#atccncrouter
Working Area 1300x2500x200mm Spindle ATC 9.6KW Italy original HSD spindle, ES951 Model. 6000-24000RPM Control system Taiwan SYNTEC 60WE control system with MPG handle wheel, more precision Drive system Japan YASKAWA 850W servo motor and drivers, Z axis with brand brake.
Japan Shimpo reducer.Inverter Taiwan Delta B Model 11.0KW Machine Frame New type thicker and bigger heavy duty 8 mm Working table Vacuum table with T slot, 4 Zones Tool Magazine 12 pieces with Carousel Tools Changer Guide rail Taiwan PMI linear guide, 25# Transmission X,Y-helical rack pinion, Z axis with 2505 TBI ball screw Tool sensor Automatic tool sensor Collect ISO30 tool holders with ER32 collect Lubrication system Automatic lubrication system for rails Traveling speed 65m/min Working speed 25m/min Voltage 380V,3phase, 50HZ Limited switch Japan Omron limited switch Electric part French SCHNERDER switch Electric Wires High soft shield with copper wire to protect against static electricity, UL/CE standard Shanghai Cardiff brand Vacuum Pump German KVT3.140 4.0KW Becker vacuum pump Dust Collector 1.5kw double bags dust collector system. Europe CE standard Drilling Head Italy HSD 9 vertical type
