what spindle manufacturer are you using guys?. Most only require a 5 min warmup higher end spindles say no warmup. HSD 915 and 919 with ceramic bearings says no warmup time is needed....
george i tried some of the changes in the acceleration rate to rapid you have been telling me about, cnc helper reexplained it on another thread and it made more sense.
James McGrew CAMaster 508 ATC
www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
Probably not recommended, but we've never warmed up the 10HP HSD spindles on our point to point machine, and they lasted over 8 years of daily use before needing a rebuild.
A friend and I just bought a used Shop Sabre 4860 router that came with WinCNC 2.4. I have been running Mach3 on my homebuilt router and Taig mill. Apparently WinCNC does not use the standard M00, M01, M02, M03, M30 codes. I have been through the manual several times and so far I haven't figured out how to control the manual changing of tools.
Mach3 uses the M00 to stop and I turn off the spindle and change bits and then continue. I know WinCNC must have this capability but I haven't found it. A small code file showing beginning and ending with a tool change would be greatly appreciated.
Jim, I have been dreaming about one of the small CAMASTER machines (Stinger). It would be perfect for my shop but too many other things going on at the moment. Maybe next year. The CAMASTER machines really look good.
thanks russ, there is one more stinger in stock at camaster, i know joey sold one to a school last week, it runs on mach three and i would bet he would cut you a deal on it!!
wincnc is running tool changers on camaster machines, i am sure joey will be here soon on this!
jim
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
