587,192 active members*
2,336 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > wierd problem on our tc-22 z axis please help!!!
Results 1 to 4 of 4
    Jun 2010
    15
    We are having a strange problem on our tc-22. This problem is only happening on certian programs, other programs work ok. All operations on the right end of the x axis work ok but when the table moves to make a cut on the left end of the x axis table as the table moves past the halfway point the number on the screen for the z axis changes from 8.5xxx to 321.xxx and we get a fault saying that the z axis was commanded to move too far negative. some of our programs work ok and some fault out, the programs that do fault have not been changed and we have used them for yoars. I'm pulling out my hair
    Nov 2004
    3028
    Switching from inch to metric?
    Check your program.
    George
    Jun 2010
    15
    No it does not appear that the programs have changed. It act like the z axis encoder loses track of it's position but why would it when the table moves to the left end. Since the z axis has a seperate cable and is not connected to the table I don't see how a left movement of the table could affect the position of the z axis
    Jun 2010
    15
    One other thing that we have noticed is that the tlo is an unusually large number like 325.xxx. The how can the machine run without faulting on the z axis on the right end of the table but fault on the left end of the table. the operator tells me if they input the tlo manually it will always revert back to the old number (325.xxx)
  1. A wierd shaped block
    By cncadmin in forum EnRoute
    Last Post: 02-15-2012, 08:10 AM
  2. HOMEBREW Z AXIS WIERD BACKLASH
    By dgalaxy in forum Bridgeport / Hardinge Mills
    Last Post: 05-03-2008, 04:05 PM
  3. Fanuc PMC: wierd FIN signal?
    By Jung in forum Fanuc
    Last Post: 02-04-2008, 09:18 AM
  4. Wierd z axes problem
    By jonmessenger in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-01-2007, 10:49 PM
