603,965 active members*
3,453 visitors online*
Page 1 of 2 12
Results 1 to 20 of 37
    May 2012
    Smile Wooden built CNC Router
    Hi everyone !!!
    I'm pleased to show you a new CNC birth, named B2CNC :
    This machine is built with Baltic Birch and MDF. There is still lot to do, like permanent wiring, a new aluminum Z axis, locate and install all the limit switchs, and finally, design and built the base.
    Some specs :
    - Cutting area of 30" by 60" by 7.5"
    - Moving gantry
    - Rack and pinions for all axis, including the Z
    - THK linear rails, from Ebay
    - Four stepper motors, Nema 23, 425 oz/in
    I began the design few months ago, and read a lots of forum, french and english, to determine the spec of my machine.
    Few weeks ago, the "Z prototype" was mounted to the gantry, so I made a little milling test with aluminum. The result was better than expected, so I decided to finish the machine with the actual Z (prototype made with baltic birch) and use it to mill the real Z axis parts in aluminum.
    So, the real fun will begin soon !!!
    Bye !!
    Nov 2006
    1036
    Very cool!! Please post more pictures!!
    May 2012
    Few pictures :
    Attached Thumbnails Attached Thumbnails IMG_2390.JPG   IMG_2391.JPG   IMG_2398a.JPG   IMG_2400a.JPG
    May 2012
    The fun began today !!!
    I've made temporary connection, draw a little thing on the computer, generate the G-Code, and did the first cut !!!
    B2CNC - First cut !! - YouTube
    I used a piece of pine, and a 2-Flute end-mill. The speed was 150 ipm for the rough cut, an 100 ipm for the final cut.
    Works great !!!
    Bye !!
    Mar 2003
    35494
    How did you attach the rails to the wood? What type of fasteners?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2012
    I forgot to take a picture of that during the assembly...
    To install the rail in the good place, and minimize the misaligment possibility, I made a slot in the baltic birch, just large enough for the rail, and 1/8" deep. So, the rail is perfectly aligned with this process.
    To maintain the rail, I just use wood screws from my "pocket hole" kit. These screws have a flat head and fit perfectly in the rail holes.
    Edit : Picture from the drawing
    Bye !!
    Mar 2003
    35494
    Thanks.
    Gerry
    May 2012
    Hi !!
    I've made a second milling test toning, with a sample file from 3dMachinist.
    My "ball nose" cutter used for the finishing pass is really cheap ... But the result is not too bad !!!
    Except for one thing ... You can see a drift on the picture, so the router height drift during the finishing process by around 0.25" ... I don't know is there was a drift during the rough pass ... But for sure, I've made a good "zero" juste before the finishing pass ...
    Everything seem to be be tight on the Z mechanism ...
    Anyone has an idea ??
    Mar 2003
    35494
    Try reducing the Z axis acceleration.
    Gerry
    Jan 2008
    853
    Perhaps too tight or too heavy, and it was missing Z steps on the way up? Does it drift when doing air cuts as well?
    An appropriate project from La Belle Province today !:cheers:
    Cheers!
    May 2012
    I've just made an other test, and I am in a good way !!!
    I dont know why I've made this, but I've set the kernel frequency to 100kz ... I decrease to 35kz, and this is now definitly better !!! And the max speed is absolutly enough !!
    Tomorrow, I will test the Z acceleration, and that will surely fix the little remaining drift.
    Thanks for the tips !!!
    Bye !!
    May 2012
    Quote Originally Posted by PaulRowntree View Post
    Cheers!
    Yes, I've made the next tests "on air", without wood. And the drift was there.
    My last, with the lower kernel frequency, was also on air, and the drift was almost gone. A little more tuning to do tomorrow with the z accel ...
    Salut !!
    May 2012
    New test tonight ...
    No more drift !!! :banana::banana:
    Thanks to everyone !!
    Jan 2008
    853
    Great! What were the original and final Z acc values?
    May 2012
    The final accel value is 15. The Z movement is very smooth.
    Bye !!
    Mar 2003
    35494
    Got any pictures of your Z axis r&p?
    Gerry
  17. #17
    May 2012
    Picture from the actual prototype (built with baltic birch plywood), or from the drawing of the real aluminum version ??
    Bye !!
  18. #18
    Mar 2003
    35494
    Both??
    Gerry
  19. #19
    May 2012
    Hi Gerry,
    Few pictures of the actual prototype, and 2 from the actual design of the final Z.
    If need to modify the design to add dust collection.
    Bye !!
    Attached Thumbnails Attached Thumbnails IMG_2425.jpg   IMG_2426.jpg   IMG_2428.jpg   Z-1.JPG
  20. #20
    Mar 2003
    35494
    Gerry
Page 1 of 2 12
  1. Wooden Sign Processed by CNC Wood Router
    By omnicnc in forum Omni CNC
    Last Post: 08-01-2012, 07:15 AM
  2. How To Open CNC Wood Router Wooden Case
    Last Post: 05-30-2012, 04:16 AM
  3. My First Router, Built in Steel
    By Haydn in forum CNC Wood Router Project Log
    Last Post: 09-15-2009, 07:05 PM
  4. Steel router on wooden table?
    By sonicwonder2000 in forum DIY CNC Router Table Machines
    Last Post: 05-29-2009, 11:24 PM
