Hello,
First off, great forum, already read a lot of stuff here on previous projects. Registered and returned, hope you could advice me on a issues. The following is stone-coal english, im Dutch, sorry.
Currently i'm working on an art project, this project consists of a painting 'battle' with my current project, an XY router capable of holding different tools.
I designed the machine myself. Parts are handmade (frame), lasercut (those pieces needed for precision, on a Trotec Speedy 500) and 3D printed (Mendel90). All the wooden stuff is done cut from MDF, frictional parts are coated with PVA (D3 white woodglue, water diluted) thoroughly in order to resist grease. It's Y motors are mounted on the X-axis itself. All steppers are a 1:3 transmission on a rack, X-axis is 1:2. Racks and gears are also MDF lasercut. The steppers themselves are NEMA17 driven by A4988 drivers. It already might be an obvious point as in design requirements: IT NEEDS TO BE AS CHEAP AS POSSIBLE! I realize that requirements of both laser cutters and CNC machines don't combine with cheapness. Still, i just finished the Y-axis and its supprisingly smooth & stable, so i'm optimistic.
So i used the trotec, asking myself; "why in the **** aren't these machines produced in 'full plate' (244 x 122 cm) format?". I realised later that i was building a larger machine and that it might carry a laser as well (on gantry).
I'm aware of the following things;
- Nema17 is'nt going to cut it when it comes to speed; neither the drivers aren't.
- Using wood for transmission & racks are a pretty bad idea when speeds increase.
- Gantry should be lighter material. In order to reach higher speeds.
My questions;
- CO2 laser tubes and their 'beam divergency' is this going to be a problem in distances over 2 meters. And yes; is this problem solvable with different lenses?
- Why is the focal distance always controlled by moving the table height? Why not change the distance to material by moving the lens on a Z-axis?
- Is there (URL please), a payable $300 - $600 80W (more = better) watt CO2 laser available. (Yes i Googled, lots of. Does anyone have good expierences with?)
Greeting, Tom
