587,611 active members*
4,076 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > "WIRE BREAKAGE" alarm on Mitsubishi Wire DWC90HA
Hybrid View
    Sep 2011
    7
    I've been getting a "WIRE BREAKAGE" alarm on my Mitsubishi Wire DWC90HA when the wire is running and obviously not broke. The "Wire breakage detection limit switch" beside the wire pulleys has had the wires clipped and taped since I got here so that is out of the picture (I have no idea why that works). Previously I've been pulling and cleaning the S318 wire detection sensor in the auto threading circuitry and that seemed to overcome the problem. However that stopped working and I replaced the sensor with a new one with negative results. I cannot identify any other sensing circuitry that would generate this error (T210) and as long as it is present the machine is inoperable. Has anyone experienced this before and can anyone help with a solution.
    Sep 2011
    7
    I am happy to finally be able to contribute to the knowledge base. Actually I'm passing on MitsTech's contribution. The problem was the carbide contact at the top of the auto wire threader. It needed cleaned and rotated. Because ours is broken and unused I didn't know about it.
  1. Mitsubishi wire type setting for zinc coated wire
    By Futurewire in forum EDM Discussion General Topics
    Last Post: 01-26-2011, 10:47 AM
  2. Wire for foam Cutting "EdgeSweets" machine
    By singerdon49 in forum Employment Opportunity
    Last Post: 12-29-2008, 03:12 PM
  3. Replies: 2
    Last Post: 01-25-2005, 05:26 PM
