586,036 active members*
3,636 visitors online*
Results 1 to 4 of 4
    Feb 2014
    3
    Wire Cut Robofil 310 Regulator Alarm
    Hello,
    I am working with Robofil 310, I need help, In our machine we are getting a series of alarms while cutting is in-progress, the alarms are
    E903: Regulator Error UPA
    E913: Regulator Error UPR1
    E915: Regulator Error UPR2
    E905: Regulator Error UPR3
    E907: Regulator Error UPR4
    E910: Com Error UPA
    E912: Com Error UPR1
    E914: Com Error UPR2
    E906: Com Error UPR4
    We are unable to remove it, please help!
    Shairyar
    Feb 2014
    3
    Re: Wire Cut Robofil 310 Regulator Alarm
    Our problem is solved. We replaced E/S PIL board. The machine is working properly now.
    Jul 2020
    3
    Quote Originally Posted by shairys88 View Post
    I have this Problem Too
    i want know the reason of this error?
    Oct 2023
    4
    I have COM. ERROR UPR4, UPR3, UPR2 And UPR1.
    My engr have replaced E/S PIL Board, Optical Cables, PA/SA Card, Swapped the UPR Boards. But no changes. The same error i am getting. Kindly let me know the solution if you have the idea. Your suggestions will be highly appreciated.
    Thanks & Regards
    Chandran
  1. Charmilles Robofil Wire Edm
    By sundara in forum EDM Discussion General Topics
    Last Post: 08-01-2017, 09:56 PM
  2. Charmilles Robofil 310 wire breakage problems
    By chrisgraf2 in forum EDM Discussion General Topics
    Last Post: 01-22-2014, 06:33 PM
  3. Help needed for Robofil 200 Wire Edm software
    By yssvaff in forum EDM Discussion General Topics
    Last Post: 10-11-2012, 04:32 AM
  4. Vero Peps Wire EDM Camtek and Charmilles Robofil 440
    By tewkesbury129 in forum EDM Discussion General Topics
    Last Post: 09-07-2012, 10:06 AM
