Hello, my particular machine doesn't have support for additional co-ordinate systems enabled. I'm having a problem where it seems like almost randomly, mastercam decides to use a different WCS - it spits out G56... This freezes my machine in its tracks.
How can I disable this so that it ONLY codes using the standard machine coordinate system? I've tried going into the WCS settings and clicking "wcs off" and such, but had no luck.
Any guru's?
Since the WCS isn't setup in the machine, I might try just manually punching it back to G53 or whatever the machine co-ord is, and see if it still runs straight down the center. I think that might work.
Ideas?
TIA-
Pete
