587,348 active members*
5,233 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > will these limit switches work with my G540?
    Mar 2006
    233
    I am looking to buy some limit switches for my machine that I am nearing completion on and I found these. I am using a G540 and the recommended power supply that is rated for 48v and 7.3a.
    http://cgi.ebay.com/4-CNC-Limit-Swit...item3ca09fcd51
    Specs say that they are rated for 4 amps at 125 volts AC. and 1/2 amp at 125 vdc. And that these can be connected normally closed or normally open via the three sets of screw lugs.
    Jul 2007
    1602
    There isn't any significant current going through a limit switch so these would be fine.
    bob
    Jul 2008
    267
    I have similar on my data-cut and they work just great.
  1. G540 and proximity switches
    By Fixittt in forum Gecko Drives
    Last Post: 06-20-2015, 01:57 AM
  2. Limit switches and homing switches
    By AeroKam in forum Open Source CNC Machine Designs
    Last Post: 01-05-2008, 02:56 PM
  3. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  4. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
  5. Home switches and limit switches.
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 04-08-2004, 11:32 PM
