603,960 active members*
3,729 visitors online*
Results 1 to 5 of 5
    Mar 2007
    73
    Would this work for scaling size up or down?
    Sorry if this is the wrong place to post this. I have been reading a lot of the treads on the zone and have seen many where someone asks about scaling the size up or down.
    It seems to me that an easy way to do this would be to make temporary changes in Mach 3. For instance, say you have the g-code for a design, but you want to make it twice as big. If our lead screws have 10 tpi then temporarily chang that setting in Mach 3 to 20 tpi. The computer then thinks that it is moving 1" for every 20 turns of the lead screw. But since you still actually have 10 tpi lead scews those 20 turns are actually moving it 2" for every 1" of your design.
    I keep thinking there must be some reason this won't work, but so far I can't think of one. Of course, you would have to remember to reset it to the correct setting once you were done.
    Feb 2004
    361
    an alternative is kellyware kcam, will scale [seperately] x,y,and z axis', and save resulting gcode file...
    I believe the unregistered version had a 500 line limit?? not sure offhand
    Mar 2003
    35494
    Changing the steps/unit in Mach3 requires re-tuning the motors, which would be a pita to do often. A far easier way to cut something at double size is to type "2" into the scale boxes to the right of the X and Y DRO's.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2006
    603
    Quote Originally Posted by wolfdagon View Post
    You may need to run with double the bit size. There is only one way to find out so try it.
    Mar 2007
    73
    I don't actually have a machine yet, but I have looked at the Mach 3 demo. It's been a while, though, and I did not remember it having that feature. That would definitely be simpler.
  1. scaling
    By reedmiles in forum Haas Mills
    Last Post: 02-28-2008, 04:11 PM
  2. scaling?
    By BiggerHammer in forum Hobby Discussion
    Last Post: 02-20-2008, 04:40 PM
  3. HAAS scaling bug
    By gar in forum Haas Mills
    Last Post: 11-04-2007, 06:33 PM
  4. Scaling tolerances
    By Ken_Shea in forum OneCNC
    Last Post: 05-15-2003, 01:28 PM
  5. Scaling?
    Last Post: 05-13-2003, 05:58 PM
