587,840 active members*
3,494 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Wolfgang Spindle Options
Page 1 of 2 12
Results 1 to 20 of 22
Hybrid View
    Feb 2009
    1290
    I posted this in the PCB area because I feel the Wolfgang spindle is targeted directly for PCB isolation routing. I'm not going to be doing large pockets and heavy hardwood carving with it. I'll use my Porter Cable for that.
    This is the motor wolfgang uses on his spindle?
    http://www.herbach.com/Merchant2/mer...de=TM99MTR3285
    Here is a motor I purchased at Princess Auto for about the same price PN: DF651(2)LG. The reason I mention it is because someone else mentioned using it for a replacemment for the wolfgang but I think that might not be a good idea. Here is a PDF the salesman at Johnson sent me with the specifications for the DF-651(2)LG.
    There are probably more motors with the same physical dimensions and shaft size. It would be nice if you find one list the motor here.
    Ultimately I would love to control the speed of the motor from Mach3 using PWM. I have a simple circuit to control the on/off and I will post it here when I have it done up in Eagle.
    Brent
    Feb 2009
    1290
    I located some pictures of a partly disassembled WG spindle.
    Attached Thumbnails Attached Thumbnails P1270192.jpg   P1270188.jpg   P1270181.jpg   P1270178.jpg
    Dec 2004
    1137
    No, that's just the collet removed Simple to do and I do that after each job to make sure any fine dust does not get in during a tool change.
    Jun 2003
    3312
    Quote Originally Posted by Drools View Post
    Brent
    Are you buying a Wolfgang or tyring to duplicate one or?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Feb 2009
    1290
    I purchased one. My main reason for building a CNC router is to do PCBs, wood is secondary. That is why I purchased this unit, however there seem to be others that have purchased this spindle and I really cannot find any user support and options on the web so I'm hoping this thread might serve as a common meeting ground for others using this spindle.
    Feb 2009
    1290
    Do you think the WG spindle with a end mill will hold up to Aluminum? Maybe with very shallow cuts?
    Apr 2005
    438
    From my experience with a WG spindle the answer is no.
    Apr 2009
    10
    Mine wolfgang spindle fell apart even without cutting anything.
    Photos here http://www.cnczone.com/forums/showthread.php?p=778495#post778495 of the thing disassembled into pieces.
    Now I have it properly glued, however it has lost its "stated" precision so I had it cut the aluminium/brass. 1mm depth at up to 300mm per min, 3mm two flute endmill, around 15000rpm... did the job, no problem.
    Would not normally do that, but due to the loss of precision after reassembling I felt that I have nothing to loose.
    Dec 2004
    1137
    I wouldn't do it with a $200 spindle. I have a $110 Proxxon IB/E for that Of course it depends on if you are engraving or milling, using a wood router or a benchtop mill.
    Feb 2009
    1290
    Ya probably better to use my PC router when I get the parts I need to mount it.
    Dec 2004
    1137
    I hate that you "threw it in the trash". Richard said he would add any type of bearing you want. I was looking for more vids and projects with your Romaxx though ... have you posted anything new recently?
    Apr 2005
    438
    No new video lately, it's been too hot to play in the garage with the Houston heat. I still have to cut the other end of a small counter top book stand for my wife and will post that when I do it. It has a 2.5D Texas crest on it.
    Yea on the "trash" I should have tried to replace the bearings before I trashed it. Came across the motor and the mount I had made for it the other day, found a use for the mount but the motor still in the junk pile.
    Aug 2009
    62
    Many thanks for this topic.
    I am thinking also on buying a Zenbot CNC and wolfgang, for making PCB.
    I live in Portugal, there is no 120V here. Could I use the 24V on wolfgang motor? It's a good idea or should I do something else?
    Thank you.
    Feb 2007
    4553
    Unhappy
    Lovebugjunkie,
    I wish you would have tossed the Wolfgang in my direction.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2005
    438
    Quote Originally Posted by jalessi View Post
    Lovebugjunkie,
    Jeff...
    If you have a use for the motor and spindle to motor mount that came with the WG you are welcome to it. If so drop me a pm with your address and I will get it to you.
    Dec 2004
    1137
    Post Actual motor and specs from Johnson Electric
    I did some looking. The surplus Herbach motor posted by Drools is not the same one on my Wolfgang that I purchased from Richard.
    This is the one I have. For posterity I will post the information as well.
    Of interest: this is AC only intended for low power application.
    Jay
    Attached Thumbnails Attached Thumbnails Wolfgang_motor.jpg   Wolfgang_motor_specs1.jpg   Wolfgang_motor_specs2.jpg   Wolfgang_motor_specs3.jpg
  17. #17
    Feb 2009
    1290
    Jay I'm a little confused. The motor you posted is not a AC only but a High Voltage DC motor. I posted the PDF that I got from Johnson in my initial thread. The WG spindle did originally come with a DC only motor probably the one you posted and Richard changed to the 120VAC motor.
    Dear Brent,
    Thanks for your information.
    After our checking, DF651(2)-LG is one of our motor series name, this is HVDC(high voltage DC) motor, the norminal voltage is 120VDC.
    Attached is a relevant product datasheet. pls check for your reference,
    You can also find it from our website. Thanks.
    (See attached file: DF651(2)LG-001.pdf)
    Best regards,
    Roy
    Ext. 2154
    Tel. +86 755 29900535
    Strategic Marketing
    VIP Center, 3/F, 11B, Johnson City
    Johnson Electric Group
    website: http://www.johnsonelectric.com
    This motor is most likely a Universal type which means it can ge run AC or DC but it will last much longer on DC. That is according to all the information I have found on Universal Motors. I have not tried mine on 24VDC yet but it might be worth a try, maybe quieter and cooler operation might result.
    Brent
  18. #18
    Dec 2004
    1137
    Yeah I just noticed that I was focusing on the surplus link I guess.
    Universal motors
    Brent
    I'm interest in those results. When this motor dies, I plan to use a modified RC BL motor.
  19. #19
    Feb 2009
    1290
    My spindle is driven with 2 o-rings, one of the o-rings broke on Monday. My buddy that works at a local hydraulics store, set me up with 2 of the following.
    The o-ring was a 2-137 (standard o-ring size number): nominal size 2-1/16id x 2-1/4od x 3/32 cross section.
    The new belts work just fine, in fact I think the motor is quieter due to less slop in the o-rings.
  20. #20
    Feb 2009
    1290
    It has been a while since my WG spindle has been mounted. I have been using my big Porter Cable router but I have been putting off some PCB making for too long so I put the WG back on. The big PC router does cut PCBs just fine but the noise of the router and I would rather wear the bearing out on the big PC cutting wood than PCBs.
    One thing I noticed right away with the WG mounted, the router would not home while the motor was running!?!?
    It turns out this motor is quite noisy EMF wise, I took some tin-foil and wrapped the motor and the AC power cord and now it homes every time with the motor running. I think my missed steps from previous trouble shooting may have been caused from this noisy motor. Any thoughts on this?
Page 1 of 2 12
  1. Wolfgang Engineering TB-350 spindle review
    By Rhodan in forum Community Club House
    Last Post: 10-26-2009, 06:44 PM
  2. Wolfgang engineering spindle
    By frejohg in forum Want To Buy...Need help!
    Last Post: 11-14-2008, 11:13 PM
  3. Fuji Frenic Spindle Drive....repair options
    By TR MFG in forum CNC Machine Related Electronics
    Last Post: 09-16-2008, 12:29 AM
  4. WolfGang Eng Spindle
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 02-15-2008, 04:54 AM
  5. Spindle Options for Woodworking CNC
    By gymcaster in forum Commercial CNC Wood Routers
    Last Post: 03-20-2007, 05:24 AM
