Will Windows 7 64bit with onboard 25 pin serial connection work with my syil x4?
I think you mean parallel port? Mach will not run under the 64 bit operating system. The parallel port drivers for Mach are 32bit only.
Thank you for the reply. What is the best solution in this case?
Get a PC with a 32bit OS, or buy a device like a Smoothstepper, which will work with Mach3 and your OS.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
pumpercloggs
What brand of computer do you have, they are not all equal
Mach3 runs with no problems on windows7 using 64bit,with the right computer, but you will need a U100 or a smooth stepper to make the conection from your computer to the Breakout board you are using, USB for the U100 & Ethernet for the smooth stepper
Mactec54
