587,518 active members*
3,481 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > wonderment about pockets
Results 1 to 6 of 6
    May 2009
    33
    So we do a lot of pocket milling here at our shop, and now we start at the center of the whole and cut material out to diameter. Now i know just cutting the outside profile, and letting the solid peice fall thru the middle will save time... but my concern is that when the solid peice finally does fall through, i was worried it might bind up with the tool and cause a crash??? tips tips tips please!
    Quote Originally Posted by CORBIN92087 View Post
    Look into surfcam's truemill technology. Go insanely fast.
    Jun 2008
    130
    If you can set up a fixture so the loose bit is fastened down so it won't move when the supporting metal is cut away, you should be alright. You might want to set up a cut with a v-shaped section, the way you would to part a piece off on a lathe, so that there is a little extra clearance between the loose bit of material and your cutter.
    Jim
    No time to do it right, plenty of time to do it twice.
    Feb 2005
    376
    I've done a lot of dropping slugs out of material, and I've lost a lot of cutters doing it.
    The trick is to have a controlled drop, and some free room for your cutter doesn't hurt either. Pretty simple to do. Run your profile, ramp in do whatever and leave a good chunk of XY stock, maybe .030 on 1/4 thick stuff, maybe .100 or more on the thick stuff, and leave a little in the Z, .010-.015 if the slug is going to be light, .050 or more if its going to be a heavy one. Now take your finish pass, or semi finish depending on what kind of finish and tolerance, completely through the material and as you start coming back to your starting point the slug will start to fall on the far side, bending that little bit of stock you left in the Z, as you break through, its already 3/4 out of the way and it finishes falling.
    Jul 2009
    108
    I do a good share of drops on the parts I run. I agree with Bubba. I pay close attention when I'm prgramming the part where and when I want the drop to happen. The material thickness to leave for drop depend a bit on the material running, tool steel I left about .015 for final pass. Alum. I leave more material
    Jun 2008
    130
    This method in [ame="http://www.youtube.com/watch?v=Ob-RBntcZc8&feature=related"]YouTube - Frà¤sen von einem Aluminium Notebookgehà¤use[/ame].
    Jim
  1. Cutting pockets
    By carvemylog in forum Uncategorised CAM Discussion
    Last Post: 08-05-2009, 03:54 PM
  2. Pockets and Islands -
    By 2Bits in forum Dolphin CAD/CAM
    Last Post: 04-24-2009, 03:35 AM
  3. pockets
    By raymond1 in forum Haas Visual Quick Code
    Last Post: 05-20-2007, 12:59 PM
  4. Open Pockets
    By big_mak in forum OneCNC
    Last Post: 08-04-2006, 05:45 PM
  5. Eliminating Pockets
    By robinsoncr in forum Rhino 3D
    Last Post: 06-27-2006, 05:21 PM
