what are the normal wires to use to hook the stepper driver to the breakout board i am using 16ga wire for my 120 volt hook up but since the voltage has drop with the connection between stepper and board can i use a 22ga wire
22 AWG wire is rated for 3amps, If referring to the control signal to the stepper drive itself, that should be a lot less than 3amps.
Al.
Albert E.
See answer from pippin88: https://www.cnczone.com/forums/diy-c...88206-cnc.html
Recent post from Misumi.
https://blog.misumiusa.com/how-to-se...gn=weekly-blog
Al.
Albert E.
Thank you for sharing, I recommend the best buy coursework- Service With 100% High Grades
If you are looking for a short-term web designing course and want to know how a website is created using programming languages then you can join a short term web design course in Rohini . This course will give a clear understanding of how a website works and how you can create a website using programming languages.
https://www.admecindia.co.in/courses...courses-delhi/
Want to build your career in design and be a professional graphic designer? By joining a graphic design institute, you can learn about different tools and master graphic design skills. Check out the courses here-
https://www.admecindia.co.in/course/...master-course/
https://www.admecindia.co.in/course/...e-master-plus/
https://www.admecindia.co.in/course/...urse-standard/
https://www.admecindia.co.in/course/...gning-premium/
Want to be a web developer and build amazing websites? Join a web development course and learn programming languages such as PHP or Pu=ython. Check the courses below-
https://www.admecindia.co.in/course/...andard-course/
Hey guys! Looking forward to being a web designer? Join ADMEC as it offers web courses to students whether it be web designing or web development. Check out the courses by clicking on the links below-
https://www.admecindia.co.in/course/...r-plus-course/
https://www.admecindia.co.in/course/...remium-course/
