603,993 active members*
3,430 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > WJ200 + 1.5kWw Air-cooled, am I missing any settings?
    Mar 2013
    12
    Question WJ200 + 1.5kWw Air-cooled, am I missing any settings?
    Greetings all, I have read through some of the other threads regarding the WJ200 but most of them seem to relate to a water-cooled setup so I thought I would ask in my own thread what settings I need to set for my setup (mainly to make sure I'm not missing anything! Like I *think* I read in one thread that I thought you should set some minimum frequency somewhere to avoid "burning out an air-cooled spindle")?
    So my setup is an Air-cooled 1.5kW chinese spindle and a WJ200 (the 1.5kW model). I am using a PMDX-107 which I have wired according to instructions I got from Steve Stallings at PMDX (thanks Steve!). I have not yet wired the spindle but I have tested the VFD without the spindle wired and it appears to work correctly (when I press the diagnostic/test button on the 107 the spindle fires up to 24,000rpm and then when I press it again it goes to the proper 30% rpm [around 7600rpm or something]).
    Using the ProDriveNext software I have only changed 4 things on the VFD, so I'd like to know if I'm missing any items that I need to set before I wire up the spindle to this sucker! These are the settings I have changed:
    A001: Frequency Source: <01: Control Terminals>
    A002: Run Command Source: <01: Control Terminal>
    A003: Base Frequency: <400.0>
    A004: Maximum Frequency: <400.0>
    While I'd love to think that's all thee is to it, I feel like maybe I'm missing some items? Thanks in advance!
    Oh, this is how I am wired from the 107 to the VFD:
    PMDX-107 >>> WJ200
    Rev/Dir >>> 2
    Fwd/Run >>> 1
    COM >>> P24
    Aref >>> H
    Aout >>> O
    Agnd >>> L on lower row
    strap >>> PLC to L on upper row
    Sep 2010
    1765
    w/o looking at terminal strip pinpout, all u say sounds good. min speed is good idea to not overheat a motor but u can just not turn it all the way down to 'too' slow urself too. besides, chinese 400v@24krpm means the voltage is soooooooooo loooooooooow at low speed that it wont produce any meaningful torque - or heat - anyway, so probably a mute point.
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Hitachi WJ200 Settings Help
    By BanduraMaker in forum Spindles / VFD
    Last Post: 10-09-2014, 05:25 PM
  3. 2.2kw water cooled ground connection missing
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 12-05-2011, 06:24 PM
  4. Water cooled spindle 2.2kW settings
    By lolos1979 in forum DIY CNC Router Table Machines
    Last Post: 08-27-2010, 07:23 PM
  5. Air cooled or water cooled ?
    By anstac in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-23-2009, 09:12 AM
