588,069 active members*
4,973 visitors online*
Results 1 to 11 of 11
    Jan 2012
    714
    Write program
    Does anyone have any info on the write program? It is the last one in the Wizards on Mach 3? Is a license needed for it?
    That was the first one my Grandson wanted to try out...
    mike sr
    Oct 2008
    103
    My copy (at least 3 years old) doesn't require a license.
    Make sure you choose a font and click the "Write" button on screen.
    Jun 2005
    655
    Search for John Stevenson's writeup on the Write wizard. Useful info there.
    Feb 2009
    2143
    Quote Originally Posted by shred View Post
    This, I suspect?
    http://www.stevenson-engineers.co.uk/files/write.pdf
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Jan 2012
    714
    Thanks for the info fellows.
    I just finished the coolant tray and the back sheild, a bit of a job I might add!
    The table splash guard I will use if necessary, from what I see so far, it gets in the way if you dont need it.
    mike sr
    Jan 2012
    714
    Quote Originally Posted by Wog View Post
    My copy does work, I clicked the write button twice and it loaded the code. The font must be entered first (I think). The save buttons do work, but the write button loads the code and returns to Mach.
    I looked for a way to save the code to a USB device but I didnt have any luck with that.
    mike sr
    Apr 2006
    439
    After the file is loaded in mach. Click the "Change g-code" button at the top. It will open in notepad then you can "Save as" anywhere you want. After that close and it will return you to mach.
    Scott
    www.sdmfabricating.com
    Jan 2012
    714
    Quote Originally Posted by Scott_M View Post
    Scott
    Thank You sir! I will try that out tomorrow as I would like to keep the code on that particular file........
    mike sr
    Jan 2012
    714
    Quote Originally Posted by mike sr1 View Post
    After using the write wizard for awhile, it seems to do a nice job. I am also looking for a text software that will write in a circular fashion, on the top of a cylinder, and not break the bank ha!
    I tried the desk engrave program but it didnt work on the small radius I need, 1.750 diameter.
    I also found the cnc write program written up here on the forum, around 200 dollars.
    Any recommendations appreciated.
    mike sr
    Jan 2012
    789
    Vcarve Pro does great font engraving, and will do text on arcs.
    I use it a lot for engraving with a 1/4" half-round, and it's a breeze.
    Apr 2006
    439
    Stick Font will do it and it is free.
    NCPlot - Stick Font
    Scott
  1. Ok, how do I do write a simple program in gcode?
    By Apples in forum G-Code Programing
    Last Post: 11-18-2010, 02:42 PM
  2. Write knife grinding program
    By tr4252 in forum Employment Opportunity
    Last Post: 03-11-2010, 02:57 AM
  3. How to write a code program to cut threads
    By jjenks in forum NCPlot G-Code editor / backplotter
    Last Post: 04-22-2008, 03:18 AM
  4. Possible to write variables to a program?
    By Heavy D in forum G-Code Programing
    Last Post: 08-22-2006, 05:08 AM
  5. someone wanna write a program?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 06-07-2004, 01:47 AM
