586,061 active members*
4,416 visitors online*
IndustryArena Forum > Maintenance in General > SERVICE FOR CNC-MACHINES > Wire has stopped getting hot - ABF Aixia Croma Pro Foam Cutter
    Dec 2016
    3
    Our hot wire cnc machine wire will not get hot, need repair technician asap or if you have any suggestions for things we can do ourselves. Thank you!
    Jun 2013
    443
    Re: Wire has stopped getting hot - ABF Aixia Croma Pro Foam Cutter
    Fuses. Breakers. Power.
    Sent from my SM-N970F using Tapatalk
    Dec 2016
    3
    Quote Originally Posted by boydage View Post
    Thank you! Yes, we have checked all of the components you mentioned, everything is confirmed to be working except for the wire temperature. Thanks!
  1. Hot Wire Foam Cutter need Help mach3 Setup
    By libas77 in forum European Club House
    Last Post: 11-26-2014, 04:01 PM
  2. First CNC Hot Wire Foam Cutter
    By TiboJ in forum CNC Wire Foam Cutter Machines
    Last Post: 12-08-2013, 05:06 PM
  3. croma aixia 848 Foam cutting machine
    By nunez0687 in forum CNC Wire Foam Cutter Machines
    Last Post: 07-23-2013, 03:43 AM
  4. CNC Hot wire Foam Cutter
    By Krashlnd in forum CNC Wire Foam Cutter Machines
    Last Post: 01-17-2006, 02:57 AM
  5. Croma Foam Cutter Available
    By misterkev in forum CNC Wire Foam Cutter Machines
    Last Post: 01-04-2005, 05:16 PM
