587,326 active members*
3,186 visitors online*
Results 1 to 7 of 7
    Mar 2017
    164
    Will a new computer run a CNC machine
    Hi all , I don't have an older computer anymore and was wondering what is the best solution for running a CNC router table with a modern day computer ?
    I was going to use Mach3 or 4 .
    Update : may go with CUCNC as per ger21
    I bought XP years ago , but newer desktop motherboards don't support XP .I also purchaced a copy of windows 7 .
    It wouldn't be on my network , so viruses wouldn't be a concern .
    Originally I wanted to use my laptop , but have been reading there not ideal , so it's back to building a desktop comp.
    Would be a bonus to buy an enclosure large enough to install a computers MB and the neccesary components to run a CNC router table all in one .
    I read at CNCrouterparts that you can add a parallel port PCI express card to a desk top computer, but I don't know enough about this subject to determine whether it's a good choice . Also seen a product called Smooth Stepper that works with your USB port .
    Anyways to sum it up , if you we're starting from scratch and had to build a new computer,
    what would your choices be ?
    Does windows 10 have to many programs running in the background , making it a poor choice ?
    I'm not trying to nickel and dime this , just wanting to learn what would be the most stable and reliable choice to run a CNC router table .
    I will be using a separate computer in my home for designing , just looking for dedicated comp ideas for a CNC .
    Thanks in advance guys.
    Rick
    Mar 2003
    35538
    Re: Best case scenario for running a CNC
    Not too many people are using the parallel port with modern PC's. If you're using a motion controller, you can use a laptop, although a dedicated desktop is better imo. I've seen some people using those mini PC's that cost about $200 to run their control software.
    I'd recommend UCCNC rather than Mach3/Mach4. It's cheaper, and better than Mach3. And Mach4 is an unfinished product imo, that's far too complex for most people.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2017
    164
    Thank you for the info , I'll have to check that out . I guess my main reason for wanting to go with Mach3 , was because I know people who use it and could help me if needed .
    Mar 2017
    164
    Just watched a video on Mach 3 versus UCCNC , and UCCNC was definitely the winner
    Aug 2009
    119
    Re: Will a new computer run a CNC machine
    Major, can you post a link to that video?
    Mar 2017
    164
    Quote Originally Posted by dixdance View Post
    He shows a comparison of the wood after its been cut by both programs
    https://youtu.be/UJ8NM1MVFdM
    Mar 2017
    164
    Guys I hate windows 8 and 10 and wasn't aware you could still buy windows 7 . I better buy another copy before there not available anymore
  1. Y Axis + Slave not running together when running G-Code
    By Fierra in forum Mach Software (ArtSoft software)
    Last Post: 05-19-2017, 08:56 AM
  2. PC case converted to CNC case
    By CurtisBarclay in forum DIY CNC Router Table Machines
    Last Post: 09-11-2014, 03:23 AM
  3. PC case made into CNC case.
    Last Post: 09-03-2014, 12:13 PM
  4. Replies: 0
    Last Post: 11-13-2013, 06:54 PM
  5. Bridgeport wiring nightmare scenario
    By navymachine in forum Bridgeport / Hardinge Mills
    Last Post: 08-14-2013, 12:13 AM
