588,380 active members*
5,075 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > Would like to use FineCut consumables to cut 3/16" mild steel sheet. Is it possible?
Results 1 to 4 of 4
    Apr 2003
    103
    Alright, here's my deal.
    I have a DynaTorch 5x10 machine with a Hypertherm Powermax 1250 G3 and the T80M machine torch. Initial height is set using Dynatorch's ohmic sensing geehaw, and cutting height is set via arc voltage.
    I cut a lot of 11 ga mild steel using the finecut consumables, and I'm happy with what I'm getting there.
    However, I'm working on a new product line that will require the extensive use of 3/16" sheet (still mild steel), and I would very much like to continue being able to use the finecut stuff.
    I need the reliable edge condition and definition of geometry that I get from the finecuts, but I need to use the thicker material.
    Is it possible to cut 3/16" mild steel with the finecut consumables?
    If it is possible, could you guys spot me some info on cutting data?
    A jumping off point to tune from would be most helpful.
    An answer from Jim Colt would likely make my week.
    Thanks for your time guys.
    Ryan Shanks - Logic Industries LLC
    http://www.logic-industries.com
    Jan 2008
    2247
    A lot of users are happy with the FineCut parts on 3/16" steel. Here would be a suggested starting point.
    Use the 220404 deflector, the 220061 ohmic cap.
    Pierce height: .15"
    Cut height: .08"
    Pierce delay time: .6 seconds
    Cut speed: 40 to 50 ipm
    Amperage: 45 to 50
    Expect light dross....it will be easy to remove. By experimenting with speed you can minimize the dross. Expect a bit shorter nozzle life as these consumables last longest at 40 amps or less....but that power level is a bit too low for 3/16"
    Jim Colt
    Quote Originally Posted by CoolHand View Post
    Apr 2003
    103
    Quote Originally Posted by jimcolt View Post
    Pierce height: .015"
    Cut height: .08"
    Amperage: 45 to 50
    Jim Colt
    Excellent, that'll get me started.
    One question, do you really mean to pierce at fifteen thou off the surface? (0.015") Or is that supposed to be one hundred fifty thou? (0.150") Or maybe the two numbers are transposed?
    It seems odd to pierce at a lower height than you would cut at.
    EDIT: BTW, do you have a recommendation for the arc voltage that is likely to yield the prescribed cut height? Just ball park it for me, if you would.
    Jan 2008
    2247
    I changed my message....pierce at .15" off the plate, the rest looks correct! The arc voltage will be a guess...probably around 85 to 90 volts. Just do a long cut and adjust voltage up or down until the height is as close to .080" as you can get.
    Thanks for the correction!
    Jim
  1. 1" mild steel milling
    By LarryRichardson in forum Employment Opportunity
    Last Post: 09-29-2010, 01:31 PM
  2. Fine-cut consumables - 1/4" mild steel
    By energyforce in forum Waterjet General Topics
    Last Post: 04-30-2009, 01:13 AM
  3. VF-2 Cutting 1/4" Mild Steel plate
    By akedward in forum Haas Mills
    Last Post: 11-25-2007, 01:05 AM
  4. Cutting 1" Mild Steel
    By 3DSteve in forum Waterjet General Topics
    Last Post: 06-14-2007, 10:58 AM
  5. RFQ - on 1/2" mild steel plate
    By BullCreek in forum Employment Opportunity
    Last Post: 07-11-2006, 12:31 AM
