Hello, all: I am constantly amazed at the diversity (although I dislike that word) of projects, topics and assistance available on CNC-Zone. Kudos to all involved.
I have two aluminum projects I sure could use some assistance with. At 63, and for whatever reason, when looking at volumes of numbers for an extended period my mind just sort of goes blank.... not good for this type of work. Anyway, one project is engraving numbers in Aluminum; the problem is the code causes each number to be done twice; IE: the main cut and then the "clean up" return cut. I do not need the second cut, and it effectively doubles the time for the MOP.
I've tried going through the code and removing what seems to be required, but when I input it into Mach3, things are missing that shouldn't be. I'm frustrated because of the issue mentioned above, and is the only reason I'm asking for help. Time is money, so I'm open to offers to see what can be arranged.
If this goes well I'll get to the second project. Both use "G" and "M" codes. I suppose one can PM me if you're interested. As a last resort I'll post the code here for comments. Maybe this should/could be in the Classifieds, but thought more people would see this here. Thanks!
John
