Hey all,
I recently purchased a used but new 40w chinese laser. The owner was hoping it was plug and play and boy was he wrong lol. So his loss is my gain.
I purchased the laser with a specific task in mind for using the laser to generate some extra income to cover costs. So far it has not worked right away with every step of my simple process.
Currently to get the machine to cut i have to draw it in Inventor and export it as a dxf. Then I import into corel draw and save as a .plt. This finally got the machine to actually cut something after many hours!
Now the issue im having is my template im trying to cut is a square with corner radius's. My machine is making two passes for each cut but is not shutting off the laser when it moves back to the start of the radius for the second pass. So instead of getting the radius it lops the corner off for a chamfer. I quickly ran out of my test material so needed to pick up more and will play with it tonight, just wanted to see if anyone has an experience with this issue.
Also on a side note is there a thread any where that lays out all the possible upgrades for this machine? That would be pretty useful since these machines are 10x cheaper then alternative machines. And also 10x a PITA!
