12:21 PM
Bubba Re: WidgitMaster's Largest... 01-24-2018, 01:41 PM
widgitmaster Re: WidgitMaster's Largest... 01-30-2018, 01:28 PM
louieatienza This will be awesome... 01-30-2018, 02:55 PM
widgitmaster Re: WidgitMaster's Largest... 02-04-2018, 10:14 PM
Bubba Re: WidgitMaster's Largest... 02-04-2018, 10:54 PM
widgitmaster Re: WidgitMaster's Largest... 02-04-2018, 11:25 PM
onecut Re: WidgitMaster's Largest... 02-06-2018, 02:28 PM
onecut Re: WidgitMaster's Largest... 02-16-2018, 01:45 AM
widgitmaster Re: WidgitMaster's Largest... 03-05-2018, 01:32 PM
Bubba Re: WidgitMaster's Largest... 03-05-2018, 01:42 PM
widgitmaster Re: WidgitMaster's Largest... 03-05-2018, 01:48 PM
widgitmaster Re: WidgitMaster's Largest... 03-06-2018, 06:38 AM
shujaa Hi widgit master That... 03-21-2018, 04:06 PM
widgitmaster Re: WidgitMaster's Largest... 03-22-2018, 12:54 PM
skrubol Re: WidgitMaster's Largest... 03-06-2018, 03:23 PM
widgitmaster Re: WidgitMaster's Largest... 03-06-2018, 05:38 PM
widgitmaster Re: WidgitMaster's Largest... 03-07-2018, 10:26 PM
Bubba Re: WidgitMaster's Largest... 03-08-2018, 12:52 PM
widgitmaster Re: WidgitMaster's Largest... 03-11-2018, 07:38 PM
widgitmaster Re: WidgitMaster's Largest... 03-12-2018, 03:16 PM
widgitmaster Re: WidgitMaster's Largest... 03-21-2018, 12:52 PM
widgitmaster Re: WidgitMaster's Largest... 03-25-2018, 02:01 PM
bill south Re: WidgitMaster's Largest... 03-27-2018, 02:46 PM
widgitmaster Re: WidgitMaster's Largest... 03-28-2018, 01:00 PM
shujaa I wish you a very quick and... 04-11-2018, 02:33 PM
skrubol Re: WidgitMaster's Largest... 04-11-2018, 03:22 PM
widgitmaster Re: WidgitMaster's Largest... 04-23-2018, 01:19 PM
epineh Re: WidgitMaster's Largest... 04-24-2018, 12:24 PM
widgitmaster Re: WidgitMaster's Largest... 04-24-2018, 02:26 PM
widgitmaster Re: WidgitMaster's Largest... 05-03-2018, 03:53 PM
Bubba Re: WidgitMaster's Largest... 05-03-2018, 04:31 PM
bill south Re: WidgitMaster's Largest... 05-03-2018, 07:01 PM
widgitmaster Re: WidgitMaster's Largest... 05-03-2018, 08:27 PM
widgitmaster Re: WidgitMaster's Largest... 05-20-2018, 02:47 PM
Bubba Re: WidgitMaster's Largest... 05-20-2018, 03:15 PM
skrubol Re: WidgitMaster's Largest... 05-21-2018, 03:38 PM
widgitmaster Re: WidgitMaster's Largest... 05-28-2018, 01:24 PM
Joe_Ohlandt Re: WidgitMaster's Largest... 06-08-2018, 12:11 AM
ViperTX Re: WidgitMaster's Largest... 06-08-2018, 09:42 PM
widgitmaster Re: WidgitMaster's Largest... 06-11-2018, 03:17 AM
widgitmaster Re: WidgitMaster's Largest... 06-11-2018, 03:15 AM
ViperTX Re: WidgitMaster's Largest... 06-11-2018, 03:39 AM
widgitmaster Re: WidgitMaster's Largest... 06-11-2018, 04:00 AM
widgitmaster Re: WidgitMaster's Largest... 06-11-2018, 04:06 AM
CarveOne Re: WidgitMaster's Largest... 09-06-2019, 08:39 PM
CarveOne Re: WidgitMaster's Largest... 09-06-2019, 08:55 PM
widgitmaster Re: WidgitMaster's Largest... 10-06-2019, 12:55 PM
Bubba Re: WidgitMaster's Largest... 06-11-2018, 11:57 AM
widgitmaster Re: WidgitMaster's Largest... 06-14-2018, 11:45 AM
Joe_Ohlandt Re: WidgitMaster's Largest... 06-15-2018, 08:52 PM
widgitmaster Re: WidgitMaster's Largest... 06-18-2018, 01:02 PM
mactec54 Re: WidgitMaster's Largest... 12-01-2018, 02:47 PM
widgitmaster Re: WidgitMaster's Largest... 06-19-2018, 01:41 PM
CarveOne Re: WidgitMaster's Largest... 10-08-2019, 08:50 PM
stragenmitsuko Re: WidgitMaster's Largest... 06-19-2018, 01:55 PM
widgitmaster Re: WidgitMaster's Largest... 06-19-2018, 02:04 PM
widgitmaster Re: WidgitMaster's Largest... 06-19-2018, 02:39 PM
skrubol Re: WidgitMaster's Largest... 06-19-2018, 02:59 PM
widgitmaster Re: WidgitMaster's Largest... 06-19-2018, 06:17 PM
CarveOne Re: WidgitMaster's Largest... 10-22-2019, 11:42 PM
widgitmaster Re: WidgitMaster's Largest... 07-16-2018, 04:47 PM
widgitmaster Re: WidgitMaster's Largest... 11-28-2018, 12:32 PM
Bubba Re: WidgitMaster's Largest... 11-28-2018, 02:02 PM
bill south Re: WidgitMaster's Largest... 11-29-2018, 12:15 PM
justCNCit Re: WidgitMaster's Largest... 11-30-2018, 05:50 PM
widgitmaster Re: WidgitMaster's Largest... 12-01-2018, 01:27 PM
mactec54 Re: WidgitMaster's Largest... 12-01-2018, 02:44 PM
justCNCit Re: WidgitMaster's Largest... 12-01-2018, 10:56 PM
widgitmaster Re: WidgitMaster's Largest... 12-03-2018, 01:43 PM
CarveOne Re: WidgitMaster's Largest... 11-20-2019, 01:54 AM
justCNCit Re: WidgitMaster's Largest... 12-03-2018, 06:56 PM
justCNCit Re: WidgitMaster's Largest... 12-03-2018, 09:36 PM
widgitmaster It’s a learning experience!... 12-04-2018, 01:49 AM
widgitmaster Re: WidgitMaster's Largest... 12-24-2018, 09:21 PM
Bubba Re: WidgitMaster's Largest... 12-24-2018, 09:26 PM
widgitmaster Re: WidgitMaster's Largest... 12-24-2018, 11:10 PM
bill south Re: WidgitMaster's Largest... 12-25-2018, 12:41 PM
justCNCit Re: WidgitMaster's Largest... 02-12-2019, 01:48 PM
widgitmaster Re: WidgitMaster's Largest... 02-12-2019, 02:16 PM
justCNCit Re: WidgitMaster's Largest... 02-12-2019, 04:37 PM
widgitmaster Re: WidgitMaster's Largest... 02-12-2019, 07:59 PM
widgitmaster Re: WidgitMaster's Largest... 03-09-2019, 02:01 PM
ViperTX Re: WidgitMaster's Largest... 03-09-2019, 06:28 PM
widgitmaster Re: WidgitMaster's Largest... 03-12-2019, 11:13 PM
justCNCit Re: WidgitMaster's Largest... 03-27-2019, 05:23 PM
widgitmaster Re: WidgitMaster's Largest... 03-28-2019, 03:31 AM
mactec54 Re: WidgitMaster's Largest... 10-09-2019, 04:02 PM
widgitmaster Re: WidgitMaster's Largest... 04-03-2019, 05:23 AM
ger21 Re: WidgitMaster's Largest... 08-31-2019, 03:28 PM
ger21 Re: WidgitMaster's Largest... 09-05-2019, 11:59 PM
widgitmaster Re: WidgitMaster's Largest... 10-07-2019, 01:10 PM
Bubba Re: WidgitMaster's Largest... 10-07-2019, 01:29 PM
Sunnychen Re: WidgitMaster's Largest... 10-10-2019, 02:50 AM
widgitmaster Re: WidgitMaster's Largest... 10-22-2019, 03:17 AM
Bubba Re: WidgitMaster's Largest... 10-22-2019, 01:54 PM
widgitmaster Re: WidgitMaster's Largest... 10-29-2019, 02:55 PM
Bubba Re: WidgitMaster's Largest... 10-29-2019, 03:21 PM
widgitmaster Can anyone tell me if Mach3... 11-14-2019, 11:44 PM
cd_edwards Re: Can anyone tell me if... 11-15-2019, 03:48 AM
Troncatore Re: Can anyone tell me if... 11-21-2019, 03:23 PM
cd_edwards Re: Can anyone tell me if... 12-06-2019, 02:36 AM
CarveOne Re: Can anyone tell me if... 11-16-2019, 02:51 PM
CarveOne Re: Can anyone tell me if... 01-22-2020, 01:38 PM
Bubba Re: WidgitMaster's Largest... 11-14-2019, 11:53 PM
widgitmaster Re: WidgitMaster's Largest... 11-15-2019, 03:24 AM
skrubol Re: WidgitMaster's Largest... 11-16-2019, 04:39 PM
widgitmaster Re: WidgitMaster's Largest... 11-19-2019, 03:22 PM
widgitmaster Re: WidgitMaster's Largest... 11-21-2019, 03:50 PM
handlewanker Re: WidgitMaster's Largest... 11-21-2019, 05:31 PM
widgitmaster Re: WidgitMaster's Largest... 11-21-2019, 09:36 PM
bill south Re: WidgitMaster's Largest... 12-06-2019, 01:01 PM
widgitmaster Re: WidgitMaster's Largest... 12-09-2019, 07:42 PM
breezy1849 Re: WidgitMaster's Largest... 12-10-2019, 02:43 PM
widgitmaster Re: WidgitMaster's Largest... 12-14-2019, 05:57 PM
breezy1849 Re: WidgitMaster's Largest... 12-15-2019, 12:32 AM
Bubba Re: WidgitMaster's Largest... 12-15-2019, 12:48 AM
breezy1849 Re: WidgitMaster's Largest... 12-15-2019, 06:15 AM
bill south Re: WidgitMaster's Largest... 12-15-2019, 01:23 AM
widgitmaster Re: WidgitMaster's Largest... 12-16-2019, 03:13 AM
breezy1849 Re: WidgitMaster's Largest... 12-16-2019, 09:37 AM
CNCMAN172 Re: WidgitMaster's Largest... 12-16-2019, 11:31 PM
widgitmaster Re: WidgitMaster's Largest... 12-17-2019, 01:12 AM
widgitmaster Re: WidgitMaster's Largest... 12-21-2019, 03:10 PM
epineh Re: WidgitMaster's Largest... 12-22-2019, 12:56 AM
epineh Re: WidgitMaster's Largest... 12-22-2019, 01:13 AM
widgitmaster Re: WidgitMaster's Largest... 01-03-2020, 09:30 PM
stragenmitsuko Re: WidgitMaster's Largest... 01-03-2020, 10:10 PM
widgitmaster Not useful! As I already... 01-03-2020, 10:40 PM
cd_edwards Re: WidgitMaster's Largest... 01-03-2020, 11:13 PM
widgitmaster Re: WidgitMaster's Largest... 01-06-2020, 02:29 AM
Bubba Re: WidgitMaster's Largest... 01-06-2020, 02:53 AM
widgitmaster Re: WidgitMaster's Largest... 01-14-2020, 01:39 PM
Bubba Re: WidgitMaster's Largest... 01-14-2020, 02:43 PM
bill south Re: WidgitMaster's Largest... 01-14-2020, 04:59 PM
stragenmitsuko Re: WidgitMaster's Largest... 01-14-2020, 06:30 PM
widgitmaster Re: WidgitMaster's Largest... 01-14-2020, 11:51 PM
widgitmaster Re: WidgitMaster's Largest... 01-25-2020, 12:21 PM
TOTALLYRC Re: WidgitMaster's Largest... 01-25-2020, 01:31 PM
widgitmaster Re: WidgitMaster's Largest... 02-09-2020, 01:58 PM
Bubba Re: WidgitMaster's Largest... 02-09-2020, 02:33 PM
TOTALLYRC Re: WidgitMaster's Largest... 02-10-2020, 09:53 PM
widgitmaster Re: WidgitMaster's Largest... 02-10-2020, 11:22 PM
widgitmaster Re: WidgitMaster's Largest... 02-16-2020, 03:22 AM
Bubba Re: WidgitMaster's Largest... 02-16-2020, 01:02 PM
widgitmaster Re: WidgitMaster's Largest... 02-26-2020, 02:30 PM
widgitmaster Re: WidgitMaster's Largest... 02-27-2020, 05:04 AM
widgitmaster Re: WidgitMaster's Largest... 03-03-2020, 01:38 PM
peteeng Re: WidgitMaster's Largest... 03-03-2020, 08:58 PM
widgitmaster Re: WidgitMaster's Largest... 03-05-2020, 01:24 AM
peteeng Re: WidgitMaster's Largest... 03-05-2020, 01:46 AM
widgitmaster Re: WidgitMaster's Largest... 03-05-2020, 01:57 AM
widgitmaster Re: WidgitMaster's Largest... 03-05-2020, 02:25 AM
widgitmaster Re: WidgitMaster's Largest... 03-05-2020, 02:41 AM
widgitmaster Re: WidgitMaster's Largest... 03-05-2020, 02:59 AM
stragenmitsuko Re: WidgitMaster's Largest... 03-05-2020, 11:05 AM
widgitmaster Re: WidgitMaster's Largest... 03-07-2020, 12:20 AM
widgitmaster Re: WidgitMaster's Largest... 03-07-2020, 12:28 AM
widgitmaster Re: WidgitMaster's Largest... 03-07-2020, 05:54 PM
widgitmaster Re: WidgitMaster's Largest... 03-07-2020, 05:55 PM
widgitmaster Re: WidgitMaster's Largest... 03-22-2020, 03:27 AM
peteeng Re: WidgitMaster's Largest... 03-22-2020, 09:31 AM
Bubba Re: WidgitMaster's Largest... 03-22-2020, 01:06 PM
widgitmaster Re: WidgitMaster's Largest... 03-22-2020, 09:31 PM
widgitmaster Re: WidgitMaster's Largest... 10-27-2021, 04:58 PM
mactec54 Re: WidgitMaster's Largest... 10-27-2021, 09:28 PM
bill south Re: WidgitMaster's Largest... 10-28-2021, 01:49 PM
Bubba Re: WidgitMaster's Largest... 10-28-2021, 01:53 PM
the4thseal Re: WidgitMaster's Largest... 10-31-2021, 04:07 AM
widgitmaster Re: WidgitMaster's Largest... 11-22-2021, 05:00 PM
Bubba Re: WidgitMaster's Largest... 11-22-2021, 06:10 PM
widgitmaster Re: WidgitMaster's Largest... 12-14-2021, 03:12 PM
CNC-Joe Re: WidgitMaster's Largest... 12-19-2021, 04:06 PM
CNC-Joe Re: WidgitMaster's Largest... 12-19-2021, 09:37 PM
Bubba Re: WidgitMaster's Largest... 12-14-2021, 04:00 PM
bill south Re: WidgitMaster's Largest... 12-15-2021, 02:41 PM
widgitmaster Re: WidgitMaster's Largest... 12-21-2021, 02:32 PM
Bubba Re: WidgitMaster's Largest... 12-21-2021, 02:46 PM
widgitmaster Re: WidgitMaster's Largest... 05-13-2022, 12:44 PM
Bubba Re: WidgitMaster's Largest... 05-13-2022, 01:33 PM
bill south Re: WidgitMaster's Largest... 05-13-2022, 12:58 PM
widgitmaster Re: WidgitMaster's Largest... 05-13-2022, 02:13 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2023, 02:36 PM
widgitmaster Re: WidgitMaster's Largest... 03-27-2023, 02:40 PM
Bubba Re: WidgitMaster's Largest... 03-27-2023, 03:59 PM
widgitmaster Re: WidgitMaster's Largest... 03-28-2023, 01:11 PM
gmfoster Re: WidgitMaster's Largest... 03-28-2023, 10:27 PM
widgitmaster Re: WidgitMaster's Largest... 03-30-2023, 05:56 PM
widgitmaster Re: WidgitMaster's Largest... 01-02-2024, 05:47 PM
    Nov 2013
    82
    I have bought 3 steppers (425oz Nema 23), a C10 BOB, 48v PS and 3 KL-4060 drivers from Automation technologies. One of the drivers smoked after I had used it once. He refunded my money (via PayPal). I bought a new one from him and have had no troubles. I would buy from him again.
    :cheers:
    W.
    Custom 24x24 MDF, 1/2-10 5 start,425 OZ KL steppers, KL-4060, C10 BOB, 48v PS. VCarvePro V7, LinuxCNC, Craftsman 1.75Hp 1/4" router.
    Jun 2005
    1828
    Widget,
    That guy's store name is "SunshineSmileService" he seems to sells truck loads of stuff, but has had 7 negative feedbacks in one month, which is not good. I know if you file a complaint with ebay they will block his ability to pull your money, they hold it in escrow. Clearly the ebay add says "NEW", he will need to replace it or issue a refund, he is actually starting to get near the threshold where his account will be reviewed by ebay, but he does do a lot of volume. Man you have no luck at all.... I got a great laugh from Kuroguy, about picking up the monster... LOL Thanks I needed it today..
    Russ
    Aug 2011
    154
    I bought stuff from Automation Technology Inc when they were Keling I was treated right and the stuff worked as advertised.
    Jul 2007
    265
    Infoshine15 is the seller I bought my VFD and spindle from. No problems, and quick to ship. I placed the order on a saturday, and the package was shipped on the following tuesday.
    The VFD has a speed control knob too.
    Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    Ok, I now have another spindle on order, this one's from Infoshine15 !
    I had a tracking number 30 minutes after placing the order, so far I'm confident this one will be good!
    Now, I have ALL the electronics working smoothly, everything in Mach3 setup correctly! Now I've been told by PMDX that I need a MACRO's to trigger the relay's on the BoB, so the yellow & blue LED's light up!
    Can anyone help me with this? I now have a 2nd printer port to use, so there's no shortage of pins!
    The 1st Macro needs t0 trigger the K2 relay on port #2, Pin #14. This turns on Yellow LED when the g-code is paused in Mack3!
    The 2nd Macro needs to trigger the K1 relay on Port #1, Pin #1, This turns on the blue LED & buzzer, when the machine has stopped for a tool change.
    Widgit
    Mar 2003
    35494
    What are the Output numbers that you have those pins assigned to?
    I believe that a Brain is a better choice for the Pause Output.
    The 2nd one needs to be in your M6Start macro.
    Let me know the Output #'s and I'll get you something.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    The Yellow LED was installed from the beginning of the build, so not hooking it up makes the machine look broken
    Sorry, I do not know which output numbers to use either!
    Its a PMDX-126 BoB
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Mar 2003
    35494
    You need to assign the pins to outputs.
    Go to Ports and Pins, Output pins, and assign them to Output #'s.
    Then tell me what output #'s you used.
    Gerry
    Thanks so much Gerry!
    K1, Port-1, Pin-1, Output#1
    K2, Port-2, Pin-14, Output#2
    Widgit
    Mar 2003
    35494
    OK, I killed two birds with one stone.
    Unzip the file to Mach3\Brains.
    Start Mach3.
    Go to Operator > Brain Control. Select Widgit_LEDs and check the enable box. If it's not listed, click Reload All Brains.
    Close and restart Mach3, and your LED's should work.
    Gerry
    WOW !!
    Start Mach3.
    The procedure & macro's work like a charm! :banana:
    Now I guess I'll have to wait on the spindle, or go get some MDF for the spoil boards!
    Widgit
    Last night I finished upgrading the electrical diagram for the Monster, it may not be industry standard, but it clearly indicates all the components and their connections! I have made it available in AutoCAD-2000 .DXF format, for those who want a look! The plot file is 36" x 48"
    Widgit
    Well, the spindle should be here soon! It's raining again, so I cant get the MDF sheets for the spoil board! But I have finished the VCarve Pro file for my 1st project!
    I have always wanted to cut a really large Aztec Mayan calendar, so here's what I came up with! It's cut from a 48" x 48" x 3/4" sheet of MDF!
    Now wood working is definitely NOT my strong point, but I think I can spray or paint the top surface with urethane prior to cutting. Then possibly put a dark stain on the cut surfaces, leaving the top un-stained! Or will it bleed under?
    I tried to upload the 13-MB zipped VCarve Pro file, but it must be too large for the Zone to handle!
    The 1st tool is a 1/4" drill, pecks 4x holes in the corners.
    The 2nd tool is a 3/32" 2-flute endmill, cuts the wide areas .375" deep.
    The 3rd tool is a 5/8" diam 90 deg 2-flute V-Bit, finishes all the calendar details.
    The 4th tool is a 1/4" 2-flute endmill, cuts the perimeter, leaving 12x thin tabs.
    Jan 2006
    2985
    Widgit
    I don't have much experience with hobby grade finish but in the woodshop we will normally cut the piece, spray the whole thing with acrylic lacquer sealer, then spray tinted lacquer on the whole thing, then sand off the top removing all the lacquer from the uncut parts. Then we can finish the whole thing in clear lacquer as required.
    If you seal it and then cut it, the stain will soak under your urethane and make it look like crap. This is especially so with intricate designs like yours.
    It would be a good idea to do some small tests before you ruin a couple days worth of work
    Matt
    Apr 2007
    8082
    Quote Originally Posted by keebler303 View Post
    Widgit
    Matt
    My latest red oak Celtic weave Paradise box project was cut into bare wood, sanded, stained with MinWax Early American liquid stain, then sprayed three coats with clear satin polyurethane from rattle cans. Now that it has been glued together I'll add some Java gel stain in specific areas of the weave and top panel and then wipe most of it off, which leaves an aged effect.. The fourth coat of spray poly will seal it. The gel stain seems compatible with the poly and I have seen no tendency to flake off with age, as it's trapped under the final coat of poly. I'll post photos tomorrow.
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2005
    1271
    Widgit;
    You have my plotter. Where in the heck to you find ink cartridges for it? I bought a bunch off of fleabay and most are dried out. I'm almost to the point of getting rid of the 750C and replacing it with a newer model. Unfortunately, I only use it for hobby so it's almost a waste of money but they sure are nice to have!
    Regarding the Aztec, give carve1 a shout. He is the forum guru when it comes to finishing off mdf!
    Looking forward to watching your machine dance!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  17. #17
    Apr 2007
    8082
    Quote Originally Posted by bill south View Post
    Widgit;
    Bill
    Anything you do with MDF on the surface (surface planing or sanding) will make the surface rougher than it comes from the factory because the surface is rolled or compressed and the fibers are laying flat. I apply a moderately heavy coat of clear satin polyurethane using a foam brush.and wait overnight or however long it takes to harden. Colder climates may take two days. Florida climates may take 2 hours in the sun. The first coat is sucked into the fibers quickly and takes longer to cure. Then I apply two or three more coats until the surface is well sealed. Letting the first coat fully cure minimizes how much of the second coat sucks in. You'll use a lot of rattle cans spraying it on and not waiting for each coat to fully dry. Cut the calendar only when the poly is fully hardened. The liquid stains WILL travel under the poly layer as mentioned, but what I do differently is to use gel stain, which does not soak into the MDF or porous woods like the red oak I use a lot also. I dab the gel stain into the cuts with a cheap 1" chip brush and don't worry too much about staying in the cuts. Cleanup is done with folded paper towels with a small amount of paint thinner on it. (Not wet, just slightly damp) The paint thinner does not dissolve the poly while picking up the excess gel stain from the poly coated surface. Just wipe the flat areas clean. It takes a little practice but you'll get good results. When doing large projects like a 48" calendar do a section and clean it, then do another section, until completed. Start in the middle and work outward so you don't get the gel stain all over your arms.
    James McGrew Woodworking in Columbia, SC has a 48" Aztec Sun Stone calendar on the shop wall. He made it on his big Camaster CNC machine.
    I recently completed a small MDF project where I painted the MDF with gloss black poly, then cut a Vcarved impossible object from a drawing I found. I colored the shallow lines with neon green acrylic artist paint and used water on folded paper towel instead of paint thinner. Water clean-up is compatible with the acrylic paint and the poly or MDF wasn't affected at all. Same technique as with gel coat clean-up but using the appropriate solvent for the acrylic.
    CarveOne
  18. #18
    Thanks Matt! That's what I expected, and I like the idea of sanding the top afterwards!
    Bill, I get them from Staple's office supply, order online or at stores!
    I bought it on eBay, then I had it serviced and its been problem free! The service was $75, the guy took it all apart and cleaned everything then replaced some old rubber parts too!
    You can clean the jet ends of the cartridges, by banging them on the table until the clotted ink breaks loose. I do it on a bunch of tissues!
    Widgit
  19. #19
    Jul 2007
    265
    I usually cut the V-toolpath at a Z-level that is 0,5-1mm below the top of the material, and them plane it after painting. Wood thickness is so inconsistent, and that way the V-toolpath ends up being even across the surface, plus the amount of wood I take off is too much for paint to bleed through.
  20. #20
    Jan 2006
    2985
    Quote Originally Posted by tahustvedt View Post
    I'll be impressed if you have a planer 48" wide and even more so if you run MDF through it!
    You could put it back on the machine after painting and surface it to achieve the same effect though.
Page 51 of 90 41495051525361
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. 4-axis CNC-router, NEMA23 steps, Gecko 540, Water cooled spindle
    By Vaffel in forum CNC Wood Router Project Log
    Last Post: 10-18-2010, 08:54 PM
  5. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
