587,083 active members*
2,989 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Wiring stepper motors to drivers
Results 1 to 11 of 11
    Nov 2007
    8
    Smile Wiring stepper motors to drivers
    Steve and the gang,
    Thanks for all the help with the parallel port to driver interface connections. Now that I have a harness built for the computer parallel port interface, I am ready to wire the motors to the drivers. I have two unipolar six wire steppers p/n 57BYGH405A and two CW260C drivers. The color code on the stepper motor is A=RED, C=GRN, B=YEL, D=BLU and the coil center taps are black and white. The drivers have six connections on the power side labeled: <DC70V/VCC, GND, A+, A-, B+, B-. Which wires on the driver go to which wires on the stepper motor.
    Thanks DiBo
    Mar 2006
    489
    The drivers you have are for servo motors with optical feedback. They won't work with stepper motors.
    Paul
    Nov 2007
    8
    What type of driver should I be using?
    Hey, Paul whats up? I bought the stepper motors and drivers from the same place and they recommended one should be used with the other. The print on CW260C calls it a Microstep Driver. How can I find something that will work and have a wiring schematic that makes sense?
    Thanks DiBo
    Sep 2006
    104
    Driver sounds like bipolar driver.
    You can connect the motor like bipolar, leave the center taps disconnected, or half of each coil.
    Mar 2003
    35538
    Do you have some instructions or data sheets that you can post?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2003
    35538
    Nevermind, I found some info. Not 100&#37; sure, but I think its:
    A+ = Red
    A- = Yellow
    B+ = Green
    B- = Blue
    However, looking at a data sheet for your motor (and a poor one at that), it looks like the Yellow is one of the center taps???
    I'd recommend calling the people you bought them from and ask them how to wire them. Looks like Circuit Specialists?
    Gerry
    Nov 2007
    8
    wiring stepper motors to drivers
    Hey guys, I have everything hooked up and tried to run my steppers with a shareware version of turbo cnc through windows 2000. I believe all my wiring is correct to the parallel port and my drivers, but nothing works. The driver is a CW260C and the steppers are 57BYGH405A. The thing I am unsure of is what is the purpose of en+ and en-. I wired both drivers en+ to pin 1 of the parallel port. From what I have been able to learn pin 1 from the parallel port is a strobe. I don't know if that has anything to do with why nothing works. The voltage at cw+ and cp+ is 2.9vdc constantly and the voltage at en+ is 2.7. If i remove the wire from either driver en+ a sound the motors sound like they want to move but don't. I am frustrated and I wanted to just quit, but now it has become a challenge to learn more so I will not accept defeat.
    Thanks DiBo
    Mar 2003
    35538
    TurboCNC will NOT work in Win2K. It can't get the needed access to the parallel port. It will work marginally in Win98, but really should be run in plain DOS
    Gerry
    Sep 2006
    104
    en is probably enable
    cw is probably direction control
    cp is probably the step control
    en will probably need to be wired to a pin that will be high while operating the steppers or fixed to a high level.
    Jan 2008
    5
    Solutions
    Hello John and all the rest. I know this is an old post but no one has posted a great reply yet.
    57BYGH405A from http://www.circuitspecialists.com/pr...57BYGH405A.pdf
    CW260C also from Circuit Specialists.
    I have both the same motor and the same controller and they are not the easiest to work with.
    Here is what I did to get them to work.
    Red to A+, Green to A-, Yellow to B+, Blue to B-, White and black connected together.
    Roger
    What sort of IPM do you get with that setup
    Quote Originally Posted by rykegrey View Post
    Roger
    I have the exact setup as that, and I can only get 15 IPM at best running a 1/2" acme thread 10 TPI screw. I'm looking for 40+ IPM.
  1. Sherline CNC - Suitable Stepper Motors and Drivers
    By FusionTiger in forum Benchtop Machines
    Last Post: 11-16-2007, 04:51 PM
  2. Stepper motors, drivers etc
    By _taz_ in forum Stepper Motors / Drives
    Last Post: 08-05-2007, 12:49 PM
  3. Stepper motors wiring and available inputs
    By future in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-20-2006, 02:57 AM
  4. Replies: 3
    Last Post: 05-22-2005, 03:55 PM
  5. What to use for wiring stepper motors?
    By CNC Darren in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 06:40 AM
