588,522 active members*
7,750 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Wrapping around a sphere?
Results 1 to 9 of 9
    Jun 2006
    59
    I have a picture that I'm trying to wrap around a sphere but I don't know how to do that. I know how to roll around 1 axis but can get it to work around a sphere. Any ideas?
    Jun 2006
    59
    bump
    Aug 2009
    986
    EDIT: Deleted by original poster.
    Feb 2010
    translate your dwg above the sphere. make sure sphere is solid. go xform.. project..to surface... now this can be chained as a toolpath with multi axis.
    Feb 2010
    2 boxes you can check.... view and normal... this differs from normal view and the actual distorted view.
    Jun 2006
    59
    Quote Originally Posted by donuts View Post
    Okay I got to this point but it only seems to be doing half the image onto both sides..... still working.
    Feb 2010
    first ensure yous sphere is larger than your dwg. it shouldnt overlap when looking down on it in top view.
    Jan 2009
    265
    Without creating a 'fisheye' compression in the corners you will have stretched corners when viewed tangentially.
    Feb 2005
    78
    Use project toolpath. Have your surface on top view and place your picture well above the surface, Some 100MM above. translate, rotate, as needed, go to isometric view and project the geometry onto the surface, follow the prompts and instructions as you go.
  1. Axis wrapping
    By davehall in forum Uncategorised CAM Discussion
    Last Post: 10-30-2009, 04:09 AM
  2. text wrapping question
    By h_2_o in forum Uncategorised CAD Discussion
    Last Post: 04-07-2009, 08:59 PM
  3. wrapping around cylinder
    By Craigpat in forum Solidworks
    Last Post: 05-21-2008, 03:45 PM
  4. A question or 2 on wrapping
    Last Post: 03-09-2008, 10:14 PM
  5. 4th axis wrapping
    By zfarkas in forum FeatureCAM CAD/CAM
    Last Post: 12-09-2006, 07:23 PM
