Usually any machine that is fed purely from a 3 phase supply, the vast majority do not include or feed a 1 ph supply, any 1ph control or circuitry is usually done via a single phase transformer inside the enclosure, the primary of which is wired across two of the phases.
In a B phase system, usually one corner of a delta supply is earth grounded for a neutral.
If so you should have the same voltage between phases.
This system is very rarely used now.
Al.
Albert E.
