588,165 active members*
4,266 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Will build a Benchtop mill including Castings! Comments appreciated.
Page 4 of 15 2345614
Results 61 to 80 of 300
  1. #61
    Oct 2005
    612
    Hi CNCfun&games,
    That is a work of art. A good sized base with the top boxed over and the generous webs it looks like a winner to me. I wish I had your talent for design.
    Look forward to seeing the casting of this.
    cheers,
    Rod
    Perth, Western Australia
  2. #62
    Jun 2006
    2512
    I think the design would benefit from some internal vertical webs on the side sections. The horizontal webs do little to add resistance to simple bending in either the x or y planes. This would match my observations of cast and fabricated structures required too perform similar functions.
    Just a thought
    Phil
    Quote Originally Posted by CNCfun&games View Post
    Jalessi
    I will probably cast 5 pcs in the present design. If the rigidity isn’t adequate I’ll happily take your suggestion and enclose the rear of the column. Adding a core will definitely increase the stength and the complexity.
    Johnc2309
    The base weighs 33# and the column #40.
    Those castings in bronze would be something!!
    Rodm1954
    Would appreciate your input.
    HI All,
    Enclosed are photo’s of the modified column.
    I will start the pattern making this week, and post a comprehensive
    photographic record of the build.
    W. Smith
  3. #63
    Nov 2005
    334
    philbur: Thanks……. Good Idea, & easy to incorporate too!
    HI All
    I am presently planning how I will make the pattern for the new column.
    I’m happy to start work on this project because it will give me an excuse
    To break out a Harbor Freight 6” Rabbeting Jointer I purchased in December.
    I will disassemble it and re-paint it with Rustoleum as part of retrofitting
    it with a Grizzly Indexable Carbide Cutter Head. The cutter head is a magnificent
    beast and I can’t wait to try it out. Nails & knots beware!!
    If there is any interest, I’ll post some pictures of the installation along with the pattern
    making process.
    W. Smith
    Attached Thumbnails Attached Thumbnails 6 Ind.Rabbeting Jointer.gif   Jointer,Cutterhead.jpg
  4. #64
    Feb 2008
    10
    have you tried lost foam casting, i am starting to build a small mill and used this for my paterns. but i cant melt iron so mine is going to be bronze
  5. #65
    Nov 2005
    334
    Lost Foam Process
    Johnc2309,
    I have never used the process!
    Would enjoy seeing some of your work.
    Feel free to post here.
    W. Smith
  6. #66
    Jul 2005
    15
    Hi CNCfun&games,
    I just bumped into this thread today ... great work and reading.
    You mentioned back in post 56 and 57 that you needed some advice on rack & pinion. I've done a little bit of work with a custon 25deg modular design we cut on our wire at work, but if you visit www.mechmate.com their entire machine build is designed using R&P and I REALLY like the self tensioning mount design there for both straight and gearhead (my personal choice) steppers.
    If you haven't found the answers you were looking for I'd suggest a visit to that site (open downloads for registered members ... same basic ethics and principals as this site).
    I think you may like their overall design once you look at it, I felt their approach to the linear bearings developed into some fresh new directions in the recent revisions.
    Hope this helps you out.
    Rob
  7. #67
    Nov 2005
    334
    Pattern's in work!
    acssgt,
    Thank you very much for the link!!
    That mechmate site is terrific....hard tearing my self away.
    I'm presently on a patternmaking binge, but it was a pleasant distraction.
    That site is very informative & highly recommended.
    HI All!
    The column pattern is coming along and i've decided to make a new base pattern similar to the existing 11 x 17 one which will be 17" x 19". It will
    accommodate my modified Enco cross slide and also serve as a sturdy foundation for a bridge mill concept i've been thinking about. Will
    make an additional pattern for a bridge side panel which will look
    similar to the new column but only 2" deep. 2 will be required to
    support a seamless tube about 2" x 4", 5/16" wall.
    12" x 12" Travel OK?
    Will post a layout soon for comments.
    Hope to have a series of photo's posted in the next week.
    W. Smith
  8. #68
    Nov 2005
    334
    Two New Concepts
    Hi All,
    Enclosed are sketches of the two new concepts!
    I am presently working on the three patterns.
    The purpose is to build the machines with gray iron
    castings which will be capable of doing serious work.
    The benchmill will use the modified Enco cross slide, and should be a
    very inexpensive solution for the guy who wants to machine steel
    with a minimum of tooth rattle.
    The Bridgemill will be patterned after my existing Unit which is rock solid.
    It will be configured to use the Enco slide or a Y axis integral to the Bridge.
    Naturally all will be CNC-able.
    Comments are always appreciated!!!
    W. Smith
    Attached Thumbnails Attached Thumbnails a1 Benchmill master-v2.jpg   a1 bridgemill master.jpg
  9. #69
    Nov 2005
    334
    Match Plate Pattern
    Hi All,
    Finished the woodworking stage of the Upright Column for the Bridge Mill
    and have begun the finishing process. Many coats of sanding sealer
    with filleting & block sanding between coats.
    Will start on the base in parallel while waiting for the sealer to dry.
    From the earlier sketch it is apparent that I have made a couple of changes.
    This is part of the evolutionary process in my case, because as I start
    assembling the pieces of the pattern refinements become apparent.
    More changes are in the works for the other side of the match Plate.
    W. Smith
    Attached Thumbnails Attached Thumbnails a1%20Benchmill%20master-v2.jpg   a1%20bridgemill%20master.jpg   Upright column-01.jpg   Upright Column-02.jpg
  10. #70
    Jul 2008
    That is indeed a very impressive project, I admire your skills.
  11. #71
    Feb 2008
    10
    Johnc2309,
    W. Smith
    this is one of my sand castings. i build fancy tattoo machines and have a small foundry and machine shop. i dont have any pics of the foam casting right now but when i cast my milling machine base i will get it on here. how do you think the bronze will do as a base
  12. #72
    Feb 2006
    1187
    Nice work John!!!
  13. #73
    Feb 2008
    10
    thanks
  14. #74
    Nov 2005
    334
    Time to get back to work!!
    Just returned from a 2400 mile Train Ride from Orange Cnty, California to Portland,
    Oregon and Back.
    THEBETTERONE:
    Noticed this was your first post . Welcome to the CLUB!!
    John 2309:
    Thanks for posting your fine Casting. Your product development and sculpting skills
    are enviable. I’m sure you will design and cast a very sturdy machine base.
    W. Smith
  15. #75
    Nov 2005
    334
    Pattern Making Changes in work!
    Pattern making progress!
    Enclosed is a picture of the rough column pattern, lots of details
    remain to be fabricated before it is attached to the match plate.
    Several changes were made to the column to add extra strength.
    Jalessi take note!!
    It will be closed and the pattern will be used for both halves.
    This will require a core to make the inside of the part hollow.
    Several cutouts will be added to the core to gain access to the interior.
    New dimensions are : top 5” x 5” , base 6.5” x 8.75”, ht 20.75”
    The Upright column for the bridge mill is being painted and block sanded to
    achieve a smooth finish. That Norton sandpaper is terrific stuff.
    W. Smith
    Attached Thumbnails Attached Thumbnails p1-column-bm-b.jpg   p2-column Pattern a.jpg   p2-column Pattern ba.jpg   p3-uprightPattern b.jpg
  16. #76
    Nov 2005
    334
    Pattern Progress
    HI ALL,
    The Column Pattern is just about finished.
    I’ll use the same pattern for the Cope & the Drag,
    and put an extra protrusion on one core half to open
    up the lead screw slot from the inside on one( the front) surface only.
    A modification to the black , cone shaped core supports
    may be necessary to keep the core from rotating.
    The two core boxes will be completed, and then I’ll
    be able to make that judgement.
    I just received my Gecko G251’s so I hope to finish the
    Cross Slide’s in the next few weeks.
    Attached Thumbnails Attached Thumbnails p1-Column-fin-g.jpg   p1-Col & core parts-h.jpg
  17. #77
    Feb 2006
    1187
    Any Updates?
  18. #78
    May 2003
    162
    YOU BETTER NOT QUIT ! !
  19. #79
    Nov 2005
    334
    UPDATE!
    ZipSnipe: See update below.
    Foam27: QUIT?……NEVER!!!!
    Update:
    1). Am concentrating on finishing the CNC mod’s to the 2 Enco CROSS
    SLIDES.
    a. Slide#1: ULTRA model with THK Rails & Blocks. Bearings & Delron Nuts
    added to ACME Screws.
    b. Slide #2: LOW COST model Utilizing existing dovetail slides with small
    Oiler, Bearing & Delron Nuts added.
    2 ). Assemble an Elec. Pkg. for the above, using G251’s, Mini I/O, Keling
    Mtr’s & Pwr S.
    3 ). Assemble my custom made “D” Series BOB for use with G540’s & cheap
    computer cables.
    4 ). Finish Knee Mill Modifications & assemble.
    5 ). In my spare time I’ll investigate Pack & Pinion Drives and Auto Tool
    Changers.
    6 ).Work on my Moving Gantry ROUTER as time permits. See Thd # 69283.
    W. Smith
  20. #80
    Feb 2006
    1187
    Okay anymore updates?
  1. Convert a 2 axis Cross Slide to CNC-comments appreciated!
    By CNCfun&games in forum Benchtop Machines
    Last Post: 10-25-2017, 06:21 PM
  2. Will Build a Moving Gantry ROUTER-comments appreciated.
    By CNCfun&games in forum CNC Wood Router Project Log
    Last Post: 12-25-2016, 01:06 AM
  3. DIY benchtop mill build
    By mkuivamaki in forum Benchtop Machines
    Last Post: 03-19-2014, 08:54 AM
  4. Designed from the ground up - including castings
    By Hack in forum Vertical Mill, Lathe Project Log
    Last Post: 02-09-2012, 11:09 PM
