603,383 active members*
3,273 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
Page 7 of 91 567891757
Results 121 to 140 of 1805
  1. #121
    Dec 2004
    783
    http://www.cnczone.com/forums/showthread.php?t=186540 should be fixed, might want to drop a reply in that thread.
    Sent from tapatalk
  2. #122
    May 2010
    88
    Quote Originally Posted by widgitmaster View Post
    I have been unable to log on to CNCzone with my pc's, as google chrome & McAfee keep telling me the website is infected with a virus!
    I have many pictures to upload, so i hope they fix it soon !
    Widgit
    Ps I'm logged in with my iPhone!
    Hey Widgitmaster -
    I'm getting the same deal with chrome. To bypass while using Chrome: If you click on the "Advanced" link to the right of the "Go Back" button you will see two items appear where the "Advanced" link was. The link on the right should say something like "Proceed at your own risk", click that and you are in.
    This lets me use chrome and bypass the malware warning. What is likely happening is someone is uploading an attachment that is infected [I'm assuming innocently without their knowledge] and Google/Chrome/McAffee look for this and flag the site as a malware source.
    Shane
  3. #123
    Apr 2007
    8082
    You can see what has been happening here in problems forum and post any problems you are having. In the past it has been due to Google seeing files that it thinks contains malware code, but doesn't.
    In Firefox security settings you can tell it to ignore the warnings. At your own risk of course.
    CarveOne
    http://www.carveonecncwoodcraft.com
  4. #124
    Jun 2004
    6618
    I had to clear my cache and cookies.
    It happened to me yesterday. I still get the warning screen, but Paul says its fixed now, so should go away soon.
    Lee
  5. #125
    WOW, That must have been a bad Cyber Attack!
    This morning Microsoft updated my XP OS with a bunch of security installs!
    Now lets get back to the build!!!
    I have removed one of the long rails, and clamped it to the cross ribbing. Then I removed one of the long tubes, and placed it on top of the router table.
    Next I made up a pair of setting gauges that will attach to the same 6mm screw holes that are used by the long rails. The gauge will allow me to accurately clamp the 3/4" solid square bar down the side of the long tube. Then the welder can put a stitch-weld between the gauges, and move over to the next set of 6mm holes. All this to ensure the square bar is 3/8" down from the top of the long tube! When the welding is finished, I will place the long tube in the mill, and cut a 1/2" x 1/2" step down the entire length of the weldment. This will be an accurate nest for the rack-gear to nest in!
    Attached Thumbnails Attached Thumbnails 9x5_Router_180.jpg   9x5_Router_181.jpg   9x5_Router_182.jpg   9x5_Router_183.jpg
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  6. #126
    While CNCZone was down, I worked on the X & Y-Axis drive mechanisms. Here is a preview!
    Attached Thumbnails Attached Thumbnails 9x5_X-AxisDriveSystem000.jpg   9x5_X-AxisDriveSystem001.jpg   9x5_X-AxisDriveSystem002.jpg   9x5_Y-AxisDriveSystem001.jpg
  7. #127
    Nothing new to post, as I'm still waiting on materials, components, and the welder! Who is MIA
  8. #128
    Mar 2004
    1806
    Widget,
    IT's Friday and you know when a welder gets payday, its libation time for a day or so!!!! He will show up on Monday:})
    Art
    AKA Country Bubba (Older Than Dirt)
  9. #129
    Good News! The welder arrived and my parts are being welded
    Now I have an electric question!
    What is required to hookup steppers with encoders?
    I have purchased a little encoder kit from Automation Technology Inc., along with one of their NEMA34 steppers. THe motor has a dual shaft and two threaded holes on the back end for mounting the encoder! The maximum shaft diam is 8mm, and the stepper is 12.7mm, I have no problem turning the shaft diam to fit the encoder, but not if it can't be connected into my router!
    I have looked through the manual for the PMDX brealout board, and do not see anything for encoders.
  10. #130
    Dec 2004
    783
    Mach3 can't close the loop http://www.machsupport.com/forum/ind...?topic=15204.0
    You will need special stepper drivers, or linuxcnc, and the encoders will only work to trigger estop if you lose steps, which should never happen if set up right.
    I thought we covered this already
    And please don't disassemble the motor to turn the shaft down, you will kill it.
    Sent from tapatalk
  11. #131
    Dec 2004
    783
    Found this http://www.rogersmachine.net/encoderinterface.html but a search on it just found a bunch of problems getting it to work correctly, and it will only go into feed hold if it senses a position error.
    Sent from tapatalk
  12. #132
    Jun 2013
    1041
    You can look into the k-flop from dynomotion. They can do closed loop steppers. Also works with mach 3.
    Ben
  13. #133
    Now that is disappointing, I really wanted to use encoders on this machine!
    But not if I can't use all the nice boards from PMDX,Inc. and Gecko drivers!
    So far I've only ordered one of the encoder kits for $39.95
    And NO, I would never dismantle a stepper, as I know it would kill it!
    Turning it between centers on the lathe would not have been a problem tho!
  14. #134
    Dec 2007
    2133
    Sorry in advance, I don't want to hijack the thread, but I've got to ask, why does dismantling a stepper kill it? I've done several and have never seen an issue.
    btw, enjoying watching your build!
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  15. #135
    Dec 2004
    783
    Quote Originally Posted by aarggh View Post
    cheers, Ian
    They are magnetized after being assembled, and you lose some of the flux when you take the rotor out of the stator. Not true for all steppers, but definitely the hybrid breed.
    It won't kill it completely, just reduce the torque by a good margin, and chances are they will run too hot at their rated amps afterwards.
    http://www.cnczone.com/forums/genera...er_motors.html
    Sent from tapatalk
  16. #136
    Dec 2007
    2133
    Quote Originally Posted by Dylwad View Post
    Sent from tapatalk
    Thanks for the link, very interesting, and seeing as it's Mariss himself testing, argument closed! Now I know not to pull my steppers apart!
    cheers, Ian
  17. #137
    A little progress today!
    So far I've cut the steel tubes for the X-Axis slide frame, along with some of the smaller plates. Every thing has been filleted for welding.
    The rest arrived today, and I quickly washed off all the black oil from the steel so my whole shop doesn't get that nasty look! I think they coat the steel with used motor oil, it's bad !
    The long beam has not returned from the welder, but now I have some other parts to keep me busy
  18. #138
    This morning I started squaring up the steel plates in the mill, first by placing the vise on its rotary base. Then I dialed the vise in square, and milled the short end of the thicker plates. Now I have to rearrange the jaws, so that I can mill the long side of the plates. Next I milled the short end of the big 1/2" thick plates, milling them to length. The stock was way oversize, so I scribed a line and made several passes .1" deep until I cut through the long side of the plate leaving a nice strip of metal for the stock pile!
    The 1" thick plate will mount on top of the three linear trucks, then the gantry will attach to the thick plate. The edge of the plate will have three 3/8-16 UNC threads, for attaching the thinner plate. There will be two gusset's welded to the bottom of the 1" plate, which will attach to the thinner front plate. The thin plate will have two 1" diam posts welded from the back, a short one will protrude .500" and have a 3/8"-16 UNC thread in the center. This will be the pivot post for the NEMA34 motor swing plate.
    Attached Thumbnails Attached Thumbnails 9x5_Router_197.jpg   9x5_Router_198.jpg   9x5_Router_199.jpg   9x5_Router_200.jpg
  19. #139
    The guys at the Air Boat shop made me a really nice water tank for the Spindle's cooling system!
    It measures 18" long, 9" wide, and 6 1/2" tall. It holds 4.2 Gallons! They even welded up a nice fill port with a cap, and two ports for a transparent water level tube connection! The drain is on the bottom.
    The pump is 1/8 HP, 13 GPM (gallons per minute), which is obviously overkill
  20. #140
    Apr 2007
    8082
    Sweet...
    Wish I could TIG weld like that. Wish I could TIG weld at all.
    CarveOne
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. 4-axis CNC-router, NEMA23 steps, Gecko 540, Water cooled spindle
    By Vaffel in forum CNC Wood Router Project Log
    Last Post: 10-18-2010, 08:54 PM
  5. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
