603,383 active members*
3,323 visitors online*
Thread: Wiring help
Results 1 to 5 of 5
Threaded View
    Mar 2007
    60
    Wiring help
    Can someone tell me which terminals I use for A/C hookup on the 24v 4.5 power supply. I know on the supply there is are two A/C terminals on the left and I'm guessing a ground terminal right next to them. Do I use all 3 terminals for the AC wire?
    Sorry but I'm a little electrically challenged - I still don't know the difference between ground and negitive.
    Also, If someone can explain all the connections I have to make with the little 5v supply, that would help also. I looked at the wiring diagram and am still confused. I was able to hook everything up except what goes to the power supplies and I don't even know if the red and black I have from the 24v to the drivers is correct. I did route the power wires low and the driver wires high. From what I remember, it's not good to have regular wires too close to power wires. (Note: In the picture, I used white instead of blue from the drivers to the motor connectors.)
    Here is what I've done so far.
  1. need help wiring
    By dtman in forum Waterjet General Topics
    Last Post: 07-14-2020, 07:10 PM
  2. wiring it all together
    By russell in forum CNC Machine Related Electronics
    Last Post: 08-22-2006, 03:08 PM
  3. CNC wiring?
    By stdly in forum CNC Machine Related Electronics
    Last Post: 02-18-2006, 09:44 PM
  4. P5 Wiring
    By tintruder in forum Servo Drives
    Last Post: 02-03-2006, 06:13 PM
  5. Wiring help.
    By dmgdesigns in forum CNC Machine Related Electronics
    Last Post: 04-17-2005, 05:12 AM
